Dear team.
I have written jd9365da panel dts file to bring up MIPI DSI based jd9365da (jadard TFT LCD panel) connected to imx8mm core board directly through MIPI DSI interface. i have taken below
dts files as reference.
dsi1.dtsi#L401
jd9365da dts file entries are given below for reference. requesting to let me know the vdd and vccio backlight entries passed in jd9365da dts file is valid or not? the panel is blank and if back light entry is enabled then failure in attaching jd9365da panel to mipi_dsi@32e10000 bus subsystem. So request to let me know vcc , vdd and backlight entries are valid or not.
#include “imx8mm-icore-starterkit.dts”
&lvds_bridge {
status = “disabled”;
&lcdif {
status = “okay”;
pwm_bl: backlight {
enable-gpios = <&gpio3 3 GPIO_ACTIVE_HIGH>; /* GPIO3, IO 03 */
pinctrl-names = “default”;
pwms = <&pwm1 0 1000000>;
&mipi_dsi {
status = “okay”;
#address-cells = <1>;
#size-cells = <0>;
panel@0 {
compatible = “radxa,display-8hd-a”, “jadard,jd9365da-h3”;
reg = <0>;
assigned-clock-rates = <23900000>; /* PLL Clock rate must be 239 MHZ*/
vdd-supply = <&buck5_reg>;
vccio-supply = <&buck5_reg>;
reset-gpio = <&gpio1 8 GPIO_ACTIVE_LOW>; /* LCD_RESET */
pinctrl-0 = <&pinctrl_mipi_dsi_en>;
//backlight = <&pwm_bl>;
status = “okay”;
bootlog:
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[ 0.000000] Linux version 5.15.71+g4c5b0dcdb0f9 (oe-user@oe-host) (aarch64-poky-linux-gcc (GCC) 11.3.0, GNU ld (GNU Binutils) 2.38.20220708) #1 SMP PREEMPT Mon Oct 28 11:27:59 UTC 2024
[ 0.000000] Machine model: Engicam i.Core MX8MM Starterkit 2.1
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000058000000, size 640 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x57dc9c00-0x57dcbfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000007fffffff]
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 20 pages/cpu s41880 r8192 d31848 u81920
[ 0.000000] Detected VIPT I-cache on CPU0
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: ARM erratum 845719
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 258048
[ 0.000000] Policy zone: DMA
[ 0.000000] Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk0p2 rootwait rw
[ 0.000000] Dentry cache hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] Memory: 330876K/1048576K available (20480K kernel code, 3426K rwdata, 10428K rodata, 6720K init, 546K bss, 62340K reserved, 655360K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 128 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x0000000038880000
[ 0.000000] ITS: No ITS available, not enabling LPIs
[ 0.000000] arch_timer: cp15 timer(s) running at 8.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x1d854df40, max_idle_ns: 440795202120 ns
[ 0.000000] sched_clock: 56 bits at 8MHz, resolution 125ns, wraps every 2199023255500ns
[ 0.001071] Console: colour dummy device 80x25
[ 0.001135] Calibrating delay loop (skipped), value calculated using timer frequency.. 16.00 BogoMIPS (lpj=32000)
[ 0.001148] pid_max: default: 32768 minimum: 301
[ 0.001204] LSM: Security Framework initializing
[ 0.001290] Mount-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.001302] Mountpoint-cache hash table entries: 2048 (order: 2, 16384 bytes, linear)
[ 0.002682] rcu: Hierarchical SRCU implementation.
[ 0.004813] EFI services will not be available.
[ 0.005020] smp: Bringing up secondary CPUs …
[ 0.005438] Detected VIPT I-cache on CPU1
[ 0.005468] GICv3: CPU1: found redistributor 1 region 0:0x00000000388a0000
[ 0.005513] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[ 0.005960] Detected VIPT I-cache on CPU2
[ 0.005982] GICv3: CPU2: found redistributor 2 region 0:0x00000000388c0000
[ 0.006008] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[ 0.006421] Detected VIPT I-cache on CPU3
[ 0.006441] GICv3: CPU3: found redistributor 3 region 0:0x00000000388e0000
[ 0.006465] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[ 0.006523] smp: Brought up 1 node, 4 CPUs
[ 0.006549] SMP: Total of 4 processors activated.
