Hi Team,
I’m working on building a Yocto image for the Verdin iMX8M Plus using the Toradex BSP 7.3.0+build.8 (scarthgap).
Setup Details:
Host Environment:
- OS: Ubuntu 22.04.5 LTS (WSL2 on Windows 11)
- Kernel:
Linux 5.15.167.4-microsoft-standard-WSL2 - Yocto packages: Installed as per Yocto 5.x system requirements
Target Board:
- Target Board: Verdin-iMX8M Plus
- BSP Version: scarthgap-7.x.y
- Manifest:
tdxref/default.xml
Initial Setup Command:
$ repo init -u git://git.toradex.com/toradex-manifest.git -b scarthgap-7.x.y -m tdxref/default.xml
$ repo sync
$ . export
Edited conf/local.conf:
MACHINE ?= “verdin-imx8mp”
DISTRO ?= “tdx-xwayland”// NXP®/Freescale EULA
ACCEPT_FSL_EULA = “1”
Build Target: bitbake -k tdx-reference-multimedia-image
Problem: uninative Fetch Fails Mid-Build
The build proceeds to around 45–50%, then fails with 404 errors while fetching uninative components and then it fails with this error:
hari@Administrator:~/oe-core/build$ cat bitbake-cookerdaemon.log
1450 16:49:40.900309 --- Starting bitbake server pid 1450 at 2025-08-06 16:49:40.900288 ---
1450 16:49:40.902846 Started bitbake server pid 1450
1450 16:49:40.903015 Entering server connection loop
1450 16:49:40.903031 Lockfile is: /home/hari/oe-core/build/bitbake.lock
Socket is /home/hari/oe-core/build/bitbake.sock (True)
1450 16:49:40.903295 Accepting [<socket.socket fd=6, family=AddressFamily.AF_UNIX, type=SocketKind.SOCK_STREAM, proto=0, laddr=bitbake.sock>] ([])
1450 16:49:40.903765 Processing Client
1450 16:49:40.903790 Connecting Client
1450 16:49:40.903943 Running command ['setFeatures', [2, 1]]
1450 16:49:40.903963 Sending reply (None, None)
1450 16:49:40.904008 Command Completed (socket: True)
1450 16:49:40.904538 Running command ['updateConfig', {'halt': False, 'force': False, 'invalidate_stamp': None, 'dry_run': False, 'dump_signatures': [], 'extra_assume_provided': [], 'profile': False, 'prefile': [], 'postfile': [], 'server_timeout': None, 'nosetscene': False, 'setsceneonly': False, 'skipsetscene': False, 'runall': [], 'runonly': None, 'writeeventlog': None, 'build_verbose_shell': False, 'build_verbose_stdout': False, 'default_loglevel': 20, 'debug_domains': {}}, {'SHELL': '/bin/bash', 'BB_ENV_PASSTHROUGH_ADDITIONS': 'ALL_PROXY BBPATH_EXTRA BB_LOGCONFIG BB_NO_NETWORK BB_NUMBER_THREADS BB_SETSCENE_ENFORCE BB_SRCREV_POLICY DISTRO FTPS_PROXY FTP_PROXY GIT_PROXY_COMMAND HTTPS_PROXY HTTP_PROXY MACHINE NO_PROXY PARALLEL_MAKE SCREENDIR SDKMACHINE SOCKS5_PASSWD SOCKS5_USER SSH_AGENT_PID SSH_AUTH_SOCK STAMPS_DIR TCLIBC TCMODE all_proxy ftp_proxy ftps_proxy http_proxy https_proxy no_proxy ', 'PWD': '/home/hari/oe-core', 'LOGNAME': 'hari', 'HOME': '/home/hari', 'BBPATH': '/home/hari/oe-core/build', 'USER': 'hari', 'PATH': '/home/hari/oe-core/layers/openembedded-core/scripts:/home/hari/oe-core/layers/openembedded-core/bitbake/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/usr/lib/wsl/lib:/mnt/c/Windows/system32:/mnt/c/Windows:/mnt/c/Windows/System32/Wbem:/mnt/c/Windows/System32/WindowsPowerShell/v1.0/:/mnt/c/Windows/System32/OpenSSH/:/mnt/c/Program Files/dotnet/:/mnt/c/SysGCC/raspberry64/bin:/mnt/c/Program Files/Git/cmd:/mnt/c/Windows/system32:/mnt/c/Windows:/mnt/c/Windows/System32/Wbem:/mnt/c/Windows/System32/WindowsPowerShell/v1.0/:/mnt/c/Windows/System32/OpenSSH/:/mnt/c/Program Files/dotnet/:/mnt/c/Users/Hariprabhu/.cargo/bin:/mnt/c/Users/Hariprabhu/AppData/Local/Programs/Eclipse