I have a Dahlia v1.1B board with the Verdin iMX8M Mini Quad 2GB WB IT V1.1B based. The image used is your Linux Multimedia Reference 6.1.0+build.5 .
When I send the following commands, the system goes to sleep, and stays in this mode. The system does not wake up with the WAKE1_MICO# pin or with a key press from the console.
echo enabled > /sys/class/tty/ttymxc0/power/wakeup;
echo deep > /sys/power/mem_sleep;
echo mem > /sys/power/state
The same thing happens to me when configuring the system to wake up with the RTC alarm after 5 seconds, it remains in suspension mode.
echo +5 > /sys/class/rtc/rtc1/wakealarm;