[ 0.006555] CPU features: detected: 32-bit EL0 Support
[ 0.006559] CPU features: detected: 32-bit EL1 Support
[ 0.006566] CPU features: detected: CRC32 instructions
[ 0.014463] CPU: All CPU(s) started at EL2
[ 0.014498] alternatives: patching kernel code
[ 0.015586] devtmpfs: initialized
[ 0.021812] KASLR disabled due to lack of seed
[ 0.021959] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.021977] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.040356] pinctrl core: initialized pinctrl subsystem
[ 0.041244] DMI not present or invalid.
[ 0.041885] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.043129] DMA: preallocated 128 KiB GFP_KERNEL pool for atomic allocations
[ 0.043211] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.043295] DMA: preallocated 128 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.043343] audit: initializing netlink subsys (disabled)
[ 0.043455] audit: type=2000 audit(0.040:1): state=initialized audit_enabled=0 res=1
[ 0.044554] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.044560] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.044754] cpuidle: using governor menu
[ 0.044981] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.045068] ASID allocator initialised with 65536 entries
[ 0.046584] Serial: AMBA PL011 UART driver
[ 0.046690] imx mu driver is registered.
[ 0.046727] imx rpmsg driver is registered.
[ 0.058608] imx8mm-pinctrl 30330000.pinctrl: no groups defined in /soc@0/bus@30000000/pinctrl@30330000/ab2anapwrgrp
[ 0.058645] imx8mm-pinctrl 30330000.pinctrl: no groups defined in /soc@0/bus@30000000/pinctrl@30330000/ab2vddpwr5v0grp
[ 0.058664] imx8mm-pinctrl 30330000.pinctrl: initialized IMX pinctrl driver
[ 0.070886] platform 32e10000.mipi_dsi: Fixing up cyclic dependency with 32e00000.lcdif
[ 0.071839] platform 32e30000.mipi_csi: Fixing up cyclic dependency with 32e20000.csi1_bridge
[ 0.096833] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.096852] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.096859] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.096867] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.098011] cryptd: max_cpu_qlen set to 1000
[ 0.101137] ACPI: Interpreter disabled.
[ 0.104357] iommu: Default domain type: Translated
[ 0.104370] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.104654] vgaarb: loaded
[ 0.104912] SCSI subsystem initialized
[ 0.105244] usbcore: registered new interface driver usbfs
[ 0.105280] usbcore: registered new interface driver hub
[ 0.105309] usbcore: registered new device driver usb
[ 0.106755] mc: Linux media interface: v0.10
[ 0.106779] videodev: Linux video capture interface: v2.00
[ 0.106856] pps_core: LinuxPPS API ver. 1 registered
[ 0.106862] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.106875] PTP clock support registered
[ 0.107023] EDAC MC: Ver: 3.0.0
[ 0.109076] FPGA manager framework
[ 0.109155] Advanced Linux Sound Architecture Driver Initialized.
[ 0.109678] Bluetooth: Core ver 2.22
[ 0.109705] NET: Registered PF_BLUETOOTH protocol family
[ 0.109710] Bluetooth: HCI device and connection manager initialized
[ 0.109722] Bluetooth: HCI socket layer initialized
[ 0.109731] Bluetooth: L2CAP socket layer initialized
[ 0.109744] Bluetooth: SCO socket layer initialized
[ 0.110347] clocksource: Switched to clocksource arch_sys_counter
[ 0.110505] VFS: Disk quotas dquot_6.6.0
[ 0.110547] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.110705] pnp: PnP ACPI: disabled
[ 0.116654] NET: Registered PF_INET protocol family
[ 0.116793] IP idents hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.117386] tcp_listen_portaddr_hash hash table entries: 512 (order: 1, 8192 bytes, linear)
[ 0.117437] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.117450] TCP established hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.117511] TCP bind hash table entries: 8192 (order: 5, 131072 bytes, linear)
[ 0.117624] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.117701] UDP hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.117729] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes, linear)
[ 0.117842] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.118194] RPC: Registered named UNIX socket transport module.
