Verdin IMX8MM clock/reset sequencing
Hi, we have Verdin IMX8MM V1.1B modules and have an issue with a PCIe bridge (PI7C9X2G404SL) which is attached to the IMX8MM internal PCIe controller.
The PI7C9X2G404SL requires that PERST is de-asserted 100ms after the clock is stable:
However, what we see is: (blue=PERST, yellow=REFCLK)
Is there a way to change the behavior so that clock is stable before PERST is released?
Thanks, Klaus
Hi @klausci !
Could you please share the steps you took to get this strange behavior? So we can try to reproduce it on our side.
We did nothing special. We just powered on the Verdin IMX8MM with Toradex BSP on our carrier board.
We are using Linux with your TDX BSP 5.2.
Anything else you need to know?
Now we checked the behaviour on the verdin development board V1.0B.
The behaviour is in principle the same, BUT the development board has an RC delay (R250/C173) element in the PERST line;
Resulting in these signal waveforms:
Question: Is this RC element needed to work properly?
It is not mentioned in the carrier board design guidelines.
I am still questioning what can cause this wrong behaviour (PERST deasserted before REFCLK stable). Can it be a misconfiguration of the BSP (e.g. devicetree)?
Could you please verify how the signal behaviour is on your side?
The effect of this problem on our side is: On many specimen of our carrier boards, the PCIe Switch works correctly, but on some specimen sometimes the PCIe bus does not come up (PHY link never came up), and on some boards it never comes up. This is a major issue that blocks our board production. Please help.
Hi @klausci!
Thanks for the information.
This issue is currently under investigation and I’ll get back to you as soon as possible.
Hi @klausci !
I could reproduce the issue.
As soon as I have some new information about the issue, I’ll inform you.
Hi @klausci !
We are currently carrying out some tests and I would like to ask you to test the following patch (at the end of this message) for the file drivers/pci/controller/dwc/pci-imx6.c
You can use git apply --ignore-whitespace patch_name to apply the patch at the root of your local linux-toradex repository.
If you need help to build, please refer to the article below
Let us know if with this patch your PCI bridge works.
Also, if possible, send us the output of your oscilloscope for both PERST and the PCI clock.
About the presence of the RC circuit, the time constant of this circuit is around 100ms, which is the delay that is stated on your PCI bridge datasheet. So maybe it would actually behave better if you had the RC circuit. We are still trying to clarify if this is general documentation that should be on our design guide.
The patch:
diff --git a/drivers/pci/controller/dwc/pci-imx6.c b/drivers/pci/controller/dwc/pci-imx6.c
index 663f41df33ab..17cadb2e0c1e 100644
--- a/drivers/pci/controller/dwc/pci-imx6.c
+++ b/drivers/pci/controller/dwc/pci-imx6.c
@@ -1227,10 +1227,6 @@ static int imx6_pcie_deassert_core_reset(struct imx6_pcie *imx6_pcie)
        if (imx6_pcie->reset_gpiod) {
                gpiod_set_value_cansleep(imx6_pcie->reset_gpiod,
                                        !imx6_pcie->gpio_active_high);
-               msleep(100);
-               gpiod_set_value_cansleep(imx6_pcie->reset_gpiod,
-                                       imx6_pcie->gpio_active_high);
-               msleep(20);
        switch (imx6_pcie->drvdata->variant) {
@@ -1403,6 +1399,16 @@ static int imx6_pcie_deassert_core_reset(struct imx6_pcie *imx6_pcie)
                break;
+        /* Make sure we respect the PCIe specification and wait at least 100ms
+         * before talking to the device. At this point we already have the clock
+         * enabled.
+       if (imx6_pcie->reset_gpiod) {
+           msleep(100);
+           gpiod_set_value_cansleep(imx6_pcie->reset_gpiod,
+                           imx6_pcie->gpio_active_high);
        return 0;
 err_pll:
Good to hear. We’ll try it beginning of next week!
Hello @henrique.tx ,
I tried your patch and can confirm that it works. The timing is now correct and it fixed our problem. The PCIe bridge of our carrier board is now detected on all the boards which had problems to bring up the bridge.
For your information. This is the new timing.
Do you plan to integrate this patch in your official BSP? If yes, when?
Thanks and best regards, Klaus
Hi @klausci!
Thanks for the feedback! It is great to know that the patch worked for you.
This issue is already on our backlog, but we do not have an ETA for this at the moment.
Soon the issue will be publicly visible on our issue tracker: Toradex System/Computer on Modules - Linux BSP Release
Hello @klausci,
We have integrated a slightly different patch on our latest kernel version. Could you check if your switch still works with the new release?
Here’s the link to the applied patch:
It should be available in your latest nightly build, that you can get here:
Please let us know if it still works,
Rafael Beims
Hello @rafael.tx,
Sorry for my late reply. At the moment we our using our own yocto image based on BSP 5.2. We’ll test your changes when we migrate to the latest BSP. But this will not happen before summer 2022. Sorry
Hi @klausci.
Ok.
Please let us know the results when you have them :slight_smile:
