For some reason I’m getting this error below.
Image size is lower than MMC, but it still complaints.
Could you please help me to debug it?
Thanks!
Error msg:
uuu (Universal Update Utility) for nxp imx chips -- libuuu_1.5.21-0-g1f42172
Success 0 Failure 1
3:43 6/ 8 [sparse image block size issue ] FB[-t 600000]: flash all someimage.img
setup:
Dahlia V1.1C
Verdin imx8m Plus Q 4GB WBIT / 16GB
info:
Verdin iMX8MP # mmcinfo
Device: FSL_SDHC
Manufacturer ID: 13
OEM: 4e
Bus Speed: 200000000
Mode: HS400 (200MHz)
Rd Block Len: 512
MMC version 5.1
High Capacity: Yes
Capacity: 14.8 GiB
Bus Width: 8-bit DDR
Erase Group Size: 512 KiB
HC WP Group Size: 8 MiB
User Capacity: 14.8 GiB WRREL
Boot Capacity: 31.5 MiB ENH
RPMB Capacity: 4 MiB ENH
Boot area 0 is not write protected
Boot area 1 is not write protected
Verdin iMX8MP # mmc list
FSL_SDHC: 1
FSL_SDHC: 2 (eMMC)
Verdin iMX8MP # mmc hwpartition
Partition configuration:
No enhanced user data area
No GP1 partition
No GP2 partition
No GP3 partition
No GP4 partition
Verdin iMX8MP # mmc part
Partition Map for MMC device 2 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type
1 2048 131072 0039cd6f-01 0c Boot
2 133120 1048576 0039cd6f-02 83
3 1181696 22243503 0039cd6f-03 8e
-rw-r--r-- 1 user users 13993705472 Jun 20 14:03 image-ARM64-test.raw.img
cat uuu.auto_bkp
uuu_version 1.4.43
SDPS: boot -f imx-boot
CFG: FB: -vid 0x0525 -pid 0x4000
CFG: FB: -vid 0x0525 -pid 0x403a
CFG: FB: -vid 0x0525 -pid 0x403d
CFG: FB: -vid 0x0525 -pid 0x403f
CFG: FB: -vid 0x0525 -pid 0x4040
CFG: FB: -vid 0x0525 -pid 0x4041
CFG: FB: -vid 0x0525 -pid 0x4042
FB: ucmd setenv fastboot_dev mmc
FB: ucmd setenv emmc_dev 2
FB: ucmd mmc dev ${emmc_dev}
FB: flash bootloader some-boot-file
FB: ucmd mmc partconf ${emmc_dev} 1 1 0
FB[-t 600000]: flash all image-ARM64-test.img
FB: reboot
FB: done
screen logs:
Detect USB boot. Will enter fastboot mode!
Net: eth1: ethernet@30be0000, eth0: ethernet@30bf0000 [PRIME]
Fastboot: Normal
Boot from USB for mfgtools
*** Warning - Use default environment for mfgtools
, using default environment
Run bootcmd_mfg: fastboot 0
flash target is MMC:2
request 00000000fdf4e3c0 was not queued to ep1in-bulk
switch to partitions #0, OK
mmc2(part 0) is current device
Starting download of 1331760 bytes
downloading of 1331760 bytes finished
writing to partition 'bootloader'
Initializing 'bootloader'
switch to partitions #1, OK
mmc2(part 1) is current device
Writing 'bootloader'
MMC write: dev # 2, block # 0, count 2602 ... 2602 blocks written: OK
Writing 'bootloader' DONE!
Starting download of 16765472 bytes
downloading of 16765472 bytes finished
writing to partition 'all'
sparse flash target is mmc:2
writing to partition 'all' for sparse, buffer size 16765472
Flashing sparse image at offset 0
Flashing Sparse Image
........ wrote 228261888 bytes to 'all'
Starting download of 2666938 bytes
downloading of 2666938 bytes finished
writing to partition 'all' for sparse, buffer size 2666938
write_sparse_image: Sparse image block size issue [32523]
