Verdin AM62 sleep and low power modes
Hi all,
I am interested in discovering the available low power and sleep modes on the Verdin AM62 device.
More specifically, I would like to know:
  • which are the configuration points in the sw project to enable low power and sleep modes
  • how to enable each low power and sleep mode programmatically or using a console command
  • how to set up properly the wake up source in device tree overlays
Low Power and Sleep Modes on Verdin AM62
Based on the Verdin AM62 V1.2 datasheet, the TI AM62x SoC supports four distinct low power modes(1):
Available Low Power Modes
Mode Description
Partial I/O The entire SoC is OFF except I/O pins in CANUART I/O bank(1)
DeepSleep Used for suspend to RAM(1)
MCU-Only The system is in DeepSleep except the MCU subsystem(1)
Standby A53 and M4F are in WFI or power down, any interrupt event is capable of waking up the SoC(1)
Important Power Considerations
To achieve minimum power consumption, you must first disable other ICs on the SoM (such as the Wi-Fi/Bluetooth module) before enabling a low power mode on the SoC, as the SoC low power modes do not affect other ICs on the SoM(1).
Wake-up Source Configuration
The wake-up capabilities vary depending on the low power mode:
Standby Mode
  • Any GPIO may wake up the module from Standby state(2)
  • Pin 252 on the X1 connector is the default wakeup source for the Verdin Family and is guaranteed to be wakeup compatible with other Verdin modules(2)
Partial I/O Mode
  • Only CANUART I/O bank pins are capable of waking up the module(2)
  • Available wake-up pins include(2):
X1 Pin SoC Ball Name GPIO Function Description
24 MCU_MCAN0_TX MCU_GPIO0_13 CAN_2 TX
26 MCU_MCAN0_RX MCU_GPIO0_14 CAN_2 RX
61 MCU_UART0_CTSn MCU_GPIO0_7 -
63 MCU_UART0_RTSn MCU_GPIO0_8 -
116 MCU_MCAN1_RX MCU_GPIO0_16 CAN_3 RX
128 MCU_MCAN1_TX MCU_GPIO0_15 CAN_3 TX
151 MCU_UART0_RXD MCU_GPIO0_5 UART_4 RX
153 MCU_UART0_TXD MCU_GPIO0_6 UART_4 TX
DeepSleep and MCU-Only Modes
  • MCU_GPIO0 pins may wake up the module(2)
  • Available wake-up pins include pins 24, 26, 57, 59, 61 (and others listed in the datasheet)(2)
Device Tree Overlay Configuration
For configuring wake-up sources in device tree overlays, you can reference the GPIO configuration examples provided in the documentation. The process involves creating pin control groups and assigning them to the appropriate GPIO controllers(3).
For detailed information on AM62x Low Power Modes, refer to TI’s “Enabling Low Power Embedded Systems With AM62x Processors” Technical White Paper referenced in the datasheet(1).
Note: The specific software configuration points and console commands for enabling these modes programmatically are not detailed in the available documentation sources. You may need to consult additional TI AM62x documentation or Linux power management documentation for the complete implementation details.
Thanks! Can you please give me some direct link to TI documentation that can help to understand how to test the 4 available low power modes?
Thanks for your response.
Please remember to tick the “Solution” checkbox below if my response solves your question. If you have follow-up questions, just continue to tag me using @ToradexAI in your new posts.
Based on the Verdin AM62 V1.2 datasheet, here are the direct links to TI documentation that can help you understand and test the four available low power modes:
TI Documentation Links
Primary Low Power Reference
Enabling Low Power Embedded Systems With AM62x Processors - TI’s Technical White Paper explaining low power modes, active power management, and analyzing power consumption on the AM62x SoC(1):
TI AM62x SoC Documentation
For additional details about the TI AM62x Sitara SoC, including comprehensive technical references(1):
AM623:
AM625:
Additional Context
The Verdin AM62 V1.2 datasheet specifically references TI’s white paper as the primary source for detailed information on AM62x Low Power Modes(1). This document should provide you with:
  • Detailed explanations of each low power mode
  • Power consumption analysis
  • Implementation guidelines
  • Testing procedures
The four low power modes supported by the TI AM62x SoC are(1):
  • Partial I/O - Most aggressive mode with entire SoC OFF except CANUART I/O pins
  • DeepSleep - Used for suspend to RAM
  • MCU-Only - System in DeepSleep except MCU subsystem
  • Standby - A53 and M4F in WFI or power down
These TI resources should provide the comprehensive technical details needed to implement and test these low power modes on your Verdin AM62 system.
I’ve found at this link Verdin AM62 Issue Tracker that there is a known HW fault that prevents to test deep sleep mode on Verdin AM62 boards V1.1. Do you confirm that in version V1.2 of the board the issue have been fixed?
Dear @dm-andreapedica,
I can indeed confirm that V1.2 has the fix in place to prevent this issue, even though this is not visible on the issue tracker. I will check in with our hardware team to see why exactly it is not mentioned under “Implemented in”.
Collin
