Verdin iMX8MP 8GB WBIT V1.1A 電源が入らない
Mallowに搭載し、電源を投入してもEasyinstallerが起動しません。
LANのLEDも一切点灯しません
他のSoMに交換すると問題なく動作します。
問題のあるSoMでは開発ボードで動作確認しても全く動作しません。
SoMのどこを確認すればよいでしょうか
Based on the context provided, here are the points you should check for the Verdin iMX8MP 8GB WBIT V1 1A SoM that is not functioning:
  1. Power Supply: Ensure that the SoM is receiving the correct voltage and current. Check that the power connections are correct and stable, as issues with power supply can prevent the LAN LED from lighting up.
  2. Physical Damage: Inspect the SoM for any visible damage or defects, such as poor soldering or connection issues.
  3. Connections: Verify that the SoM is properly seated on the development board and that all connections are secure. Loose connections can lead to malfunction.
  4. Internal Components: Check the internal components of the SoM, such as the power management IC and memory, for any issues. This includes verifying the functionality of power management and memory.
  5. Firmware: Ensure that the SoM’s firmware is up-to-date and correctly installed, as firmware issues can prevent the system from booting.
If these checks do not resolve the issue, consider replacing the SoM or contacting the manufacturer for further assistance.
Plugging Ethernet cable crashes M7.
