We need to use 2 LVDS ports because we have to use independent 2 LCD.
Regarding Verdin iMX8MPLUS, it supports 1xdual channel or 2xsingle channel in datasheet.
If we use 2 single channels, can we use LCD independently? Max resolution of each LCD?
The Verdin iMX8M Plus supports 1x dual-channel or 2x single-channel LVDS configurations. If you use 2 single channels, you can indeed use two LCDs independently. However, the context provided does not specify the maximum resolution for each LCD when using single-channel LVDS. You may need to refer to the specific datasheet or technical documentation for the Verdin iMX8M Plus to determine the maximum supported resolution for each single-channel LVDS output.
HI @josephjang ,
Yes, is possible to use 2x displays independently. You essentially need to define a lvds-channel@1 similar to what this customer did in the device tree (overlay).
This information from the kernel is also useful.
From the Verdin iMX8M Plus datasheet:
A single channel LVDS interface can support resolutions up to 1366×768 pixels @60 frames per second (80MHz pixel clock maximum). For higher resolutions, a second LVDS channel is required.
I did some work in LVDS some time ago that helps explain how is LVDS transmitted:
Mitsubishi Displays - Linux information - Toradex - V1.pdf (973.8 KB)
Conclusion: Yes, you shoule be able to drive 2 independent LCD if each of them are upto 1366×768 pixels @60 frames per second (80MHz pixel clock maximum).
Kind regards,
Alvaro.