[ 0.118201] RPC: Registered udp transport module.
[ 0.118206] RPC: Registered tcp transport module.
[ 0.118214] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.119070] PCI: CLS 0 bytes, default 64
[ 0.119662] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counters available
[ 0.120288] kvm [1]: IPA Size Limit: 40 bits
[ 0.122314] kvm [1]: GICv3: no GICV resource entry
[ 0.122321] kvm [1]: disabling GICv2 emulation
[ 0.122361] kvm [1]: GIC system register CPU interface enabled
[ 0.122441] kvm [1]: vgic interrupt IRQ9
[ 0.122562] kvm [1]: Hyp mode initialized successfully
[ 0.125817] Initialise system trusted keyrings
[ 0.125994] workingset: timestamp_bits=42 max_order=18 bucket_order=0
[ 0.131867] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.132478] NFS: Registering the id_resolver key type
[ 0.132519] Key type id_resolver registered
[ 0.132525] Key type id_legacy registered
[ 0.132595] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 0.132603] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 0.132625] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.132962] 9p: Installing v9fs 9p2000 file system support
[ 0.168427] Key type asymmetric registered
[ 0.168437] Asymmetric key parser ‘x509’ registered
[ 0.168494] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 242)
[ 0.168502] io scheduler mq-deadline registered
[ 0.168509] io scheduler kyber registered
[ 0.186701] EINJ: ACPI disabled.
[ 0.202747] mxs-dma 33000000.dma-controller: initialized
[ 0.205347] SoC: i.MX8MM revision 1.0
[ 0.206146] Bus freq driver module loaded
[ 0.218363] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.221578] SuperH (H)SCI(F) driver initialized
[ 0.222296] 30860000.serial: ttymxc0 at MMIO 0x30860000 (irq = 39, base_baud = 5000000) is a IMX
[ 0.222875] 30880000.serial: ttymxc2 at MMIO 0x30880000 (irq = 40, base_baud = 5000000) is a IMX
[ 0.223283] 30890000.serial: ttymxc1 at MMIO 0x30890000 (irq = 41, base_baud = 1500000) is a IMX
[ 1.258574] printk: console [ttymxc1] enabled
[ 1.263823] msm_serial: driver initialized
[ 1.278848] imx-drm 32c00000.bus:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 1.287726] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 1.294922] [drm:drm_bridge_attach] ERROR failed to attach bridge /soc@0/bus@32c00000/mipi_dsi@32e10000 to encoder DSI-34: -19
[ 1.306517] imx_sec_dsim_drv 32e10000.mipi_dsi: Failed to attach bridge: 32e10000.mipi_dsi
[ 1.314853] imx_sec_dsim_drv 32e10000.mipi_dsi: failed to bind sec dsim bridge: -517
[ 1.332076] loop: module loaded
[ 1.337006] of_reserved_mem_lookup() returned NULL
[ 1.341899] megasas: 07.717.02.00-rc1
[ 1.347574] imx ahci driver is registered.
[ 1.359772] tun: Universal TUN/TAP device driver, 1.6
[ 1.366193] thunder_xcv, ver 1.0
[ 1.369474] thunder_bgx, ver 1.0
[ 1.372749] nicpf, ver 1.0
[ 1.377604] hclge is initializing
[ 1.380947] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 1.388177] hns3: Copyright (c) 2017 Huawei Corporation.
