started VS2015 und tried to use some remote Tools (remote file Viewer) just to see the Connection working, but … no Response. I used the remote Tools on this PC with other products, no Problem.
Where to look into?
With best regards
Gerhard
Where to look into?
With best regards
Gerhard
oh, I have to start the Debugger Client on the device manually, thats the difference.
From the Task bar: Start/Programs/Colibri Tools/Start Debugger Client.
And the currently assigned IP address is displayd also.
Sorry.
Hi @Gerhard
There’s some setup required to use the Visual Studio Remote Tools, and there’s a number of known issues related to these tools. Please refer to the following post:
To work on a headless device, I recommend to use the Remote Display V3, which allows you to interact with the WinCe device as if you had a real screen and keyboard connected.
Regards, Andy
Hi Andy,
ok, sounds nice, will give it a try now.
With best regards
Gerhard
