I was wondering about the steps that would be necessary to integrate a monochrome RAW image sensor with the Verdin IMX8M Plus?
In theory, as the image is mono (8bit or 10bit), there would not be any processing (de-beyering) necessary.
But recently I read that the ISI of the IMX8 family does not support RAW8 formats, even if they bypass the format conversion (CSC). See here:
(the link is on the Toradex Apalis, but afaik the IMX8M Plus has the same ISI)
In theory one could use the ISP for this purpose, but there I cannot find any reference code on how to setup and use the ISP on the Verdin IMX8 Plus.
Also it seems like and overkill, as for monochrome there is anyways no processing required.
What would you do for interfacing RAW8/RAW10 monochrome camera with this board?
Thank you for contacting Toradex by using our community.
We are currently looking into your question.
As you correctly stated, there is no need of using the ISP on a mono image. We are looking at the situation with the RAW8 format. Unfortunately the openly available information about the ISP is very limited.
Our team is currently working on some reference code samples to provide for setting up the ISP. This is still work in progress.
I will reach out to you again as soon as possible.
Thanks for your patience. Just to provide you an update. We are still working on this issue.
Did anything change from your side?
Which sensor do you intend to use?
What is your application?
It is exactly the same requirement. We would like to directly use the ISP of the iMX8M Plus to process the RAW8 OV9281 output, as the ISI is only supporting 16bit.
You were mentioning that you are working on some reference code half a year ago. What is the status there? Would be great to get some support here.
The team is aware and we’re giving our best to provide a solution as soon as possible. We are waiting for certain components to be finished by our partners on our end. So as these become available we will be able to update you guys here.
