We need to confirmation for this LVDS display is compatible [Capacitive Touch Display - 10 inch LVDS] with Verdin-AM62 SOM and Mallow carrier board.
Yes, that display is compatible with the Verdin-AM62 SoM and the Mallow carrier board. However, it is not supported out-of-the-box in our pre-built OS images. You will need to apply the ‘Capacitive Touch Display 10.1" LVDS’ device tree overlay for the ‘Mezzanine’ add-on boards
hi alex
we are added Mezzanine dtbo but display is not working. can you share me steps for testing.
Thank you
Akash Shinde
- Ensure that you have added the correct Device Tree Overlay (DTO). The correct name is not “Mezzanine dtbo” but “verdin-am62_mezzanine_panel-cap-touch-10inch-lvds_overlay.dtbo”.
- Verify that you have followed all the steps described here correctly.
- Check that the display cable is properly connected.
Hi @Akash,
Apart from what @alex.tx shared please also check if JP1 is shortened. This will power LVDS back-light from Mallow input supply.
Make sure Mallow power input should be same as displayu backlight input. Check Mallow datasheet section 2.9.3 for more details.
Ritesh kumar
@alex.tx thank you.
we are loaded verdin-am62_mezzanine_panel-cap-touch-10inch-lvds_overlay.dtbo.mezzanine backlight related sys entry we are detecting but only splash screen detecting on boot time but no any logo loaded. May be something we are missing can you please help me.
@ritesh.tx Jumper p1is shorted.12v power supply we are connecting
One more thing touch i2c entey not detected in i2cdetect can you please help for same
Hi @Akash,
We quickly tested Verdin AM62Q 2GB WB IT+Mallow+BSP 6 and display works fine without any issue. Please check below overlay which we used
cat /boot/overlays.txt
fdt_overlays=verdin-am62_panel-cap-touch-10inch-lvds_overlay.dtbo
Please check cable is properly connected. Also Pease share i2cdetect command output and complete log to further check issue related to same.
Ritesh Kumar
@alex.tx @ritesh.tx We are confused. You both giving different dtbo files please confirm.
currently i have loaded.verdin-am62_dsi-to-lvds_panel-cap-touch-10inch-lvds_overlay.dtbo
after some modification i have getting console logs on lvds display but touch i2c not detected.
how to i disable console logs and enable boot logo. Please help me.
thank you!