[ 1.393550] e1000: Intel(R) PRO/1000 Network Driver
[ 1.398436] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 1.404225] e1000e: Intel(R) PRO/1000 Network Driver
[ 1.409195] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 1.415151] igb: Intel(R) Gigabit Ethernet Network Driver
[ 1.420554] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 1.426161] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 1.432434] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 1.438874] sky2: driver version 1.30
[ 1.444210] Broadcom 43xx driver loaded [ Features: PNLS ]
[ 1.449732] Broadcom 43xx-legacy driver loaded [ Features: PLID ]
[ 1.456093] VFIO - User Level meta-driver version: 0.3
[ 1.464866] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 1.471414] ehci-pci: EHCI PCI platform driver
[ 1.475898] ehci-platform: EHCI generic platform driver
[ 1.481335] ehci-orion: EHCI orion driver
[ 1.485500] ehci-exynos: EHCI Exynos driver
[ 1.489831] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 1.496038] ohci-pci: OHCI PCI platform driver
[ 1.500520] ohci-platform: OHCI generic platform driver
[ 1.505926] ohci-exynos: OHCI Exynos driver
[ 1.511207] usbcore: registered new interface driver uas
[ 1.516574] usbcore: registered new interface driver usb-storage
[ 1.525821] input: 30370000.snvs:snvs-powerkey as /devices/platform/soc@0/30000000.bus/30370000.snvs/30370000.snvs:snvs-powerkey/input/input0
[ 1.541285] snvs_rtc 30370000.snvs:snvs-rtc-lp: registered as rtc0
[ 1.547512] snvs_rtc 30370000.snvs:snvs-rtc-lp: setting system clock to 2024-10-30T16:06:24 UTC (1730304384)
[ 1.558061] i2c_dev: i2c /dev entries driver
[ 1.565670] mx6s-csi 32e20000.csi1_bridge: initialising
[ 1.578099] Bluetooth: HCI UART driver ver 2.3
[ 1.582581] Bluetooth: HCI UART protocol H4 registered
[ 1.587729] Bluetooth: HCI UART protocol BCSP registered
[ 1.593064] Bluetooth: HCI UART protocol LL registered
[ 1.598211] Bluetooth: HCI UART protocol ATH3K registered
[ 1.603632] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 1.610035] Bluetooth: HCI UART protocol Broadcom registered
[ 1.615728] Bluetooth: HCI UART protocol QCA registered
[ 1.623506] sdhci: Secure Digital Host Controller Interface driver
[ 1.629720] sdhci: Copyright(c) Pierre Ossman
[ 1.635320] Synopsys Designware Multimedia Card Interface Driver
[ 1.642972] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.652702] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.660625] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping …
[ 1.667900] usbcore: registered new interface driver usbhid
[ 1.673490] usbhid: USB HID core driver
[ 1.683645] cs_system_cfg: CoreSight Configuration manager initialised
[ 1.683998] mmc2: SDHCI controller on 30b60000.mmc [30b60000.mmc] using ADMA
[ 1.694722] galcore: clk_get vg clock failed, disable vg!
