Hello guys,
I’m trying to run my QT Application on the Toradex Verdin Development board and when I run
./myQtApp
I get this error message:
xdg_wm_base@18: error 4: xdg_surface buffer (720 x 1280) is larger than the configured fullscreen state (1024 x 768)
The Wayland connection experienced a fatal error: Protocol error
Is there any way to change the fullscreen state from 1024x768 to 720x1280?
Thanks a lot,
Ruben
Greetings, @rubencz !
Your issue seems to be related to this question, can you please check if your weston.ini is configured correctly? Also, can you please check if your qt application is configured correctly?
For further information about weston.ini configuration, please take a look on the Fixed Display Resolution section on this article.
Felipe Madureira
Hi @felipe.tx ,
Where I can find the weston.ini file?
Ruben
Hello, @rubencz
The weston.ini file could be found in /etc/xdg/weston inside the container. Please let me know in case of any questions
Felipe Madureira
Hi @felipe.tx ,
I don’t container. My application was built on Yocto.
Ruben
Hello, @rubencz !
Sorry for my misunderstanding, but you can also find weston.ini file at /etc/xdg/weston on Yocto as well. Please, let me know in case of any problems
Felipe Madureira
