Verdin iMX8M Mini, GStreamer error when opening vpuenc_h264
Hello!
I’m using i.MX8M Mini with “BSP 7 Downstream Linux Reference Multimedia” (7.1.0+build.3) image.
When I ran the following GStreamer pipeline with VPU encoder element(vpuenc_h264):
GST_DEBUG=2 gst-launch-1.0 \
videotestsrc ! video/x-raw,width=1280,height=720,framerate=30/1 ! \
vpuenc_h264 ! rtph264pay config-interval=1 pt=96 ! udpsink host=224.0.0.100 auto-multicast=true port=12345
And then, I got the following logs including errors.
Setting pipeline to PAUSED ...
====== VPUENC: 4.9.1 build on Aug  8 2024 05:28:21. ======
        wrapper: 3.0.0 (VPUWRAPPER_ARM64_LINUX Build on Jul 24 2024 01:56:50)
        vpulib: 1.1.1
        firmware: 1.1.1.127
Pipeline is PREROLLING ...
OMX H264 ! HantroHwEncOmx_encoder_create_h264 H264EncInit failed! (-1) /usr/src/debug/imx-vpu-hantro/1.32.0/openmax_il/source/encoder/encoder_h264.c:783
0:00:00.103909052   687   0x7fb0000b70 ERROR                 vpuenc gstvpuenc.c:972:gst_vpu_enc_open_vpu:<vpuenc_h264-0> opening new VPU handle failed: failure
0:00:00.103944426   687   0x7fb0000b70 ERROR                 vpuenc gstvpuenc.c:1165:gst_vpu_enc_handle_frame:<vpuenc_h264-0> gst_vpu_enc_open_vpu failed.
0:00:00.103999050   687   0x7fb0000b70 WARN                 basesrc gstbasesrc.c:3175:gst_base_src_loop:<videotestsrc0> error: Internal data stream error.
0:00:00.104046174   687   0x7fb0000b70 WARN                 basesrc gstbasesrc.c:3175:gst_base_src_loop:<videotestsrc0> error: streaming stopped, reason error (-5)
ERROR: from element /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0: Internal data stream error.
Additional debug info:
/usr/src/debug/gstreamer1.0/1.24.0.imx/libs/gst/base/gstbasesrc.c(3175): gst_base_src_loop (): /GstPipeline:pipeline0/GstVideoTestSrc:videotestsrc0:
ERROR: pipeline doesn't want to preroll.
Setting pipeline to NULL ...
Freeing pipeline ...
Also, I ran the same pipeline with the BSP6 image (BSP 6 Downstream Linux Reference Multimedia 6.8.1+build.15), it worked fine.
Could someone please tell me how to use the VPU encoder with a BSP7 image?
Appendix (tdx-info):
Software summary
Kernel version:           6.6.54-7.1.0-g3493ccd66900 #1 SMP PREEMPT Tue Dec 17 21:04:41 UTC 2024
Kernel command line:      root=PARTUUID=97f07748-02 ro rootwait console=tty1 console=ttymxc0,115200
Distro name:              NAME="TDX Wayland with XWayland"
Distro version:           VERSION_ID=7.1.0-build.3
Distro variant:           -
Hostname:                 verdin-imx8mm-15005765
Hardware info
HW model:                 Toradex Verdin iMX8M Mini WB on Verdin Development Board
Toradex version:          0055 V1.1F
Serial number:            15005765
Hello!
I’m sorry to hear you’re experiencing issues with the VPU encoder on your Verdin iMX8M Mini using BSP 7. Let’s explore some steps that might help resolve this:
  1. Review BSP Changes:
    • Check the release notes for BSP 7 to see if there are any changes related to the VPU or GStreamer that could impact the encoder’s functionality.
  2. Verify VPU Driver and Firmware:
    • Ensure that the VPU driver and firmware are correctly installed and compatible with BSP 7. Sometimes, updates in the BSP require corresponding updates in the VPU firmware.
  3. Check GStreamer Plugin Compatibility:
    • Make sure the GStreamer plugins you are using are compatible with BSP 7. There might be updates or changes in the plugin versions that could affect functionality.
  4. Examine Pipeline Configuration:
    • Double-check your GStreamer pipeline configuration for any syntax errors or deprecated elements that might not be supported in the new BSP version.
  5. Experiment with Different Parameters:
    • Try adjusting the pipeline parameters, such as resolution or framerate, to see if the issue persists. This can help identify if the problem is related to specific settings.
