It looks like you are trying to enable all the UART interfaces on the Verdin AM62 module, but you are only seeing 5 UARTs listed after booting. Here are a few things to check and consider:
Device Tree Consistency:
- Ensure that the pinctrl settings and the UART nodes are correctly defined and consistent.
- Verify that there are no conflicting pin assignments or incorrect pin configurations.
Status Property:
- Make sure that the
statusproperty for each UART node is set to"okay". - In your device tree, you have some UART nodes with
status = "disabled";and then later set tostatus = "okay";. Ensure that the final status is correctly set to"okay".
DMA Configuration:
- Ensure that the DMA settings are correctly configured for each UART that requires DMA.
- Verify that the DMA channels are not conflicting with each other.
Kernel Logs:
- Check the kernel logs (
dmesg) for any errors or warnings related to UART initialization. This can provide clues if there are issues with the device tree or driver initialization.
UART Driver Support:
- Ensure that the UART driver in the kernel supports all the UART instances you are trying to enable.
- Verify that the driver is not limited to a certain number of UARTs.
Pin Multiplexing:
- Double-check the pin multiplexing settings to ensure that the pins are correctly configured for UART functionality and not being used by other peripherals.
Here is a revised version of your device tree snippet with some corrections:
/* Verdin UART_0, used as the Linux console */
pinctrl_uart0: main-uart0-pins-default {
pinctrl-single,pins = <
AM62X_IOPAD(0x1c8, PIN_INPUT_PULLUP, 0) /* (D14) UART0_RXD */ /* SODIMM 147 */
AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ /* SODIMM 149 */
/* Verdin UART_4 */
pinctrl_uart4: main-uart4-pins-default {
AM62X_IOPAD(0x00b0, PIN_INPUT_PULLUP, 3) /* (K22) GPMC0_CSn2.UART4_RXD */ /* SODIMM 53 */
AM62X_IOPAD(0x00b4, PIN_OUTPUT, 3) /* (K24) GPMC0_CSn3.UART4_TXD */ /* SODIMM 55 */
/* Verdin UART_6 */
pinctrl_uart6: main-uart6-pins-default {
AM62X_IOPAD(0x0194, PIN_INPUT_PULLUP, 3) /* (B19) MCASP0_AXR3.UART6_RXD */ /* SODIMM 21 */
AM62X_IOPAD(0x0244, PIN_OUTPUT, 1) /* (C17) MMC1_SDWP.UART6_TXD */ /* SODIMM 21 */
/* Verdin UART_5 */
pinctrl_uart5: main-uart5-pins-default {
AM62X_IOPAD(0x0074, PIN_INPUT_PULLUP, 2) /* (U25) GPMC0_AD14.UART5_RXD */ /* SODIMM 135 */
AM62X_IOPAD(0x0078, PIN_OUTPUT, 2) /* (U24) GPMC0_AD15.UART5_TXD */ /* SODIMM 17 */
/* Verdin UART_2 */
pinctrl_uart2: main-uart2-pins-default {
AM62X_IOPAD(0x0224, PIN_INPUT_PULLUP, 3) /* (D22) MMC1_DAT3.UART2_RXD */ /* SODIMM 70 */
AM62X_IOPAD(0x0228, PIN_OUTPUT, 3) /* (C21) MMC1_DAT2.UART2_TXD *//* SODIMM 72 */
/* Verdin UART_3 */
pinctrl_uart3: main-uart3-pins-default {
AM62X_IOPAD(0x0234, PIN_INPUT_PULLUP, 3) /* (B22) MMC1_CLK.UART3_RXD */ /* SODIMM 74 */
AM62X_IOPAD(0x023c, PIN_OUTPUT, 3) /* (A21) MMC1_CMD.UART
https://developer.toradex.com/software/linux-resources/device-tree/
https://community.toradex.com/t/enable-uart-instead-of-verdin-can-1-on-verdin-am62/21882.