Adoptium/jdk-21.0.6.7-hotspot/bin:/mnt/c/Users/Hariprabhu/AppData/Local/Microsoft/WindowsApps:/mnt/c/Users/Hariprabhu/AppData/Local/Programs/Microsoft VS Code/bin:/mnt/c/Users/Hariprabhu/.dotnet/tools:/mnt/c/Users/Hariprabhu/AppData/Roaming/Code/User/globalStorage/github.copilot-chat/debugCommand:/mnt/c/Users/Hariprabhu/AppData/Roaming/Code/User/globalStorage/github.copilot-chat/debugCommand:/mnt/c/SysGCC/raspberry64/bin:/mnt/c/Program Files (x86)/Nmap:/snap/bin', 'LC_ALL': 'en_US.UTF-8', 'WSL2_GUI_APPS_ENABLED': '1', 'OE_ADDED_PATHS': '/home/hari/oe-core/layers/openembedded-core/scripts:/home/hari/oe-core/layers/openembedded-core/bitbake/bin:', 'WSL_DISTRO_NAME': 'Ubuntu-22.04', 'WT_SESSION': 'a8ae4d63-4c73-469b-8408-3080eec113dc', 'NAME': 'Administrator', 'LANG': 'C.UTF-8', 'WSL_INTEROP': '/run/WSL/1383_interop', 'WAYLAND_DISPLAY': 'wayland-0', 'PYTHONPATH': '/home/hari/oe-core/layers/openembedded-core/bitbake/lib:', 'TERM': 'xterm-256color', 'DISPLAY': ':0', 'SHLVL': '1', 'XDG_RUNTIME_DIR': '/run/user/1000/', 'WSLENV': 'WT_SESSION:WT_PROFILE_ID:', 'XDG_DATA_DIRS': '/usr/local/share:/usr/share:/var/lib/snapd/desktop', 'DBUS_SESSION_BUS_ADDRESS': 'unix:path=/run/user/1000/bus', 'BUILDDIR': '/home/hari/oe-core/build', 'HOSTTYPE': 'x86_64', 'PULSE_SERVER': 'unix:/mnt/wslg/PulseServer', 'WT_PROFILE_ID': '{4ff56d04-d9cf-57ea-bae2-ad396374e7e3}', 'OLDPWD': '/home/hari/oe-core/build', '_': '/home/hari/oe-core/layers/openembedded-core/bitbake/bin/bitbake'}, ['/home/hari/oe-core/layers/openembedded-core/bitbake/bin/bitbake', '-k', 'tdx-reference-multimedia-image']]
1450 16:49:41.600162 Base config valid
1450 16:49:41.690963 Sending reply (None, None)
1450 16:49:41.691122 Command Completed (socket: True)
1450 16:49:41.691520 Running command ['getVariable', 'BBINCLUDELOGS']
1450 16:49:41.691650 Sending reply ('yes', None)
1450 16:49:41.691703 Command Completed (socket: True)
1450 16:49:41.691931 Running command ['getVariable', 'BBINCLUDELOGS_LINES']
1450 16:49:41.691970 Sending reply (None, None)
1450 16:49:41.692020 Command Completed (socket: True)
1450 16:49:41.692229 Running command ['getSetVariable', 'BB_CONSOLELOG']
1450 16:49:41.692331 Sending reply ('/home/hari/oe-core/build/tmp/log/cooker/verdin-imx8mp/20250806111941.log', None)
1450 16:49:41.692387 Command Completed (socket: True)
1450 16:49:41.692600 Running command ['getSetVariable', 'BB_LOGCONFIG']
1450 16:49:41.692639 Sending reply (None, None)
1450 16:49:41.692688 Command Completed (socket: True)
1450 16:49:41.696531 Running command ['getUIHandlerNum']
1450 16:49:41.696605 Sending reply (1, None)
1450 16:49:41.696655 Command Completed (socket: True)
1450 16:49:41.696891 Running command ['setEventMask', 1, 20, {'BitBake.SigGen.HashEquiv': 19, 'BitBake.RunQueue.HashEquiv': 19}, ['bb.runqueue.runQueueExitWait', 'bb.event.LogExecTTY', 'logging.LogRecord', 'bb.build.TaskFailed', 'bb.build.TaskBase', 'bb.event.ParseStarted', 'bb.event.ParseProgress', 'bb.event.ParseCompleted', 'bb.event.CacheLoadStarted', 'bb.event.CacheLoadProgress', 'bb.event.CacheLoadCompleted', 'bb.command.CommandFailed', 'bb.command.CommandExit', 'bb.command.CommandCompleted', 'bb.cooker.CookerExit', 'bb.event.MultipleProviders', 'bb.event.NoProvider', 'bb.runqueue.sceneQueueTaskStarted', 'bb.runqueue.runQueueTaskStarted', 'bb.runqueue.runQueueTaskFailed', 'bb.runqueue.sceneQueueTaskFailed', 'bb.event.BuildBase', 'bb.build.TaskStarted', 'bb.build.TaskSucceeded', 'bb.build.TaskFailedSilent', 'bb.build.TaskProgress', 'bb.event.ProcessStarted', 'bb.event.ProcessProgress', 'bb.event.ProcessFinished']]
