Hello together,
I am trying to control the LEDs on the Ivy board. According to the datasheet and the schematics the pinout is as following:
First qestion: Is the SODIMM 54 multiplexed? According to the schematics not, but in the datasheet it is:
Second question: I cant find SODIMM 30, 32, 34 and 54 ind the gpioinfo
/# gpioinfo | grep -v 'unnamed'
gpiochip0 - 32 lines:
line 1: "GPIO2" unused input active-high
line 5: "GPIO3" unused input active-high
gpiochip1 - 32 lines:
line 6: "SODIMM_143" unused input active-high
line 7: "SODIMM_141" unused input active-high
line 10: "SODIMM_161" "id" input active-high [used]
line 12: "SODIMM_84" "cd" input active-low [used]
line 13: "SODIMM_78" unused input active-high
line 14: "SODIMM_74" unused input active-high
line 15: "SODIMM_80" unused input active-high
line 16: "SODIMM_82" unused input active-high
line 17: "SODIMM_70" unused input active-high
line 18: "SODIMM_72" unused input active-high
gpiochip2 - 32 lines:
line 6: "DIG_1" unused input active-high
line 7: "DIG_2" unused input active-high
line 8: "REL1" unused input active-high
line 9: "REL2" unused input active-high
line 14: "REL4" unused input active-high
line 16: "REL3" unused input active-high
gpiochip3 - 32 lines:
line 0: "SODIMM_252" "Wake-Up" input active-low [used]
line 1: "SODIMM_222" unused input active-high
line 2: "SODIMM_36" unused input active-high
line 3: "SODIMM_220" unused input active-high
line 4: "SODIMM_193" unused input active-high
line 5: "SODIMM_191" unused input active-high
line 6: "SODIMM_201" unused input active-high
line 7: "SODIMM_203" unused input active-high
line 8: "SODIMM_205" unused input active-high
line 9: "SODIMM_207" unused input active-high
line 10: "SODIMM_199" unused input active-high
line 11: "SODIMM_197" unused input active-high
line 12: "SODIMM_221" unused input active-high
line 13: "SODIMM_219" unused input active-high
line 14: "SODIMM_217" unused input active-high
line 15: "SODIMM_215" unused input active-high
line 16: "SODIMM_211" unused input active-high
line 17: "SODIMM_213" unused input active-high
line 18: "SODIMM_189" unused input active-high
line 19: "SODIMM_244" "PCIe reset" output active-high [used]
line 20: "SODIMM_38" unused output active-high
line 22: "SODIMM_76" "regulator-usdhc2" output active-high [used]
line 23: "SODIMM_135" unused input active-high
line 24: "SODIMM_133" unused input active-high
line 25: "SODIMM_17" unused input active-high
line 26: "SODIMM_24" unused input active-high
line 27: "SODIMM_26" unused input active-high
line 28: "SODIMM_21" "enable" output active-high [used]
line 29: "SODIMM_256" "regulator-force-sleep-moci" output active-high [used]
line 30: "SODIMM_48" unused input active-high
line 31: "SODIMM_44" "GPIO application" output active-high [used]
gpiochip4 - 32 lines:
line 0: "SODIMM_42" "reset" output active-low [used]
line 1: "SODIMM_46" "enable" output active-high [used]
line 2: "SODIMM_187" unused input active-high
line 3: "SODIMM_20" unused input active-high
line 4: "SODIMM_22" unused input active-high
line 5: "SODIMM_15" unused input active-high
line 6: "SODIMM_196" unused input active-high
line 7: "SODIMM_200" unused input active-high
line 8: "SODIMM_198" unused input active-high
line 9: "SODIMM_202" "spi1 CS0" output active-low [used]
line 16: "SODIMM_55" "scl" output active-high [used open-drain]
line 17: "SODIMM_53" "sda" input active-high [used open-drain]
line 18: "SODIMM_95" "scl" output active-high [used open-drain]
line 19: "SODIMM_93" "sda" input active-high [used open-drain]
line 20: "SODIMM_14" "scl" output active-high [used open-drain]
line 21: "SODIMM_12" "sda" input active-high [used open-drain]
line 22: "SODIMM_129" unused input active-high
line 23: "SODIMM_131" unused input active-high
line 24: "SODIMM_137" unused input active-high
line 25: "SODIMM_139" unused input active-high
line 26: "SODIMM_147" unused input active-high
line 27: "SODIMM_149" unused input active-high
line 28: "SODIMM_151" unused input active-high
line 29: "SODIMM_153" unused input active-high
root@6dc8511e497d:/# gpioinfo | grep -v 'unnamed'
Regards
mvo