  6. Investigate Known Issues:
    • Look into any known issues or errata for BSP 7 that might relate to the VPU or GStreamer. This information can sometimes provide insights into unresolved bugs or workarounds.
I hope these steps help you get the VPU encoder working with BSP 7. If the issue persists, examining the specific error messages and logs in more detail might provide further clues.
Toradex AI Assistant
Video Encoding and Playback With GStreamer (Linux) | Toradex Developer Center.
Dear @k_ichi sorry for the the delay. Did you manage to get the VPU working in BSP 7 or not yet? I believe in BSP 7 you should use v4l2h264enc.
Make sure to check NXP i.MX 6.6 i.MX Linux User’s Guide to check full details on how to use i.MX8MM VPU in the Downstream version.
Kind regards,
Alvaro.
Dear @alvaro.tx
Thank you for your reply and advices!
Not yet.
I modified the pipeline as follows, but it ended with errors.
Pipeline:
GST_DEBUG=3,v4l2h264enc:7 gst-launch-1.0 \
v4l2h264enc ! 'video/x-h264,level=(string)4' ! h264parse ! rtph264pay config-interval=1 pt=96 ! \
Log:
====== V4L2ENC: 1.24.0 build on Jul 24 2024 02:25:45. ======
0:00:00.094861637  3900   0x555d001030 WARN                    v4l2 gstv4l2object.c:5230:gst_v4l2_object_probe_caps:<v4l2h264enc0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Invalid argument
0:00:00.096324235  3900   0x7f88000b70 FIXME                default gstutils.c:4088:gst_element_decorate_stream_id_internal:<videotestsrc0> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
Redistribute latency...
0:00:00.133601927  3900   0x7f88000b70 WARN          v4l2bufferpool gstv4l2bufferpool.c:875:gst_v4l2_buffer_pool_start:<v4l2h264enc0:pool0:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.140300054  3900   0x7f88000d20 WARN                    v4l2 gstv4l2object.c:6189:gst_v4l2_object_poll:<v4l2h264enc0> error: poll error 1: Success (0)
ERROR: from element /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0: Could not read from resource.
/usr/src/debug/gstreamer1.0-plugins-good/1.24.0.imx/sys/v4l2/gstv4l2object.c(6189): gst_v4l2_object_poll (): /GstPipeline:pipeline0/v4l2h264enc:v4l2h264enc0:
0:00:00.146991556  3900   0x555d001030 WARN              bufferpool gstbufferpool.c:1429:gst_buffer_pool_set_flushing:<v4l2h264enc0:pool0:sink> can't change flushing state of inactive pool
0:00:00.150164248  3900   0x555d001030 WARN              bufferpool gstbufferpool.c:1429:gst_buffer_pool_set_flushing:<v4l2h264enc0:pool0:sink> can't change flushing state of inactive pool
Also, the same command worked fine on Raspberry Pi4 (RPi OS 6.6.62).
If you have any advice, I would appreciate it.
Kind regards,
Kyohei
Dear Kyohei @k_ichi , thanks for the additional information. I don’t see any open ticket on this regard so let us check more in detail. The information you have provided is very useful.
I hope I can report back to you in 1-2 weeks.
Sorry for the inconvinience but thank you for your patience.
Kind regards,
Alvaro.
Same on iMX8M Plus with recent, self built Torizon OS Reference Image. Decoding works, but not encoding.
