I recently encountered that my application works slower than usual (in my case it’s an Avalonia DRM app template). After some investigation I found out some weird results when running the eglinfo and kmscube -D /dev/dri/card0 commands. I’ve sent the logs in the files attached.
eglinfo_HWacc.log (33.5 KB)
eglinfo_no_HWacc.log (48.9 KB)
kmscube_HWacc.log (4.4 KB)
kmscube_no_HWacc.log (5.5 KB)
The temporary solution that works for me seems to be downgrading the ti-img-rogue-umlibs-am62 lib to version 24.2.6643903+git20250227.1ed9ee1-1 but I would rather not do that. Is there anything else I could do to avoid manually downgrading the library?
tdx-info:
Software summary
Bootloader: U-Boot
Kernel version: 6.6.106-7.4.0-g650792253644 #1-Torizon SMP PREEMPT Thu Sep 18 20:27:33 UTC 2025
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/d0838a71184a4ce5ad80766190ae02885679714841d06ba0e0dbf180d4510eb6/0
Distro name: NAME="Torizon OS"
Distro version: VERSION_ID=7.4.0-build.28
Distro variant: VARIANT="Docker"
Hostname: verdin-am62-15380640
Hardware info
HW model: Toradex Verdin AM62 on Mallow Board
Toradex version: 0076 V1.1C
Serial number: 15380640
Processor arch: aarch64
