Value of prescale to generate pwm pulse at desired frequency for T20
How to generate a pwm pulse of desired frequency, which generates a non-integer prescale value?
Hello @Mania,
Did you already checked the possible configurations and restrictions in the lib help file?
Here a short print screen:
Does this documentation answer your question? If not could you please specify your needs a little bit more precisely?
