Verdin AM623 deep sleep wake up sources
in my design, I have the requirement to go in deep sleep mode using the command:
echo mem > /sys/power/state
that should be the deep sleep mode. From this condition I have 4 wake up sources:
  • pin SODIMM 252 - CTRL_WAKE1_MICO : linked to keyboard interrupt
  • pin SODIMM 63 - HDMI_1_CEC - MCU_GPIO0_8 : short circuited to pin SODIMM 252
  • pin SODIMM 246 - CTRL_RECOVERY_MICO : linked to a button
  • pin SODIMM 248 - CTRL_PWR_BTN_MICO : linked to a button
Experimentally I see that :
  • toggle on pin 246 low system wakes up every time
  • toggle on pins 63 / 248 wakes up the system only once
  • toggle on pin 248 does not wakes up the system
What shall I control in the system configuration and device tree overlay configurations to make all those input sources work correctly to wake up the system?
To configure multiple wake-up sources for deep sleep mode on your Toradex module, you need to understand the proper wake-up configuration and device tree overlay setup.
Understanding Deep Sleep Mode
For deep sleep mode using echo mem > /sys/power/state, the system enters Suspend-to-RAM (deep) state(1). The default wake-up behavior varies by pin configuration and module type.
Standard Wake-up Pin Configuration
According to the Verdin iMX8M Plus datasheet, pin 252 (CTRL_WAKE1_MICO#) is the standard external wake signal(2):
  • SODIMM 252: CTRL_WAKE1_MICO# - Standard external wake signal
  • i.MX 8MP Function: SAI1_RXFS / GPIO4_IO0
  • This pin is guaranteed to be wake-up compatible with other Verdin modules(2)
Wake-up Source Configuration Requirements
To configure multiple GPIO pins as wake-up sources, you need to create a device tree overlay that:
1. Enable Wake-up Capability for Each Pin
For each wake-up source, you need to configure the GPIO with proper wake-up properties in your device tree overlay(3)(4). The overlay structure should include:
/dts-v1/;
/plugin/;
    compatible = "toradex,verdin-imx8mp";
(3)(4)
2. Configure GPIO Properties for Wake-up
Each GPIO used as a wake-up source must be properly configured with:
  • Correct pinmux settings
  • GPIO direction (input for wake-up sources)
  • Wake-up capability enabled
  • Proper interrupt configuration
3. Device Tree Overlay Customization Process
To write your custom device tree overlay(3)(4):
  1. Identify the specific pin functions for your SODIMM pins in the datasheet
  2. Create pinctrl configurations with proper GPIO pinmux definitions(4)
  3. Add wake-up properties to each GPIO node
  4. Configure interrupt settings for edge detection
4. Pin-Specific Considerations
Based on your observations:
  • SODIMM 246 (CTRL_RECOVERY_MICO): Works consistently - this suggests proper wake-up configuration
  • SODIMM 63 and 248: Work only once - indicates potential configuration issues with interrupt clearing or GPIO state management
  • SODIMM 252: Should work as the standard wake-up pin(2)
Recommended Approach
  1. Check existing device tree overlays provided by Toradex for similar wake-up configurations(3)
  2. Create a custom overlay that properly configures all four pins with wake-up capabilities
  3. Ensure proper interrupt handling for each wake-up source
  4. Test wake-up functionality systematically for each pin
Device Tree Overlay Development Resources
For creating and deploying your custom overlay:
The key is ensuring each wake-up GPIO is properly configured with interrupt capabilities and wake-up properties in your device tree overlay, rather than relying on default pin configurations.
Hello Andrea,
Quick check, which AM62 board version are you using?
Unfortunately the V1.1 has known issues with sleep, which have been resolved in the 1.2 version
best regards
Maximiliano Zapata
Toradex
I am using version 1.2, I am aware about the v1.1 bug related to the deep sleep.
Actually I’m struggling making work the pin 244 as wake up source even if it is in the deep sleep wake up pin list in datasheet. Also, seems like there is a problem in managing the keyboard ISR as wake up source: it works just once, then seems like the ISR is no more triggered (keyboard no more works).
If you have any suggestion on overlay settings or some more bug I need to know about this chip, it’s more than welcome (I have few experience in embedded linux dev, any suggestion is welcome :slight_smile:
Thanks,
Andrea
Hi Andrea,
thanks for the clarification, quick question:
  1. is there are particular reason preventing you from using the CTRL_WAKE1_MICO (PIN 252) for wake up? (which is intended for this purpose - See datasheet page 62).
  2. you mentioned at the beginning of this thread: SODIMM 252 - CTRL_WAKE1_MICO : linked to keyboard interrupt, can this interrupt be moved to a different GPI ?
The pin 252 on the X1 connector is the default wakeup source for the Verdin Family, and only this pin is guaranteed to be wakeup compatible with other Verdin modules. Please use only this pin to wake up the module if the carrier board needs to be compatible with other Verdin modules. (see page 59). While other pin can be used, we would recommend using this one if possible.
Maximiliano Zapata
Toradex
Dear Maximiliano,
since we need to activate the deep sleep mode to minimize the power consumption, I cannot rely only on the standard wake up pin, that’s why I needed to route it also to another pin that is part of the deep sleep wake up pins table in the datasheet.
Anyway, during my tests, I am observing a strange behavior: when I enter in deep sleep, even if i did not configured one pin as wakeup-source, I see that the system anyway wakes up.
In detail: I have a button linked to pin MCU_GPIO0_11, configured only as input, but not as wakeup source. Anyway, if this pin toggles, the system wakes up.
I have an assumption in mind: is for the system enough that any of the MCU_GPIO0 pin moves to exit from deep sleep mode in the Verdin AM623? There is no way to “exclude” deep sleep wake up capable pins from wake actually the system up?
Thanks for answering,
Andrea
Hi Andrea,
You assumption is correct. Under DeepSleep MCU_GPIO0 pins may wake up the module. I would suggest you checking the 5.4.1 GPIO Wakeup section on the datesheet for more information about it
as far as I know, these pins are wired into the wakeup logic which makes it hard to deactivate these functions, therefore, if possible, a much straight forward solution should be to use different pins.
hope this helps
best regards
Maximiliano Zapata
Toradex
