Dear community,
we ran into an issue using USB webcams on the Yocto built Linux 5.4.77: the v4l2-compliance test reports buffer-ioctls errors. Correspondingly, video capturing with gstreamers v4l2src does not work. It is worth noting, that the same hardware worked fine with the zeus based image (http://git.toradex.com/toradex-bsp-platform.git -b LinuxImage4.0). Please find detailed information regarding system setup, hardware, and error messages below. I will be glad to provide any additional info if required.
As always, any help is highly appreciated.
System Setup:
repo init -u https://git.toradex.com/toradex-manifest.git -b dunfell-5.x.y -m tdxref/default.xml
settings:
MACHINE ?= "colibri-imx6ull"
DISTRO = "poky-tiny"
the image is built as a fitImage, adding gstreamer software packages and v4l-utils.The used device tree is ‘wifi-aster’. The linux-toradex Kernel is configured to support USB video devices:
CONFIG_USB_VIDEO_CLASS=y
CONFIG_USB_GSPCA=y
CONFIG_V4L_PLATFORM_DRIVERS=y
CONFIG_VIDEO_MUX=y
CONFIG_SOC_CAMERA=y
CONFIG_VIDEO_MXC_CAPTURE=y
CONFIG_VIDEO_MXC_CSI_CAMERA=y
CONFIG_V4L_MEM2MEM_DRIVERS=y
CONFIG_VIDEO_IMX_VDOA=y
CONFIG_VIDEO_CODA=y
CRYPTO_DEV_FSL_CAAM_RNG_API=y
CONFIG_CMA_SIZE_MBYTES=256
Camera devices
We have tested the following webcams:
- Creative VF0700
- ELP ELP-USBFHD04H-L180
The error is the same for both devices.
Error message
Running v4l2-compliance -T -d /dev/video0:
v4l2-compliance SHA: not available, 32 bits
VIDIOC_G_SELECTION returned -1 (Invalid argument)
Compliance test for uvcvideo device /dev/video0:
Driver Info:
Driver name : uvcvideo
Card type : VF0700 Live! Cam Chat HD: VF070
Bus info : usb-ci_hdrc.0-1
Driver version : 5.4.77
Capabilities : 0x84a00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Required ioctls:
test VIDIOC_QUERYCAP: OK
Allow for multiple opens:
test second /dev/video0 open: OK
VIDIOC_S_PRIORITY returned -1 (Resource busy)
test VIDIOC_G/S_PRIORITY: OK
test for unlimited opens: OK
VIDIOC_QUERY_EXT_CTRL returned -1 (Invalid argument)
Debug ioctls:
VIDIOC_DBG_G_REGISTER returned -1 (Not a tty)
test VIDIOC_DBG_G/S_REGISTER: OK (Not Supported)
VIDIOC_LOG_STATUS returned -1 (Not a tty)
test VIDIOC_LOG_STATUS: OK (Not Supported)
Input ioctls:
VIDIOC_G_STD returned -1 (Not a tty)
VIDIOC_G_TUNER returned -1 (Not a tty)
test VIDIOC_G/S_TUNER/ENUM_FREQ_BANDS: OK (Not Supported)
VIDIOC_G_FREQUENCY returned -1 (Not a tty)
VIDIOC_S_FREQUENCY returned -1 (Not a tty)
test VIDIOC_G/S_FREQUENCY: OK (Not Supported)
VIDIOC_S_HW_FREQ_SEEK returned -1 (Not a tty)
test VIDIOC_S_HW_FREQ_SEEK: OK (Not Supported)
VIDIOC_ENUMAUDIO returned -1 (Not a tty)
test VIDIOC_ENUMAUDIO: OK (Not Supported)
VIDIOC_ENUMINPUT returned -1 (Invalid argument)
VIDIOC_S_INPUT returned -1 (Invalid argument)
test VIDIOC_G/S/ENUMINPUT: OK
VIDIOC_G_AUDIO returned -1 (Not a tty)
VIDIOC_S_AUDIO returned -1 (Not a tty)
test VIDIOC_G/S_AUDIO: OK (Not Supported)
Inputs: 1 Audio Inputs: 0 Tuners: 0
Output ioctls:
VIDIOC_G_MODULATOR returned -1 (Not a tty)
test VIDIOC_G/S_MODULATOR: OK (Not Supported)
VIDIOC_ENUMAUDOUT returned -1 (Not a tty)
test VIDIOC_ENUMAUDOUT: OK (Not Supported)
VIDIOC_G_OUTPUT returned -1 (Not a tty)
VIDIOC_ENUMOUTPUT returned -1 (Not a tty)
VIDIOC_S_OUTPUT returned -1 (Not a tty)
test VIDIOC_G/S/ENUMOUTPUT: OK (Not Supported)
test VIDIOC_G/S_AUDOUT: OK (Not Supported)
Outputs: 0 Audio Outputs: 0 Modulators: 0
Input/Output configuration ioctls:
VIDIOC_S_STD returned -1 (Not a tty)
VIDIOC_ENUMSTD returned -1 (Not a tty)
VIDIOC_QUERYSTD returned -1 (Not a tty)
test VIDIOC_ENUM/G/S/QUERY_STD: OK (Not Supported)
VIDIOC_G_DV_TIMINGS returned -1 (Not a tty)
VIDIOC_ENUM_DV_TIMINGS returned -1 (Not a tty)
VIDIOC_QUERY_DV_TIMINGS returned -1 (Not a tty)
test VIDIOC_ENUM/G/S/QUERY_DV_TIMINGS: OK (Not Supported)
VIDIOC_DV_TIMINGS_CAP returned -1 (Not a tty)
test VIDIOC_DV_TIMINGS_CAP: OK (Not Supported)
VIDIOC_G_EDID returned -1 (Not a tty)
VIDIOC_S_EDID returned -1 (Not a tty)
test VIDIOC_G/S_EDID: OK (Not Supported)
Control ioctls (Input 0):
VIDIOC_QUERYMENU returned -1 (Invalid argument)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-controls.cpp(216): missing control class for class 00980000
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-controls.cpp(253): missing control class for class 009a0000
test VIDIOC_QUERY_EXT_CTRL/QUERYMENU: FAIL
VIDIOC_QUERYCTRL returned -1 (Invalid argument)
VIDIOC_QUERYCTRL returned -1 (Invalid a[ 86.009362] uvcvideo: Failed to query (SET_CUR) UVC control 10 on unit 2: -32 (exp. 2).
