Verdin imx8mp mallow board
Mallow Board v1.1B
verdin Imx8mp 1.1B
Capacitive 10 inch LVDS display from Toradex
hello im trying to activate the 10.1" display from toradex on mallow carrier board
i’ve added verdin-imx8mp-panel-cap-touch-10inch-lvds_overlay.dtbo to the overlays.txt and but the screen is always black
dmesg returns imx8mp-ldb ldp-display-controller: Failed to create device link(0x180) with panel-lvds-native
i tried with the verdin evaluation board with the dsi to lvds adapter and it works right after changing the overlays.txt and updating the environnement variables
i’m using Torizon OS 7.0.0
To address the issue with your 10.1" LVDS display on the Verdin iMX8MP with the Mallow carrier board, please consider the following steps:
  1. Verify Overlay Application: Ensure that the overlay verdin-imx8mp-panel-cap-touch-10inch-lvds_overlay.dtbo is correctly applied. You can confirm this by checking the directory /proc/device-tree/chosen/overlays. If the overlay file is listed and its value is 0, it indicates successful application.
  2. Check Display Connections: Double-check all physical connections between the display and the Mallow carrier board. Ensure that the LVDS cables are securely connected.
  3. Test with Weston: After applying the overlay, test the display using the Weston Wayland Compositor. Run the Weston container on your module to see if the display initializes correctly. This can help confirm if the system recognizes the display.
  4. Review Display Timings: If the display remains black, review the display’s datasheet to ensure that the timing settings in the overlay match the display’s requirements. Adjust the overlay if necessary to match the horizontal and vertical sync timings.
By following these steps, you should be able to troubleshoot and resolve the issue with your display setup. If the problem persists, further investigation into the software configuration may be needed.
Verdin IMX8MP: Use native LVDS and HDMI Interface.
Hi, @khalil.fourati!
You informed us via email that another Mallow carrier board worked just fine with the display, right?
So I think we can mark this topic as solved, since the issue was hardware-related.
