is the u-boot toradex_imx_v2020.04_5.4.70_2.3.0 compatible with the linux toradex_5.15-2.2.x-imx ?
where can i find the compabilities between u-boot and linux source code for the Verdin iMX8M Mini ?
Based on the documentation, the Embedded Linux Release Matrix is the definitive source for finding compatible U-Boot and Linux versions for Verdin iMX8M Mini(1).
The Embedded Linux Release Matrix provides comprehensive compatibility information showing which U-Boot versions work with specific Linux kernel versions for each BSP release(1).
For Verdin iMX8M Mini, the documentation shows these combinations(1):
The versions you mentioned (toradex_imx_v2020.04_5.4.70_2.3.0 U-Boot and toradex_5.15-2.2.x-imx Linux) appear to be from different BSP generations. For Verdin iMX8M Mini, the current supported combinations use upstream U-Boot versions rather than downstream i.MX versions(2)(1).
For Verdin iMX8M Mini, the modules use upstream U-Boot version with the verdin-imx8mm_defconfig configuration(3). The documentation indicates that these modules follow the upstream U-Boot documentation at docs.u-boot.org(2).
Hi @Eliasm!
Did the answer from Toradex AI solve your doubt? May I consider this topic solved?
Best regards.