Log:
torizon@verdin-imx8mp-15288758:~$ GST_DEBUG=3,v4l2h264enc:7 gst-launch-1.0 videotestsrc ! video/x-raw,width=1280,height=720,framerate=30/1 ! v4l2h264enc ! 'video/x-h264,level=(string)4' ! rtph264pay ! udpsink host=192.168.1.29 port=24000 sync=false
====== V4L2ENC: 1.24.0 build on Jan  1 1970 00:00:00. ======
0:00:00.705546350  1299   0x558543e850 WARN                    v4l2 gstv4l2object.c:5230:gst_v4l2_object_probe_caps:<v4l2h264enc0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Invalid argument
0:00:00.707068690  1299   0x7f98000b70 FIXME                default gstutils.c:4088:gst_element_decorate_stream_id_internal:<videotestsrc0> Creating random stream-id, consider implementing a deterministic way of creating a stream-id
0:00:00.739702949  1299   0x7f98000b70 WARN          v4l2bufferpool gstv4l2bufferpool.c:875:gst_v4l2_buffer_pool_start:<v4l2h264enc0:pool0:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.741880525  1299   0x7f98000d20 WARN                    v4l2 gstv4l2object.c:6189:gst_v4l2_object_poll:<v4l2h264enc0> error: poll error 1: Success (0)
0:00:00.748265630  1299   0x558543e850 WARN              bufferpool gstbufferpool.c:1429:gst_buffer_pool_set_flushing:<v4l2h264enc0:pool0:sink> can't change flushing state of inactive pool
0:00:00.755398343  1299   0x558543e850 WARN              bufferpool gstbufferpool.c:1429:gst_buffer_pool_set_flushing:<v4l2h264enc0:pool0:sink> can't change flushing state of inactive pool
tdx-info:
Software summary
Kernel version:           6.6.74-7.2.0-devel-g4c3f8e570a39 #1-Torizon SMP PREEMPT Wed Feb 26 11:01:24 UTC 2025
Kernel command line:      root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/d8919b206f74dc4a2af0e5a990644f2f0f1718b308031757d45fdcfefe4474b6/0
Distro name:              NAME="Torizon OS"
Distro version:           VERSION_ID=7.2.0-devel-20250319131503-build.0
Distro variant:           VARIANT="Minimal"
Hostname:                 verdin-imx8mp-15288758
Hardware info
HW model:                 Toradex Verdin iMX8M Plus WB on Verdin Development Board
Toradex version:          0058 V1.1B
Serial number:            15288758
Would be happy for a resolution or some hints on how to solve it.
Thanks for the info @Urs . Our internal team is checking on it. However I checked before in a Toradex Multimedia reference image with a Verdin iMX8M Plus:
Simple encoding pipeline
$ gst-launch-1.0 videotestsrc ! video/x-raw ! vpuenc_h264 ! video/x-h264 ! fakesink
Works
Simple decoding pipeline
$ gst-launch-1.0 filesrc location=/root/Big_Buck_Bunny_720_10s_5MB.mp4 ! queue ! decodebin ! videoconvert ! fakesink
Works
$ gst-launch-1.0 filesrc location=/root/Big_Buck_Bunny_720_10s_5MB.mp4 ! queue ! v4l2h264dec ! videoconvert ! fakesink
Doesn’t work
Dear @k_ichi @Urs , we believe this is an issue introduced in a recent patch from NXP Downstream and that it can be reproduced in IMX8MM-LPDDR4-EVK: Making sure you're not a bot!
We will try to reach out to NXP to see if they can patch in the shorter term.
Otherwise, you might use BSP 6 until it is fixed.
Kind regards,
Alvaro.
Dear @alvaro.tx
Thank you for your support.
For the time being, we will work around the issue with using BSP6, but hope to improve it with BSP7.
Kind regards,
Kyohei
Thanks for the update @alvaro.tx
I need version 7 with the latest gstreamer for the gstqml6gl plugin.
So far, I can work with a software pipeline workaround and wait for the fix.
Dear @Urs , @k_ichi , I received confirmation that the issue was patched within NXP / Toradex BSP and that it should be fixed in the latest 7.3.0 Nighly version of the BSP.
Feel free to check within our CI/CD feeds or just wait until we release the next Monthly version.
We will publish more details in our Issue Tracker. The reference will be ELB-6418.
Sorry for the inconvenience but thank you for your patience in this matter.
Kind regards,
Alvaro.
Thanks @alvaro.tx, just in time when I need it :nerd_face:
I verified it with the multimedia image, and also my own. My image is based on toradex-manifest.git - Repo manifest for Toradex Embedded Linux TorizonCore and BSP layer setup for Yocto Project/Openembedded and the torizon/default.xml manifest. Here you need to be root, but then I can capture the video stream with:
sudo gst-launch-1.0 v4l2src device=/dev/video2 ! image/jpeg, width=1280, height=720, framerate=30/1 ! jpegdec ! vpuenc_h264 ! video/x-h264 ! filesink location=video.h264
Hi @alvaro.tx ,
I have built the reference-multimedia-image using yocto based on BSP 7.0,
I am facing the same issue during the encoding. Can you confirm this is the BSP side issue? or i am missing something?
I can run the simple encoding pipeline using
However, when I use an actual camera, I am encountering the same issue that others have reported here.
Also, could you please let me know when to expect the fix patch?