[ 1.703051] Galcore version 6.4.3.p4.398061
[ 1.757836] [drm] Initialized vivante 1.0.0 20170808 for 38000000.gpu on minor 0
[ 1.767055] hantrodec 0 : module inserted. Major = 505
[ 1.772751] hantrodec 1 : module inserted. Major = 505
[ 1.778852] hx280enc: module inserted. Major <504>
[ 1.786529] mmc2: new HS400 Enhanced strobe MMC card at address 0001
[ 1.788678] NET: Registered PF_LLC protocol family
[ 1.793496] mmcblk2: mmc2:0001 DG4008 7.28 GiB
[ 1.798259] NET: Registered PF_INET6 protocol family
[ 1.803785] mmcblk2boot0: mmc2:0001 DG4008 4.00 MiB
[ 1.809690] Segment Routing with IPv6
[ 1.813307] mmcblk2boot1: mmc2:0001 DG4008 4.00 MiB
[ 1.815972] In-situ OAM (IOAM) with IPv6
[ 1.821775] mmcblk2rpmb: mmc2:0001 DG4008 4.00 MiB, chardev (506:0)
[ 1.824925] NET: Registered PF_PACKET protocol family
[ 1.838221] Bluetooth: RFCOMM TTY layer initialized
[ 1.843124] Bluetooth: RFCOMM socket layer initialized
[ 1.848283] Bluetooth: RFCOMM ver 1.11
[ 1.852045] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.857361] Bluetooth: BNEP filters: protocol multicast
[ 1.862598] Bluetooth: BNEP socket layer initialized
[ 1.867569] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.873499] Bluetooth: HIDP socket layer initialized
[ 1.878499] 8021q: 802.1Q VLAN Support v1.8
[ 1.882800] 9pnet: Installing 9P2000 support
[ 1.887103] tsn generic netlink module v1 init…
[ 1.891910] Key type dns_resolver registered
[ 1.896764] Loading compiled-in X.509 certificates
[ 1.926379] bt_regulator GPIO handle specifies active low - ignored
[ 1.934069] usb_phy_generic usbphynop1: supply vcc not found, using dummy regulator
[ 1.941852] usb_phy_generic usbphynop1: dummy supplies not allowed for exclusive requests
[ 1.950276] usb_phy_generic usbphynop2: supply vcc not found, using dummy regulator
[ 1.958036] usb_phy_generic usbphynop2: dummy supplies not allowed for exclusive requests
[ 2.029425] nxp-pca9450 0-0025: pca9450a probed.
[ 2.034181] i2c i2c-0: IMX I2C adapter registered
[ 2.049210] rtc-pcf8563 1-0051: low voltage detected, date/time is not reliable.
[ 2.057031] rtc-pcf8563 1-0051: registered as rtc1
[ 2.399552] edt_ft5x26 1-0038: touchscreen probe failed
[ 2.405353] i2c 1-003c: Fixing up cyclic dependency with 32e30000.mipi_csi
[ 2.412671] ov5640_mipi 1-003c: No sensor reset pin available
[ 2.418461] ov5640_mipi 1-003c: supply DOVDD not found, using dummy regulator
[ 2.425707] ov5640_mipi 1-003c: supply DVDD not found, using dummy regulator
[ 2.432816] ov5640_mipi 1-003c: supply AVDD not found, using dummy regulator
[ 2.451585] ov5640_mipi 1-003c: Read reg error: reg=300a
[ 2.456908] ov5640_mipi 1-003c: Camera is not found
[ 2.462062] i2c i2c-1: IMX I2C adapter registered
[ 2.468511] i2c i2c-2: IMX I2C adapter registered
[ 2.474317] i2c i2c-3: IMX I2C adapter registered
[ 2.480437] pwm-backlight backlight_lvds: supply power not found, using dummy regulator
[ 2.495462] imx-drm 32c00000.bus:display-subsystem: bound imx-lcdif-crtc.0 (ops lcdif_crtc_ops)
[ 2.504372] imx_sec_dsim_drv 32e10000.mipi_dsi: version number is 0x1060200
[ 2.511617] jadard_dsi_probe entry ***** dsi->lane 4 , dsi->format 0
[ 2.518237] imx-drm 32c00000.bus:display-subsystem: bound 32e10000.mipi_dsi (ops imx_sec_dsim_ops)
[ 2.528095] [drm] Initialized imx-drm 1.0.0 20120507 for 32c00000.bus:display-subsystem on minor 1
[ 2.913778] Console: switching to colour frame buffer device 100x80
