Please confirm current consumption of Verdin iMX8M Plus QuadLite 1GB IT SOM on 25 deg C and -40 to 85 deg C.
Parimal
Parimal
Based on the power consumption testing for the Verdin iMX8M Plus QuadLite 1GB IT V1.1A, here are the measured power consumption values(1):
| Test Case | Mean Power Consumption [W] | Peak Power Consumption [W] |
| Poweroff state | - | 0.00 |
| Suspend mode idle | 0.10 | 0.40 |
| Idling mode without screen and without eth | 1.34 | 2.43 |
| Idling mode without screen and with eth | 2.11 | 3.54 |
| Idling mode with screen and without eth | 1.58 | 3.25 |
| Idling mode with screen and with eth | 2.32 | 3.93 |
| Stress 1 core(s) without screen | 2.39 | 3.69 |
| Stress 2 core(s) | 2.87 | 4.51 |
| Stress 3 core(s) | 3.13 | 4.70 |
| Stress 4 core(s) | 3.40 | 4.75 |
| Max stress: all cores stressed, glmark2, iperf3 and ethernet | 4.17 | 6.07 |
| CPU neon stress script | 4.41 | 5.61 |
The measurements were conducted using(1):
The Verdin iMX8M Plus QuadLite 1GB IT is designed for Industrial Temperature (IT) range operation, which covers -40°C to +85°C(2). The module incorporates DVFS (Dynamic Voltage and Frequency Scaling) and Thermal Throttling to continuously adjust operating frequency and voltage based on workload and temperature changes(3).
