Verdin iMX8M Mini – RS485 RX issues and SC16IS762 IRQ instability on custom carrier board
Hello Toradex Support Team,
I am working with a custom carrier board based on the Ivy Carrier Board V1.1, using the Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT (No CAN) V1.1A module.
Hardware Modifications
I made the following modifications compared to the Ivy carrier:
  1. Converted the RS232 interface to RS485:
    • Using SN65176BDR transceivers
    • Isolation via ISO6721RBDR
    • Similar topology to the existing RS485 design on the Ivy carrier
  2. Added an external SPI UART:
    • SC16IS762IPW connected via ECSPI3 (SPI3)
    • Two RS485 transceivers (SN65HVD72DR) connected to the SC16 UART channels
Issues Observed
1. RS485 Communication (SN65176BDR)
  • TX works correctly
  • RX does not work reliably
  • Received data appears as garbage / corrupted
This happens on both RS485 channels.
2. SC16IS762 Interrupt Issue
  • The interrupt line (connected to GPIO5_IO3 / SPDIF_TX pin) appears unstable
  • The IRQ is continuously firing
  • System shows high CPU usage:
irq/168-spi2.0 ~95-100% CPU
  • This suggests an interrupt storm or incorrect IRQ configuration
Device Tree Configuration
Below is the relevant device tree configuration:
/* ---------------- PINCTRL ---------------- */
&iomuxc {
	pinctrl_sc16is762_int: sc16is762-int {
		fsl,pins =
			<MX8MM_IOMUXC_SPDIF_TX_GPIO5_IO3 0x140>; /* GPIO for SC16IS762 interrupt */
	pinctrl_ecspi3: ecspi3grp {
		fsl,pins =
			<MX8MM_IOMUXC_UART1_RXD_ECSPI3_SCLK 0x6>,
			<MX8MM_IOMUXC_UART1_TXD_ECSPI3_MOSI 0x6>,
			<MX8MM_IOMUXC_UART2_RXD_ECSPI3_MISO 0x6>,
			<MX8MM_IOMUXC_UART2_TXD_GPIO5_IO25 0x6>;
/* ---------------- SPI3 + SC16IS762 ---------------- */
&ecspi3 {
    #address-cells = <1>;
    #size-cells = <0>;
    cs-gpios = <&gpio5 25 GPIO_ACTIVE_LOW>;
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_ecspi3 &pinctrl_sc16is762_int>;
    sc16is762: uart@0 {
        compatible = "nxp,sc16is762";
        reg = <0>;
        spi-max-frequency = <1000000>;
        clocks = <&sc16is762_clk>;
        interrupt-parent = <&gpio5>;
        interrupts = <3 IRQ_TYPE_LEVEL_LOW>;
        linux,rs485-enabled-at-boot-time;
        rs485-rts-active-low;
        rs485-rts-delay = <1 0>;
Additional Observations
  • The SC16IS762 driver loads correctly:
    • /dev/ttySC0 and /dev/ttySC1 are created
  • dmesg shows:
    spi2.0: ttySC0 ... is a SC16IS762
    spi2.0: ttySC1 ... is a SC16IS762
  • However:
    • IRQ appears constantly active
    • GPIO debug shows the pin as “GPIO UNCLAIMED”
I have attached images of the relevant schematic sections for:
  • RS485 implementation (SN65176BDR + ISO6721RBDR)
  • SC16IS762 + SPI + interrupt connection
I can also provide the full schematic PDF if needed.
Questions
  1. Is the pin configuration for GPIO5_IO3 (SPDIF_TX) correct for use as an interrupt input?
  2. What is the recommended pad configuration (pull-up/down) for SC16IS762 IRQ on i.MX8MM?
  3. Could the IRQ storm be caused by incorrect pinmux or missing bias configuration?
  4. Are there any known requirements or constraints when using ECSPI3 (SPI3) on Verdin iMX8M Mini without CAN?
  5. For RS485:
    • Are there known issues when converting RS232 to RS485 using SN65176BDR on this platform?
    • Could incorrect DE/RE control or polarity cause RX corruption?
Summary
  • RS485 TX works, RX is corrupted
  • SC16IS762 IRQ is unstable and causes high CPU usage
  • Suspecting GPIO/pinctrl or hardware biasing issue
Any guidance on validating the interrupt configuration and RS485 design would be greatly appreciated.
