Thank you for the additional details and oscilloscope captures. Your measurements confirm VCC remains well above the 3.135V minimum threshold during switching, which rules out voltage sag as the trigger.
Analysis of Your Specific Issue
Based on your scope traces showing clean VCC transitions, the problem likely stems from the internal pulse generator circuit on the module. This circuit is designed to generate a power button press when VCC is first applied(1), but it may be sensitive to the rate of voltage change or transient characteristics during your super capacitor switching—even when absolute voltage levels remain valid.
Regarding CTRL_PWR_EN_MOCI (Pin 214)
You’re correct that pin 214 (CTRL_PWR_EN_MOCI) is a module output, not an input you can directly control from the carrier board(2). This signal is controlled by the module’s PMIC and SoC to enable carrier board peripheral power rails(2). I apologize for the confusion in my previous response—you cannot de-assert this signal from the carrier board side.
Root Cause Hypothesis
Since your VCC remains stable and pin 248 is not connected, the issue likely involves:
- PMIC sensitivity to dV/dt: The PCA9450C PMIC may interpret the transient characteristics of your power source switching as a power interruption event, even though voltage levels remain valid
- Internal pulse generator triggering: The pulse generator circuit may be responding to characteristics of the switching event that aren’t visible as simple voltage drops
Potential Solutions
1. CTRL_FORCE_OFF_MOCI# Signal Behavior
The CTRL_FORCE_OFF_MOCI# signal (pin 250) is designed to kill the main power rail and includes a ~1.5 second delay after PMIC power-off to prevent false triggers during reset cycles(1). However, this signal is an output from the module.
If your carrier board’s power switching circuit is monitoring or responding to this signal, ensure it ignores CTRL_FORCE_OFF_MOCI# transitions during your controlled power source switching.
2. VCC Input Capacitance
While your scope shows stable voltage, ensure you have sufficient bulk capacitance directly at the module’s VCC pins (251, 253, 255, 257, 259)(2). The datasheet recommends using decoupling capacitors on the carrier board(2). During super capacitor switching, additional bulk capacitance (e.g., 100µF-470µF ceramic or low-ESR electrolytic) placed very close to the module connector may help dampen any high-frequency transients not visible on your scope.
3. Pin 248 Floating vs. Defined State
You mentioned pin 248 is not connected. The module has an internal 100k pull-up to the 1.8V SNVS rail(2). Leaving it floating is acceptable per the datasheet(2), but during power transitions, electromagnetic coupling or board-level noise could induce transients on this high-impedance input.
Instead of adding external pullups (which you’ve found problematic), consider:
- Short, direct trace from pin 248 to a nearby GND via a 100nF capacitor to provide AC coupling to ground while maintaining the DC floating state
- This filters high-frequency noise without fighting the internal pull-up or pulse generator circuit
4. CTRL_RESET_MICO# (Pin 260) Behavior
You mentioned adding a pullup to pin 260 interfered with reset functionality. This is expected—pin 260 has an internal 100k pull-up to the 1.8V SNVS rail(2) and connects to the PMIC_RST_B input of the PCA9450C PMIC(2). When pulled low, it triggers a complete power-down followed by power-up sequence(2).
Do not add external pullups to pin 260. Leave it floating as designed(2).
Additional Diagnostic Steps
Since you’ve removed tdx-info and other diagnostic tools, could you clarify:
What is the exact behavior? Does the module:
- Completely power down and require manual restart?
- Automatically reboot after the switching event?
- Enter a halted state requiring power cycle?
Timing: Does the issue occur:
- Immediately during the switch?
- Within a specific time window after switching?
- Randomly during or after switching?
Super Capacitor Switching Method: Are you using:
- Ideal diodes / ORing MOSFETs?
- Mechanical relays?
- Solid-state switches?
Understanding these details will help identify whether the issue is related to switching transients, PMIC state machine behavior, or electromagnetic interference during the transition.
Hardware Filtering Recommendation
Based on the Apalis Carrier Board Design Guide principles(3), ensure your power switching circuit minimizes any potential backfeeding or reverse current paths during transitions. Even brief reverse currents through body diodes or protection circuits can create voltage perturbations that trigger the PMIC’s protection mechanisms.
