Is there a copy of Table 3-1 in the Verdin iMX8MM Datasheet that is a text file/spreadsheet, instead of the .PDF? I want to make a Signal Map from the iMX8MM ball to my design’s connectors.
Something like these two?
I quickly put them together, so there might be some mistakes.
To make sure, compare them side-by-side with the PDF version and correct them.
CSV (it’s actually tab separated):
verdin_imx8mm.csv (8.9 KB)
OpenDocument Spreadsheet (LibreOffice):
verdin_imx8mm.ods (19.8 KB)
That work!
Thank you,
Dan
Could you mark an answer that solved your problem as the solution so that this issue can be closed?
Thanks,
MGlolenstine