Alvaro Jimenez
I’d be glad to help with your RS485 and SC16IS762 issues! To provide the most accurate guidance, could you let me know which OS and version you are running on your Verdin iMX8M Mini? For example:
  • Hardware: Verdin iMX8M Mini Quad 2GB Wi-Fi / Bluetooth IT (No CAN) V1.1A
  • OS: Torizon OS 6.8.2, Torizon OS 7.2.0-build.13, Yocto BSP 7, etc.
You can get detailed information about your setup using the tdx-info command - see this guide for more details.
Initial Analysis of Your Issues
Based on the information provided, I can see you’re experiencing:
  1. RS485 RX corruption despite working TX
  2. SC16IS762 interrupt storm causing high CPU usage
RS485 Configuration Insights
From the community discussion on a similar setup (1), there are some key considerations for RS485 on Verdin iMX8M Mini:
Device Tree RS485 Settings
For proper RS485 operation, the device tree configuration should include proper direction control (1):
&uart3 {
    rs485-rts-active-low; // Adjust polarity as required by your board
    // Remove rs485-rx-during-tx; to suppress echo
Echo Suppression
The documentation indicates that RS485 can echo transmissions if the transceiver’s receive line is enabled during transmission (1). The rs485-rx-during-tx property should be removed unless you specifically need to receive while transmitting, as this enables loopback (echo) (1).
Device Tree Overlay Considerations
When working with custom pin configurations, the device tree overlay approach is recommended (2). Your pin multiplexing configuration needs to ensure:
  1. Proper pin function assignment
  2. Correct pad configuration values
  3. No conflicting peripheral usage
Once you provide your OS version, I can give you more specific guidance on:
  • Proper interrupt configuration for SC16IS762
  • Recommended pad settings for GPIO5_IO3
  • RS485 direction control validation
  • SPI3 configuration specifics for your platform
Yes for RS485 Communication (SN65176BDR – Native UARTs)
This occurs on the native UART interfaces.
For reference, I enabled RS485 in the device tree as follows:
&uart3 {
    // rs485-rx-during-tx;
Based on your RS485 configuration and the fact that TX works but RX is corrupted, this suggests a direction control timing or polarity issue. Let me help you troubleshoot this systematically.
RS485 Direction Control Analysis
Your device tree configuration looks correct for basic RS485 operation(1). However, there are several factors that could cause RX corruption:
1. RTS Polarity Verification
The rs485-rts-active-low setting assumes your transceiver’s DE (Driver Enable) pin is active when RTS is low(1). For the SN65176BDR, verify that:
  • DE pin is connected to RTS signal
  • RE# (Receiver Enable) pin is connected to inverted RTS or separate control
  • The polarity matches your hardware design
2. Missing RTS Delay Configuration
The i.MX 8M Mini UART supports RTS delay timing, which can be crucial for proper RS485 operation(1). Try adding delay configuration:
&uart3 {
    rs485-rts-delay = <1 1>; /* pre-delay, post-delay in milliseconds */
3. Hardware Verification Steps
According to the documentation, the i.MX 8M Mini UART block has built-in support for RS-485 auto RTS for controlling the direction of the RS-485 transceiver(1). However, you should verify:
  1. Signal integrity: Use an oscilloscope to check:
    • RTS signal transitions properly during TX/RX
    • Data signal quality on the RS485 bus
    • Timing between RTS assertion and data transmission
  2. Transceiver configuration: Ensure the SN65176BDR is properly configured for half-duplex operation
4. Alternative Configuration Method
If device tree configuration doesn’t resolve the issue, you can enable RS-485 using ioctl from userspace(1). The documentation references this approach for troubleshooting.
Additional Considerations
Since you mentioned this is based on the Ivy Carrier Board design, ensure that:
  • Your custom PCB maintains the same signal routing and termination
  • Power supply decoupling is adequate for the transceivers
  • Ground planes are properly designed to minimize noise
Could you also confirm which OS version you’re running? This will help me provide more specific guidance for your platform configuration.
I’m more worry about this SC16IS762 Interrupt Issue
Random tidbit but we’ve seen this with that SPI-to-UART bridge in the past on our hardware. The driver doesn’t seem to set itself up as an edge triggered IRQ, so if the line is stuck low, it will constantly fire the IRQ and consume a CPU core in the process. I would confirm with a meter or other means the state of the IRQ line - this will point to whether it’s a HW/config/pinmux issue (line is actually stuck low or something is constantly generating interrupts from the bridge) or a SW issue (line value is deasserted but system thinks otherwise)
@AYJF
Let’s avoid mixing multiple topics and debug the issue step by step.
