verdin imx8m-plus, For production reasons, we would like to create an image with the contents of the module to clone it quickly.
Is there any software that can do this? It would be like the inverse function of the “Tezi”
Hello! Thank you for your question.
Currently, the Toradex Easy Installer (TEZI) is specifically designed to deploy images to the module, but there isn’t a documented, official Toradex tool that performs the inverse operation, i.e., creating a complete backup or image of a module’s contents for rapid cloning purposes(1). This functionality—“imaging out”—is not provided as a standard function in the Toradex workflow.
However, for production cloning, you generally have these options:
Manual Image Creation (Linux Tools):
- You can use Linux commands such as
ddto capture the contents of the eMMC storage on the Verdin iMX8M Plus. You would boot the module into a Linux environment (for example, using a minimal Linux from an SD card or USB) and useddto create a binary image of the storage. - Example:
Replacedd if=/dev/mmcblk0 of=/media/sdcard/backup.img bs=1M/dev/mmcblk0with the correct storage device and/media/sdcard/backup.imgwith your desired path. - This needs to be done with care, as it will include all partitions and raw data from the module.
Scripted Backup & Restore:
- For more flexibility, you could script the backup and restoration process of individual partitions (boot, rootfs, etc.) using
ddor filesystem-aware tools liketar. - This approach lets you restore to new hardware using the same tools or via a custom TEZI image.
Custom Easy Installer Image:
- After creating a backup as above, you can package it as an image compatible with the Toradex Easy Installer, making redeployment to many devices straightforward. Documentation for creating custom images for TEZI is available(2).
A few important notes:
- Make sure the module is not in use (not running the rootfs you’re imaging) or use an external Linux environment to avoid inconsistencies.
- Large storage devices may take time and result in large image files.
Please let me know if you’d like detailed instructions for one of these approaches!
Hello @mdmeoqui !
Could you please let me know which operating system you are using in your product?
If you’re working with Torizon OS, you can generate a new TEZI image using the TorizonCore Builder. This tool offers a very helpful command called isolate, which allows you to extract the current configuration from /etc on your device. Additionally, you can customize other elements of your image, such as device tree overlays, kernel modules, and your final application.
Ideally, using dd to clone the image is not recommended, since this method only gives you the final binary. For long-term maintenance and flexibility, it’s best to have the source and configuration under version control. This way, you can easily make adjustments and maintain your image throughout the product’s lifecycle.
Feel free to reach out if you have any questions or need further assistance.
Daniel, Marcelo Meoqui from Electrónica Naval s.a / Seaman Electronics s.a, responding what OS do we use?. The company already had a version of Ubuntu Server that was used in other products and for cost and administrative reasons it was decided to continue with it, now the product is already working and we are interested in speeding up production.
Regarding OS maintenance, in our case it is practically not necessary, except in the case that the product breaks.
This is because the final product fulfills a very specific function that does not require updates to the OS.
If you have a developed option that can solve the creation of an image to easily clone the disk, it would be perfect for the production of this product.
Thank you very much for your email.
Marcelo D Meoqui
Hi @mdmeoqui ,
Thanks for your detailed response!
Just to confirm, are you running Ubuntu Server directly on our hardware? And do you still have any components from our software stack, such as U-Boot or the BSP?
If you still have U-Boot available, you could use the ums command ums (USB Mass Storage) to expose the eMMC as a USB drive to a host machine through the OTG port. This method is described in this article, and it allows you to clone the eMMC content and replicate it across devices efficiently.
However, if your image no longer includes U-Boot or does not retain compatibility with it, unfortunately, there may not be an easy solution for disk cloning that I can offer at this point.
Please let me know if I can assist with anything.
Daniel Morais
