Verdin iMX8MP – System Freeze When Starting M7 via remoteproc
hello_world.c (1.3 KB)
verdin-imx8mp_hmp_overlay.dts (1.4 KB)
overlays.txt (143 Bytes)
Hi everyone,
I am working on a Verdin iMX8MP module and trying to run Cortex-M7 firmware using remoteproc from Linux (A53 side).
I followed the official Toradex documentation:
https://developer.toradex.com/software/cortex-m/cortex-m-imx/how-to-use-remoteproc/
:desktop_computer: Setup
  • Module: Verdin iMX8MP
  • Linux running on Cortex-A53
  • M7 firmware: hello_world_cm7.elf
  • Firmware location: /lib/firmware/
  • Using remoteproc (not U-Boot booting)
Commands Used
cd /lib/firmware/
echo stop > /sys/class/remoteproc/remoteproc0/state
echo hello_world_cm7.elf > /sys/class/remoteproc/remoteproc0/firmware
echo start > /sys/class/remoteproc/remoteproc0/state
I also set the U-Boot environment variable:
fw_setenv tdxargs 'clk-imx8mp-mcore-booted=1'
:red_exclamation_mark: Problem
When running:
The entire Linux system freezes and then automatically reboots.
Any guidance on how to properly debug this would be greatly appreciated.
Thank you.
Looking at your setup, there are several key configuration issues that could cause the system freeze when starting remoteproc on the Verdin iMX8M Plus. Let me help you troubleshoot this systematically.
Critical Configuration Issue
First, there’s an error in your U-Boot environment variable. The correct command should be(1):
fw_setenv tdxargs "clk-imx8mp.mcore_booted=1"
Notice the dot (.) instead of a dash (-) in clk-imx8mp.mcore_booted=1. This is a critical parameter that prevents Linux from interfering with the M-core during boot(1).
Device Tree Overlay Verification
Ensure you have the correct device tree overlay enabled. For Verdin iMX8M Plus, you need the verdin-imx8mp_hmp_overlay.dtbo(1). You can verify this is active by checking:
cat /proc/device-tree/chosen/overlays/name
Remoteproc Status Verification
Before loading firmware, verify remoteproc is properly initialized(1):
# Check if remoteproc driver is available
dmesg | grep -E "remote|rproc"
You should see output similar to:
[    1.629455] remoteproc remoteproc0: imx-rproc is available
Firmware Loading Process
Follow this exact sequence for loading firmware(1):
# Ensure the remote processor is stopped
# Verify it's offline
cat /sys/class/remoteproc/remoteproc0/state
# Set the firmware name (must be .elf format)
# Start the remote processor
Known Issues and Workarounds
Based on community reports, there are known issues with remoteproc on certain Torizon OS versions(2). If you continue experiencing system freezes, consider these alternatives:
  1. Use U-Boot Loading: Load the firmware via U-Boot instead of remoteproc, as this method is more reliable for some firmware configurations(2).
  2. Firmware Size Considerations: Large firmware images can cause remoteproc loading failures. If your firmware is particularly large, try building a minimal version to test if size is the issue(3).
Additional Debugging Steps
  1. Check Memory Regions: Ensure your firmware’s memory layout doesn’t conflict with Linux memory regions(4).
  2. Verify ELF Format: RemoteProc requires .elf format files, not .bin files(1).
  3. Monitor System Logs: Use dmesg -w in another terminal while starting remoteproc to capture any error messages before the freeze occurs.
If the issue persists after correcting the kernel command line argument, the problem might be related to firmware memory layout or specific hardware interactions that require further investigation.