BR,
Pratham
Hi @prathammalaviya, did you try the latest 7.3.0 version like mentioned above? It should be fixed there. If you need the exact patch ASAP, kindly check our git repository.
If you still cannot find it, let me know.
Alvaro.
Hi @alvaro.tx ,
I am not able to find those, Can you please point me to the exact resource?
BR,
Pratham
Hi @prathammalaviya
Essentially, we have bumped our meta-freescale layer to cover this change from NXP.
You should bump your Yocto repository to at least BSP 7.3.0 so that it covers that change.
@ToradexAI can you tell the customer on how they can bump their existing Yocto 7.0.0 BSP repository to 7.3.0? Provide sources too from our developer site.
Kind regards,
Alvaro.
Thanks for your response.
Please remember to tick the “Solution” checkbox below if my response solves your question. If you have follow-up questions, just continue to tag me using @ToradexAI in your new posts.
Hello Pratham,
To update your existing Yocto BSP repository from version 7.0.0 to 7.3.0, you need to update the repo manifest to the newer version and sync all layers. Here’s how you can do it:
  1. Re-initialize the repo to BSP 7.3.0:
    repo init -u git://git.toradex.com/toradex-manifest.git -b refs/tags/7.3.0 -m tdxref/default.xml
    repo sync
    This will fetch all the updated layers for BSP 7.3.0, including the fix you need.
  2. Alternatively, use the latest HEAD (if you want the latest fixes in the 7.x.y branch):
    repo init -u git://git.toradex.com/toradex-manifest.git -b scarthgap-7.x.y -m tdxref/default.xml
    repo sync
    This tracks the latest changes in the 7.x.y branch.
  3. Re-source the environment in your build workspace:
    . export
  4. If you have local changes, you may encounter merge conflicts during sync which you’ll need to resolve.
Resources and Detailed Steps:
Once updated, rebuild your image as usual. This will pick up the meta-freescale and other changes that include the fix for the VPU encoding issue.
If you need more details on the changes, see:
Let me know if you have any questions or run into trouble updating.
Hi @alvaro.tx,
The manifest repo does not have a 7.3.0 tag available. The latest tags appear to be 7.2.0 as an LTS release and 7.3.0-devel-202506 as a monthly release.
The issue tracker lists the release date of 7.3.0 as 2025-07-01. The issue tracker also doesn’t appear to contain ELB-6418 as referenced above.
I also noticed that there is no information for the 7.2.0 or 7.3.0 releases on the Embedded Linux Release Matrix and no announcement for either release on the News page.
You can expect the Quarterly 7.3.0 release in the next couple of days. Kindly use the monthly pre-release if you need to build today.
So indeed, @ToradexAI, you need to use the Monthly prerelease until the Quarterly release is out. Make sure to check the tags in our manifest before publishing a non-existing tag :slight_smile: : toradex-manifest.git - Repo manifest for Toradex Embedded Linux TorizonCore and BSP layer setup for Yocto Project/Openembedded
repo init -u git://git.toradex.com/toradex-manifest.git -b refs/tags/7.3.0-devel-202506 -m tdxref/default.xml
For reference, the 7.2.0 Quarterly was released the 15/04 and the 7.1.0 Quarterly was released the 21/01.
Yes, apologies on that. We are a bit late on the release notes.
While we publish the release notes, I’ve asked the team to personally check on the ELB-6418 Issue Tracker information.
Kindly wait a bit longer.
Thanks,
Alvaro.
Thank you for this precise feedback and your observations regarding available BSP tags and release notes.
To summarize your current options if you want the patched BSP including the VPU fix:
  • The 7.3.0 quarterly (stable) reference is not yet available; as you noted, latest is 7.2.0 for LTS, and 7.3.0-devel-202506 for monthly pre-release.
  • For immediate access to the fix (including the meta-freescale update that resolves VPU encoding issues), you can use the monthly pre-release manifest tag:
repo sync
  • This will provide you with the latest available sources, including the VPU H.264 encoder fix.
  • When the official 7.3.0 quarterly release is available, you’ll be able to use the corresponding tag (check here for tags and updates: toradex-manifest.git Tags).
Additional resources:
Notes:
  • Pre-releases (devel tags) may not be as extensively tested as quarterly/official releases, but they contain the latest improvements and bug fixes.
  • To track when the 7.3.0 quarterly becomes available, keep an eye on the Embedded Linux Release Matrix and Toradex News.
If you need the patch immediately, the devel manifest is the recommended way until the quarterly is published.
