The context provided indicates that there is an inquiry about the UL certification requirements for the Verdin iMX8M Plus and Mallow Carrier Board. Here are the key points to consider:
Certification Requirements: It is not explicitly stated in the datasheet whether these components require individual UL certification. Therefore, it is crucial to determine if they need to be certified individually or if they are covered under the overall device certification.
Consultation with Experts: It is advisable to consult with UL representatives or certification experts to clarify the specific requirements for these components. They can provide guidance on whether individual certification is necessary or if the overall device certification suffices.
Documentation Review: Since the datasheet does not provide explicit UL certification details, further inquiry with Toradex or a certification body may be necessary to clarify the certification status of the boards.
UL94 Compliance: The mention of UL94 indicates that the materials used in the boards have been tested for flammability, but this does not confirm full UL certification for the entire assembly or its components.
In conclusion, to ensure compliance and safety, it is recommended to verify the certification requirements for the Verdin iMX8M Plus and Mallow Carrier Board with Toradex or relevant certification bodies. This will provide clarity on whether these components need to be certified individually or if they are included in the overall device certification process.