rgument)
V[ 86.024106] uvcvideo: Failed to query (SET_CUR) UVC control 10 on unit 2: -32 (exp. 2).
test VIDIOC_QUERYCTRL: OK
VIDIOC_S_CTRL returned -1 (Result not representable)
VIDIOC_S_CTRL returned -1 (Invalid argument)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-controls.cpp(445): s_ctrl returned an error (22)
test VIDIOC_G/S_CTRL: FAIL
VIDIOC_S_EXT_CTRLS returned -1 (Invalid argument)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-controls.cpp(695): s_ext_ctrls returned an error (22)
test VIDIOC_G/S/TRY_EXT_CTRLS: FAIL
VIDIOC_DQEVENT returned -1 (Not a tty)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-controls.cpp(844): couldn't get event for control 'Brightness'
test VIDIOC_(UN)SUBSCRIBE_EVENT/DQEVENT: FAIL
VIDIOC_G_JPEGCOMP returned -1 (Not a tty)
VIDIOC_S_JPEGCOMP returned -1 (Not a tty)
test VIDIOC_G/S_JPEGCOMP: OK (Not Supported)
Standard Controls: 12 Private Controls: 0
Format ioctls (Input 0):
VIDIOC_ENUM_FMT returned -1 (Invalid argument)
VIDIOC_ENUM_FRAMEINTERVALS returned -1 (Invalid argument)
VIDIOC_ENUM_FRAMESIZES returned -1 (Invalid argument)
test VIDIOC_ENUM_FMT/FRAMESIZES/FRAMEINTERVALS: OK
VIDIOC_G_PARM returned -1 (Invalid argument)
VIDIOC_S_PARM returned -1 (Invalid argument)
warn: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1327): S_PARM is supported but doesn't report V4L2_CAP
_TIMEPERFRAME
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(1222): reserved not zeroed
test VIDIOC_G/S_PARM: FAIL
VIDIOC_G_FBUF returned -1 (Not a tty)
test VIDIOC_G_FBUF: OK (Not Supported)
VIDI[ 86.411239] uvcvideo: Failed to query (SET_CUR) UVC control 10 on unit 2: -32 (exp. 2).
OC_G_FMT returned -1 (Invalid argument)
VIDIOC_G_FMT returned -1 (Invalid argument)
VIDIOC_G_FMT returned -1 (Invalid ar[ 86.429357] uvcvideo: Failed to query (SET_CUR) UVC control 10 on unit 2: -32 (exp. 2).
gument)
test VIDIOC_G_FMT: OK
VIDIOC_TRY_FMT returned -1 (Invalid argument)
test VIDIOC_TRY_FMT: OK
VIDIOC_S_FMT returned -1 (Invalid argument)
VIDIOC_S_FMT returned -1 (Resource busy)
warn: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-formats.cpp(976): Could not set fmt2
test VIDIOC_S_FMT: OK
VIDIOC_G_SLICED_VBI_CAP returned -1 (Not a tty)
test VIDIOC_G_SLICED_VBI_CAP: OK (Not Supported)
VIDIOC_CROPCAP returned -1 (Invalid argument)
VIDIOC_G_CROP returned -1 (Invalid argument)
VIDIOC_S_SELECTION returned -1 (Not a tty)
test Cropping: OK (Not Supported)
test Composing: OK (Not Supported)
test Scaling: OK (Not Supported)
Codec ioctls (Input 0):
VIDIOC_ENCODER_CMD returned -1 (Not a tty)
test VIDIOC_(TRY_)ENCODER_CMD: OK (Not Supported)
VIDIOC_G_ENC_INDEX returned -1 (Not a tty)
test VIDIOC_G_ENC_INDEX: OK (Not Supported)
VIDIOC_DECODER_CMD returned -1 (Not a tty)
test VIDIOC_(TRY_)DECODER_CMD: OK (Not Supported)
Buffer ioctls (Input 0):
VIDIOC_REQBUFS returned -1 (Invalid argument)
VIDIOC_QUERYBUF returned -1 (Not a tty)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-buffers.cpp(610): q.reqbufs(node, 1)
test VIDIOC_REQBUFS/CREATE_BUFS/QUERYBUF: FAIL
VIDIOC_EXPBUF returned -1 (Resource busy)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-buffers.cpp(747): VIDIOC_EXPBUF is supported, but the V4L2_MEMORY_
MMAP support is missing or malfunctioning.
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-buffers.cpp(748): VIDIOC_EXPBUF is supported, but the V4L2_MEMORY_
MMAP support is missing, probably due to earlier failing format tests.
test VIDIOC_EXPBUF: OK (Not Supported)
fail: ../../../v4l-utils-1.18.1/utils/v4l2-compliance/v4l2-test-buffers.cpp(1833): ret != EINVAL && ret != EBADR && ret != ENOTTY
test Requests: FAIL
Total for uvcvideo device /dev/video0: 44, Succeeded: 37, Failed: 7, Warnings: 2
