i am trying to bring up all the main uart available in AM625. as per the documents we have 7 uart, so i have enabled all in the device tree
below is my device tree:
/* Verdin UART_0, used as the Linux console */
pinctrl_uart0: main-uart0-pins-default {
pinctrl-single,pins = <
AM62X_IOPAD(0x1c8, PIN_INPUT_PULLUP, 0) /* (D14) UART0_RXD */ /* SODIMM 147 */
AM62X_IOPAD(0x1cc, PIN_OUTPUT, 0) /* (E14) UART0_TXD */ /* SODIMM 149 */
/* Verdin UART_4, used as the Linux console */
pinctrl_uart4: main-uart4-pins-default {
AM62X_IOPAD(0x00b0, PIN_INPUT_PULLUP, 3) /* (K22) GPMC0_CSn2.UART4_RXD */ /* SODIMM 53 */
AM62X_IOPAD(0x00b4, PIN_OUTPUT, 3) /* (K24) GPMC0_CSn3.UART4_TXD */ /* SODIMM 55 */
/* Verdin UART_6, used as the Linux console */
pinctrl_uart6: main-uart6-pins-default {
AM62X_IOPAD(0x0194, PIN_INPUT_PULLUP, 3) /* (B19) MCASP0_AXR3.UART6_RXD */ /* SODIMM 21 */
AM62X_IOPAD(0x0244, PIN_OUTPUT, 1) /* (C17) MMC1_SDWP.UART6_TXD */ /* SODIMM 21 */
/* Verdin UART_5, used as the Linux console */
pinctrl_uart5: main-uart5-pins-default {
AM62X_IOPAD(0x0074, PIN_INPUT_PULLUP, 2) /* (U25) GPMC0_AD14.UART5_RXD */ /* SODIMM 135 */
AM62X_IOPAD(0x0078, PIN_OUTPUT, 2) /* (U24) GPMC0_AD15.UART5_TXD */ /* SODIMM 17 */
/* Verdin UART_2, used as the Linux console */
pinctrl_uart2: main-uart2-pins-default {
AM62X_IOPAD(0x0224, PIN_INPUT_PULLUP, 3) /* (D22) MMC1_DAT3.UART2_RXD */ /* SODIMM 70 */
AM62X_IOPAD(0x0228, PIN_OUTPUT, 3) /* (C21) MMC1_DAT2.UART2_TXD *//* SODIMM 72 */
/* Verdin UART_3, used as the Linux console */
pinctrl_uart3: main-uart3-pins-default {
AM62X_IOPAD(0x0234, PIN_INPUT_PULLUP, 3) /* (B22) MMC1_CLK.UART3_RXD */ /* SODIMM 74 */
AM62X_IOPAD(0x023c, PIN_OUTPUT, 3) /* (A21) MMC1_CMD.UART3_TXD */ /* SODIMM 78 */
/* Verdin UART_1 */
pinctrl_uart1: main-uart1-pins-default {
AM62X_IOPAD(0x01ac, PIN_INPUT_PULLUP, 2) /* (E19) MCASP0_AFSR.UART1_RXD */ /* SODIMM 129 */
AM62X_IOPAD(0x01b0, PIN_OUTPUT, 2) /* (A20) MCASP0_ACLKR.UART1_TXD */ /* SODIMM 131 */
&main_uart0 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_uart0>;
status = "disabled";
/* Verdin UART_1 */
&main_uart1 {
pinctrl-0 = <&pinctrl_uart1>;
/* Verdin UART_4 */
&main_uart2 {
pinctrl-0 = <&pinctrl_uart2>;
/* Verdin UART_4 */
&main_uart3 {
pinctrl-0 = <&pinctrl_uart3>;
/* Verdin UART_4 */
&main_uart4 {
pinctrl-0 = <&pinctrl_uart4>;
/* Verdin UART_5 */
&main_uart5 {
pinctrl-0 = <&pinctrl_uart5>;
/* Verdin UART_3 */
&main_uart0 {
dmas = <&main_pktdma 0x4400>, <&main_pktdma 0xc400>;
dma-names = "rx", "tx";
/* Verdin UART_1, connector X50 through RS485 transceiver. */
&main_uart1 {
linux,rs485-enabled-at-boot-time;
rs485-rx-during-tx;
dmas = <&main_pktdma 0x4401>, <&main_pktdma 0xc401>;
&main_uart2 {
&main_uart3 {
&main_uart4 {
&main_uart5 {
&main_uart6 {
But once the board is booted, i can see only 5 uart listed from ttyS0 to ttyS4, is there anything i am missing, kindly check and reply!
thanks in advance