[ 2.936402] imx-drm 32c00000.bus:display-subsystem: [drm] fb0: imx-drmdrmfb frame buffer device
[ 2.949211] pps pps0: new PPS source ptp0
[ 2.960973] fec 30be0000.ethernet eth0: registered PHC device 0
[ 2.968623] imx_usb 32e40000.usb: No over current polarity defined
[ 2.978081] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 2.982991] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 3.002971] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 3.009217] hub 1-0:1.0: USB hub found
[ 3.013001] hub 1-0:1.0: 1 port detected
[ 3.019828] imx_usb 32e50000.usb: No over current polarity defined
[ 3.029305] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 3.034216] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 3.054737] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 3.061017] hub 2-0:1.0: USB hub found
[ 3.064796] hub 2-0:1.0: 1 port detected
[ 3.071574] mxc_mipi-csi 32e30000.mipi_csi: supply mipi-phy not found, using dummy regulator
[ 3.080332] mxc_mipi-csi 32e30000.mipi_csi: mipi csi v4l2 device registered
[ 3.087305] CSI: Registered sensor subdevice: mxc_mipi-csi.0
[ 3.092997] mxc_mipi-csi 32e30000.mipi_csi: lanes: 2, hs_settle: 13, clk_settle: 2, wclk: 1, freq: 333000000
[ 3.103713] imx-cpufreq-dt imx-cpufreq-dt: cpu speed grade 2 mkt segment 2 supported-hw 0x4 0x4
[ 3.113658] Hot alarm is canceled. GPU3D clock will return to 64/64
[ 3.124895] sdhci-esdhc-imx 30b40000.mmc: Got CD GPIO
[ 3.127200] WLAN_EN: supplied by BT_EN
[ 3.134092] imx8mm-pinctrl 30330000.pinctrl: invalid function pinctrl in map table
[ 3.141796] ANA_12V0: supplied by BUCK5
[ 3.146077] imx8mm-pinctrl 30330000.pinctrl: invalid function pinctrl in map table
[ 3.153747] VDD_5V0: supplied by BUCK5
[ 3.157938] CPH_3V3: supplied by VDD_5V0
[ 3.162192] CPH_1V8: supplied by CPH_3V3
[ 3.165380] mmc0: SDHCI controller on 30b40000.mmc [30b40000.mmc] using ADMA
[ 3.166522] DAC_AVDD_6V0: supplied by ANA_12V0
[ 3.185375] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.197094] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 3.203744] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.205719] mmc0: host does not support reading read-only switch, assuming write-enable
[ 3.212371] platform regulatory.0: Falling back to sysfs fallback for: regulatory.db
[ 3.214356] mmc1: SDHCI controller on 30b50000.mmc [30b50000.mmc] using ADMA
[ 3.220608] ALSA device list:
[ 3.222457] mmc0: new high speed SDHC card at address b368
[ 3.223006] mmcblk0: mmc0:b368 USD 7.47 GiB
[ 3.224631] mmcblk0: p1 p2
[ 3.251212] No soundcards found.
[ 3.271245] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 3.281069] VFS: Mounted root (ext4 filesystem) on device 179:98.
[ 3.288692] devtmpfs: mounted
[ 3.293270] Freeing unused kernel memory: 6720K
[ 3.297918] Run /sbin/init as init process
[ 3.322364] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 3.486252] hub 2-1:1.0: USB hub found
[ 3.490425] hub 2-1:1.0: 4 ports detected
[ 3.820692] systemd[1]: systemd 250.5+ running in system mode (+PAM -AUDIT -SELINUX -APPARMOR +IMA -SMACK +SECCOMP -GCRYPT -GNUTLS -OPENSSL +ACL +BLKID -CURL -ELFUTILS -FIDO2 -IDN2 -IDN -IPTC +KMOD -LIBCRYPTSETUP +LIBFDISK -PCRE2 -PWQUALITY -P11KIT -QRENCODE -BZIP2 -LZ4 -XZ -ZLIB +ZSTD -BPF_FRAMEWORK +XKBCOMMON +UTMP +SYSVINIT default-hierarchy=hybrid)
[ 3.852621] systemd[1]: Detected architecture arm64.
rgds
nelakurthi
