We’re trying to add a device tree overlay for an LVDS display on a custom carrier board. The steps we took:
- Compile the overlay in a Yocto build for Verdin IMX8MP
- Copy the dtbo to
/boot/ostree/torizon-0ae6185bf9fb1de8f511a613c5be079038e6b2949b00449628b02d14dfad6613/dtb/overlays/lvds.dtbo - Append the dtbo to
/boot/ostree/torizon-0ae6185bf9fb1de8f511a613c5be079038e6b2949b00449628b02d14dfad6613/dtb/overlays.txt
With this we ran into these errors:
failed on fdt_overlay_apply(): FDT_ERR_NOTFOUND
libfdt fdt_path_offset() returned FDT_ERR_BADMAGIC
Would appreciate any help figuring out what we’re doing wrong.
The device tree file:
/dts-v1/;
/plugin/;
compatible = "toradex,verdin-imx8mp";
#include "imx8mp.dtsi"
#include <dt-bindings/pwm/pwm.h>
&panel_lvds {
compatible = "panel-lvds";
backlight = <&backlight>;
data-mapping = "vesa-24";
height-mm = <224>;
width-mm = <126>;
panel-timing {
clock-frequency = <71600000 72900000 85000000>;
de-active = <1>;
hactive = <1920>;
hback-porch = <5 16 260>;
hfront-porch = <24 26 260>;
hsync-active = <0>;
hsync-len = <10 12 255>;
pixelclk-active = <1>;
vactive = <1200>;
vback-porch = <2 5 255>;
vfront-porch = <5 8 260>;
vsync-active = <0>;
vsync-len = <1 3 20>;
port {
panel_lvds_in: endpoint {
remote-endpoint = <&lvds_out>;
&pwm1 {
&backlight {
compatible = "pwm-backlight";
brightness-levels = <0 45 63 88 119 158 203 255>;
default-brightness-level = <4>;
/* Verdin I2S_2_D_OUT (DSI_1_BKL_EN/DSI_1_BKL_EN_LVDS, SODIMM 46) */
//enable-gpios = <&gpio5 1 GPIO_ACTIVE_HIGH>;
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_i2s_2_d_out_dsi_1_bkl_en>;
/* Verdin PWM_3_DSI/PWM_3_DSI_LVDS (SODIMM 19) */
pwms = <&pwm_lvds1 0 6666667 PWM_POLARITY_INVERTED>;
&ldb2 {
lvds-channel@0 {
fsl,data-mapping = "spwg";
fsl,data-width = <24>;
port@1 {
reg = <1>;
lvds_out_custom: endpoint {
remote-endpoint = <&panel_lvds_in_custom>;
Boot log:
-Boot SPL 2024.07-7.2.0-devel+git.3f772959501c (Jan 01 1970 - 00:00:00 +0000)
DDR configured as dual rank
SEC0: RNG instantiated
Normal Boot
WDT: Started watchdog@30280000 with servicing every 1000ms (60s timeout)
Trying to boot from BOOTROM
Boot Stage: Primary boot
Find img info 0x4802f000, size 1068
Need continue download 1024
NOTICE: Do not release JR0 to NS as it can be used by HAB
NOTICE: BL31: v2.10.0 (release):android-14.0.0_2.2.0-rc2-0-g7c64d4e86-dirty
NOTICE: BL31: Built : 00:00:00, Jan 1 1970
U-Boot 2024.07-7.2.0-devel+git.3f772959501c (Jan 01 1970 - 00:00:00 +0000)
CPU: Freescale i.MX8MP[8] rev1.1 1600 MHz (running at 1200 MHz)
CPU: Industrial temperature grade (-40C to 105C) at 49C
Reset cause: POR
DRAM: 8 GiB
Core: 176 devices, 31 uclasses, devicetree: separate
MMC: FSL_SDHC: 1, FSL_SDHC: 2
Loading Environment from MMC... Reading from MMC(2)... OK
get_tdx_eeprom: cannot find EEPROM by node
MISSING TORADEX CARRIER CONFIG BLOCKS
In: serial@30880000
Out: serial@30880000
Err: serial@30880000
Model: Toradex 0070 Verdin iMX8M Plus Quad 8GB WB IT V1.1A
Serial#: 15601687
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
switch to partitions #0, OK
mmc2(part 0) is current device
Scanning mmc 2:1...
Found U-Boot script /boot.scr
969 bytes read in 1 ms (946.3 KiB/s)
## Executing script at 50280000
7005 bytes read in 1 ms (6.7 MiB/s)
88166 bytes read in 2 ms (42 MiB/s)
128 bytes read in 2 ms (62.5 KiB/s)
Working FDT set to 50200000
Applying Overlay: verdin-imx8mp_hdmi_overlay.dtbo
2219 bytes read in 2 ms (1.1 MiB/s)
Applying Overlay: verdin-imx8mp_dsi-to-hdmi_overlay.dtbo
4099 bytes read in 2 ms (2 MiB/s)
Applying Overlay: verdin-imx8mp_spidev_overlay.dtbo
561 bytes read in 3 ms (182.6 KiB/s)
Applying Overlay: lvds.dtbo
3202 bytes read in 2 ms (1.5 MiB/s)
11341637 bytes read in 36 ms (300.5 MiB/s)
13127676 bytes read in 43 ms (291.2 MiB/s)
Uncompressing Kernel Image to 0
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
SCRIPT FAILED: continuing...
MMC: no card present
No EFI system partition
Failed to persist EFI variables
Loading Boot0000 'mmc 2' failed
EFI boot manager: Cannot load any image
tdx-info:
Software summary
Bootloader: U-Boot
Kernel version: 6.6.54-7.2.0-devel-g91c19e78f9da #1-Torizon SMP PREEMPT Fri Jan 31 15:24:42 UTC 2025
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/0ae6185bf9fb1de8f511a613c5be079038e6b2949b00449628b02d14dfad6613/0
Distro name: NAME="Torizon OS"
Distro version: VERSION_ID=7.2.0-devel-202502-build.5
Distro variant: VARIANT="Docker"
Hostname: verdin-imx8mp-15601687
Hardware info
Toradex version: 0070 V1.1A
Serial number: 15601687
Processor arch: aarch64
