Verdin iMX8MPlus LVDS
The Verdin iMX8M Plus supports 1x dual-channel or 2x single-channel LVDS configurations. If you use 2 single channels, you can indeed use two LCDs independently. However, the context provided does not specify the maximum resolution for each LCD when using single-channel LVDS. You may need to refer to the specific datasheet or technical documentation for the Verdin iMX8M Plus to determine the maximum supported resolution for each single-channel LVDS output.
How to add new customise HDMI resolution.