1450 16:49:41.696922 Sending reply (True, None)
1450 16:49:41.696971 Command Completed (socket: True)
1450 16:49:41.697181 Running command ['getVariable', 'BB_DEFAULT_TASK']
1450 16:49:41.697219 Sending reply ('build', None)
1450 16:49:41.697268 Command Completed (socket: True)
1450 16:49:41.697480 Running command ['setConfig', 'cmd', 'build']
1450 16:49:41.697502 Sending reply (None, None)
1450 16:49:41.697548 Command Completed (socket: True)
1450 16:49:41.697787 Running command ['buildTargets', ['tdx-reference-multimedia-image'], 'build']
1450 16:49:41.697842 Registering idle function <bound method Command.runAsyncCommand of <bb.command.Command object at 0x7f92ecbfba60>>
1450 16:49:41.697849 Sending reply (True, None)
1450 16:49:41.697893 Command Completed (socket: True)
1450 16:49:41.715304 Parsing started
1450 16:49:43.222794 Parse cache valid
--2025-08-06 16:51:16-- https://artifacts.toradex.com/artifactory/tdxref-torizoncore-sources-frankfurt/7/x86_64-nativesdk-libc-4.7.tar.xz
Resolving artifacts.toradex.com (artifacts.toradex.com)... 3.125.132.142
Connecting to artifacts.toradex.com (artifacts.toradex.com)|3.125.132.142|:443... connected.
HTTP request sent, awaiting response... 404
2025-08-06 16:51:16 ERROR 404: (no description).
--2025-08-06 16:51:16-- https://artifacts.toradex.com/artifactory/tdxref-torizoncore-sources-frankfurt/7/uninative/5800d4e9a129d1be09cf548918d25f74e91a7c1193ae5239d5b0c9246c486d2c/x86_64-nativesdk-libc-4.7.tar.xz
2025-08-06 16:51:17 ERROR 404: (no description).
--2025-08-06 16:51:17-- http://downloads.yoctoproject.org/releases/uninative/4.7/x86_64-nativesdk-libc-4.7.tar.xz
Resolving downloads.yoctoproject.org (downloads.yoctoproject.org)... 37.27.135.249, 2a01:4f9:3070:3985::2
Connecting to downloads.yoctoproject.org (downloads.yoctoproject.org)|37.27.135.249|:80... connected.
HTTP request sent, awaiting response... 200 OK
Length: 7038984 (6.7M) [application/octet-stream]
Saving to: ‘/home/hari/oe-core/downloads/uninative/5800d4e9a129d1be09cf548918d25f74e91a7c1193ae5239d5b0c9246c486d2c/x86_64-nativesdk-libc-4.7.tar.xz.tmp’
2025-08-06 16:51:26 (851 KB/s) - ‘/home/hari/oe-core/downloads/uninative/5800d4e9a129d1be09cf548918d25f74e91a7c1193ae5239d5b0c9246c486d2c/x86_64-nativesdk-libc-4.7.tar.xz.tmp’ saved [7038984/7038984]
Server refused shutdown. Remaining client fds: 1
Client pids: 360086
Server will shut down after all clients exit.
Client pids: 360075
Client pids: 783861
Client pids: 800339
Client pids: 809047
I have attached the full bitbake error log in the topic,
Questions:
- Why is
uninativefailing to fetch from the Toradex Artifactory? - Is the URL deprecated or temporarily down?
- Is there a way to override or mirror the uninative source?
Summary
- Targeting Verdin iMX8M Plus with
scarthgap-7.x.yBSP andtdx-reference-multimedia-imagebuild. - Build consistently fails while fetching
uninativedue to 404 error from Toradex Artifactory. - Running build inside WSL2 (Ubuntu 22.04 on Windows 11).
conf/local.confcorrectly set with machine, distro, and EULA acceptance.- Need guidance on:
- Whether this is a known issue or temporary server problem.
- How to manually override/unset uninative, if it’s optional.
- If a mirror or alternate source can be configured.