I suggest we first focus on the SC16IS762 and test it as a basic UART, without connecting the RS485 transceivers. For this initial test, you can use a simple loopback connection to another free UART on the Verdin module, or to a USB-to-serial adapter connected to your development machine.
Could you please also provide higher-quality schematic snippets? The current ones are difficult to read, especially the signal names and component pin labels. Please include the relevant connections between the SC16IS762 and the Verdin module so we can clearly see how SPI, chip select, interrupt, reset, clock, and UART signals are routed.
Regarding the interrupt storm issue:
Since the interrupt is connected to the SPDIF_TX pad, please make sure the pad is configured as GPIO, not as S/PDIF or another alternate function.
The pinctrl entry should be similar in concept to:
pinctrl_sc16is762_int: sc16is762intgrp {
     fsl,pins = <
		MX8MM_IOMUXC_SPDIF_TX_GPIO5_IO3 0x1c4
Please also check the behavior of the SC16IS762 INT pin using oscilloscope.
As a debug step, you can temporarily remove the interrupt-parent and interrupts properties from the SC16IS762 node and check whether the high CPU usage disappears. You can also try IRQ_TYPE_EDGE_FALLING instead of IRQ_TYPE_LEVEL_LOW for testing.
Once the SC16IS762 UART functionality will be fixed, we can continue debugging the RS485-related issues separately.
@alex.tx Thank you very much. I will follow your suggestions step by step and will get back to you as soon as possible. In the meantime, I have attached the complete schematics PDF for your reference.
46806005 - Ivy_compressed_removed.pdf (1.6 MB)
Michael Park The schematic looks OK. I asked for a higher-quality version just to better understand its functionality.
I have suggested some initial debugging steps to the customer. Let’s wait for their response.
Alexander Samutin
Toradex
Senior Field Application Engineer
Measured DC voltages, at idle, with chip awake (port held open via exec 3<>/dev/ttySC0):
Pin / Net Voltage Expected for healthy RS-485 idle
SC16IS762 INT (3V3 side) 0.3 – 0.9 V ~3.3 V
SC16IS762 RTSA 3.3 V ~0 V (so DE LOW = driver disabled, /RE LOW = receiver enabled)
SN65HVD72 /RE (pin 2) 3.3 V ~0 V
Level shifter U26 A1 → SoC GPIO5_IO3 0 V (correctly tracking chip INT) ~1.8 V
The SC16IS762’s RTS pin sits at the chip’s reset default (MCR[1] = 0 → RTS deasserted = HIGH). With /RE HIGH, the SN65HVD72 receiver is disabled; its R output is tri-stated and drifts to ~2.2 V, which crosses the SC16IS762 VIH threshold (~2.0 V at VDD=3.3 V) intermittently. The chip latches these as UART RX edges and continuously asserts INT for RX-data / line-status sources. The IRQ thread cannot clear them faster than they re-arrive.
What we’ve ruled out
Hardware/PCB
  • Lift test on U26 pin 2 (level-shifter output → SODIMM 16): with pin 2 lifted, the SoC-side pad measures 1.79 V (internal pull-up unopposed) and GPIO5 PSR bit 3 reads HIGH. The PCB trace and SoC pad are healthy.
  • U26 itself is healthy: VCCA = 1.80 V, VCCB = 3.30 V, DIR = 0.00 V, GND = 0.00 V. Correctly translates B1→A1.
  • 1 kΩ pull-up on SC16IS762 INT matches NXP recommendation.
DT / Pinmux
  • Pinmux registers verified by direct mmap read of IOMUXC:
    • SW_MUX_CTL_PAD_SPDIF_TX = 0x5 (ALT5 = GPIO5_IO3) ✓
    • SW_PAD_CTL_PAD_SPDIF_TX = 0x1C6 (pull-up + hysteresis enabled) ✓
  • GPIO5 GDIR bit 3 = 0 (input) ✓
  • The three RS-485 DT properties are visible in /proc/device-tree/.../uart@0/
@AYJF
Before we start debugging the RS485 transceiver issue can you confirm that related UART work as expected and you have no more problem with the high CPU usage?
Hey @AYJF ,
Did you find a way forward here?
