Dear community,
Apalis IMX8
Ixora Carrier
TDX Wayland with XWayland 5.3.0-devel-20210730092438+build.0 (dunfell)
Apalis-iMX8_Reference-Multimedia-Image
I am getting 2 bugs from v4l2 drivers.
One of it is about hardware acc. encode:
GST_DEBUG=3 gst-launch-1.0 v4l2src device=/dev/video4 io-mode=dmabuf ! 'video/x-raw, format=(string)UYVY, width=720, height=480, framerate=30/1, interlace-mode=interleaved' ! deinterlace fields=1 method=2 ! videoconvert ! v4l2h264enc output-io-mode=dmabuf-import ! filesink location=dmaTest1.mp4 sync=false
output:
Setting pipeline to PAUSED ...
0:00:00.110224177 1830 0xaaaaec82e2d0 WARN v4l2 gstv4l2object.c:2031:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.110261551 1830 0xaaaaec82e2d0 WARN v4l2 gstv4l2object.c:2031:gst_v4l2_object_get_interlace_mode: Driver bug detected - check driver with v4l2-compliance from http://git.linuxtv.org/v4l-utils.git
0:00:00.110397924 1830 0xaaaaec82e2d0 WARN v4l2 gstv4l2object.c:4400:gst_v4l2_object_probe_caps:<v4l2h264enc0:src> Failed to probe pixel aspect ratio with VIDIOC_CROPCAP: Invalid argument
0:00:00.110666669 1830 0xaaaaec82e2d0 WARN v4l2 v4l2_calls.c:547:gst_v4l2_subscribe_event:<v4l2src0> Cannot subscribe V4L2_EVENT_SOURCE_CHANGE or V4L2_EVENT_EOS event for device '/dev/video4'.
Pipeline is live and does not need PREROLL ...
Setting pipeline to PLAYING ...
New clock: GstSystemClock
Redistribute latency...
0:00:00.125634762 1830 0xaaaaec84f320 WARN v4l2bufferpool gstv4l2bufferpool.c:813:gst_v4l2_buffer_pool_start:<v4l2src0:pool:src> Uncertain or not enough buffers, enabling copy threshold
0:00:00.125767135 1830 0xaaaaec84f320 ERROR v4l2allocator gstv4l2allocator.c:943:gst_v4l2_allocator_alloc_dmabuf:<v4l2src0:pool:src:allocator> Failed to export DMABUF: Inappropriate ioctl for device
0:00:00.125797884 1830 0xaaaaec84f320 ERROR v4l2bufferpool gstv4l2bufferpool.c:479:gst_v4l2_buffer_pool_alloc_buffer:<v4l2src0:pool:src> failed to allocate buffer
0:00:00.125824384 1830 0xaaaaec84f320 WARN bufferpool gstbufferpool.c:305:do_alloc_buffer:<v4l2src0:pool:src> alloc function failed
0:00:00.125849508 1830 0xaaaaec84f320 WARN bufferpool gstbufferpool.c:338:default_start:<v4l2src0:pool:src> failed to allocate buffer
0:00:00.125874133 1830 0xaaaaec84f320 ERROR v4l2bufferpool gstv4l2bufferpool.c:921:gst_v4l2_buffer_pool_start:<v4l2src0:pool:src> allocate failed
0:00:00.125898007 1830 0xaaaaec84f320 ERROR bufferpool gstbufferpool.c:559:gst_buffer_pool_set_active:<v4l2src0:pool:src> start failed
0:00:00.125932632 1830 0xaaaaec84f320 WARN v4l2src gstv4l2src.c:660:gst_v4l2src_decide_allocation:<v4l2src0> error: Failed to allocate required memory.
0:00:00.125960381 1830 0xaaaaec84f320 WARN v4l2src gstv4l2src.c:660:gst_v4l2src_decide_allocation:<v4l2src0> error: Buffer pool activation failed
0:00:00.126067129 1830 0xaaaaec84f320 WARN basesrc gstbasesrc.c:3292:gst_base_src_prepare_allocation:<v4l2src0> Subclass failed to decide allocation
0:00:00.126123128 1830 0xaaaaec84f320 WARN basesrc gstbasesrc.c:3072:gst_base_src_loop:<v4l2src0> error: Internal data stream error.
0:00:00.126152877 1830 0xaaaaec84f320 WARN basesrc gstbasesrc.c:3072:gst_base_src_loop:<v4l2src0> error: streaming stopped, reason not-negotiated (-4)
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Failed to allocate required memory.
Additional debug info:
../git/sys/v4l2/gstv4l2src.c(660): gst_v4l2src_decide_allocation (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
If i dont use io-mode=dmabuf and output-io-mode=dmabuf-import works fine.
Second problem i face is in the same debug output.
Every time i use v4l2 drivers from gstreamer or opencv it gives this warning.
As always, any help is highly appreciated.
