Using USB webcam on Colibri iMX8X
I’m trying to get a USB webcam to run on a Colibri iMX8X, but - as I don’t know much about Linux, Docker OR Portainer - am stuck and can’t really tell what to search for / try next.
My goal is to eventually display the webcam feed in a Python (PySide) GUI and be able to take pictures. For that, I managed to make a project using the VS Code plugin with a Weston container and a Pyside2 container that currently displays an empty GUI trying to display webcam images using OpenCV.
Please bare with me, this is an experimental project, someone else set up the hardware many months ago and I only really know my way around the Python parts of all this.
Trying to follow How to use cameras on Torizon and other things I googled, I added permissions and mounts to my docker compose file and v4l-utils to my Dockerfile:
docker-compose.yml
#version: "3.9"
services:
  pyside-container-debug:
    build:
      context: .
      dockerfile: Dockerfile.debug
    image: ${LOCAL_REGISTRY}:5002/pyside-container-debug:${TAG}
    ports:
      - ${DEBUG_SSH_PORT}:${DEBUG_SSH_PORT}
      - ${DEBUG_PORT1}:${DEBUG_PORT1}
    volumes:
      - type: bind
        source: /tmp
        target: /tmp
      - type: bind
        source: /dev
        target: /dev
      # for camera access:
      - type: bind
        source: /sys
        target: /sys
      - type: bind
        source: /var/run/dbus
        target: /var/run/dbus
    # trying to add webcam:
    devices:
      #- /dev/video0:/dev/video0
      #- /dev/video0:/dev/video1
      #- /dev/video0:/dev/video2
      #- /dev/video0:/dev/video3
      - /dev/video0:/dev/video4
      - /dev/video0:/dev/video5
      - /dev/video0:/dev/video6
      - /dev/video0:/dev/video7
    device_cgroup_rules:
      # ... for tty
      - "c 4:* rmw"
      # ... for /dev/input devices
      - "c 13:* rmw"
      - "c 199:* rmw"
      # ... for /dev/dri devices
      - "c 226:* rmw"
    depends_on: [
      weston
  weston:
    image: commontorizon/weston${GPU}:3.3.2
    environment:
      - ACCEPT_FSL_EULA=1
    # Required to get udev events from host udevd via netlink
    network_mode: host
    volumes:
      - type: bind
        source: /tmp
        target: /tmp
      - type: bind
        source: /dev
        target: /dev
      - type: bind
        source: /run/udev
        target: /run/udev
      - type: bind
        source: /sys
        target: /sys
      - type: bind
    devices:
    cap_add:
      - CAP_SYS_TTY_CONFIG
    # Add device access rights through cgroup...
      # ... for tty
      - "c 4:* rmw"
      - "c 13:* rmw"
      - "c 199:* rmw"
      - "c 226:* rmw"
Dockerfile.debug
# ARGUMENTS --------------------------------------------------------------------
# Board architecture
ARG IMAGE_ARCH=
# Base container version
ARG BASE_VERSION=3.3.1
# Debug port
ARG DEBUG_SSH_PORT=
# Run as
ARG SSHUSERNAME=
# Directory of the application inside container
ARG APP_ROOT=
# Board GPU vendor prefix
ARG GPU=
FROM --platform=linux/${IMAGE_ARCH} \
     commontorizon/qt5-wayland${GPU}:${BASE_VERSION} AS debug
ARG IMAGE_ARCH
ARG GPU
ARG DEBUG_SSH_PORT
ARG SSHUSERNAME
ARG APP_ROOT
# SSH for remote debug
EXPOSE ${DEBUG_SSH_PORT}
EXPOSE 6512
ENV QT_QPA_PLATFORM="wayland"
# Make sure we don't get notifications we can't answer during building.
ENV DEBIAN_FRONTEND="noninteractive"
# for vivante GPU we need some "special" sauce
RUN apt-get -q -y update && \
        if [ "${GPU}" = "-vivante" ] || [ "${GPU}" = "-imx8" ]; then \
            apt-get -q -y install \
            imx-gpu-viv-wayland-dev \
        ; else \
            libgl1 \
        ; fi \
    apt-get clean && apt-get autoremove && \
    rm -rf /var/lib/apt/lists/*
# your regular RUN statements here
# Install required packages
    v4l-utils \
    openssl \
    openssh-server \
    rsync \
    file \
    screen \
    python3-minimal \
    python3-pip \
    python3-setuptools \
    python3-venv \
    qml-module-qtquick-controls \
    qml-module-qtquick-controls2 \
    qml-module-qtquick2 \
    python3-pyside2.qtwidgets \
    python3-pyside2.qtgui \
    python3-pyside2.qtqml \
    python3-pyside2.qtcore \
    python3-pyside2.qtquick \
    python3-pyside2.qtnetwork \
    qml-module-qtquick-dialogs \
    qtwayland5 \
    && apt-get clean && apt-get autoremove && \
# edge case for amd64
# this prevent the error: texture atlas allocation failed
    if [ "${IMAGE_ARCH}" = "amd64" ]; then \
        libqt5quick5 \
    ; fi \
# automate for torizonPackages.json
# DO NOT REMOVE THIS LABEL: this is used for VS Code automation
    # __torizon_packages_dev_start__
    # __torizon_packages_dev_end__
# Create virtualenv
RUN python3 -m venv ${APP_ROOT}/.venv --system-site-packages
# Install pip packages on venv
COPY requirements-debug.txt /requirements-debug.txt
RUN . ${APP_ROOT}/.venv/bin/activate && \
    pip3 install --upgrade pip && pip3 install -r requirements-debug.txt && \
    rm requirements-debug.txt
# ⚠️ DEBUG PURPOSES ONLY!!
# THIS CONFIGURES AN INSECURE SSH CONNECTION
# create folders needed for the different components
# configures SSH access to the container and sets environment by default
RUN mkdir /var/run/sshd && \
    sed 's@session\s*required\s*pam_loginuid.so@session optional pam_loginuid.so@g' \
        -i /etc/pam.d/sshd && \
    if test $SSHUSERNAME != root ; \
        then mkdir -p /home/$SSHUSERNAME/.ssh ; \
        else mkdir -p /root/.ssh ; fi && \
    echo "PermitUserEnvironment yes" >> /etc/ssh/sshd_config && \
    echo "PermitRootLogin yes" >> /etc/ssh/sshd_config && \
    echo "Port ${DEBUG_SSH_PORT}" >> /etc/ssh/sshd_config && \
    echo "PasswordAuthentication yes" >> /etc/ssh/sshd_config && \
    echo "PermitEmptyPasswords yes" >> /etc/ssh/sshd_config && \
    su -c "env" $SSHUSERNAME > /etc/environment && \
    echo "$SSHUSERNAME:" | chpasswd -e
RUN rm -r /etc/ssh/ssh*key && \
    dpkg-reconfigure openssh-server
# Copy the application source code in the workspace to the $APP_ROOT directory
# path inside the container, where $APP_ROOT is the torizon_app_root
# configuration defined in settings.json
COPY --chown=$SSHUSERNAME:$SSHUSERNAME ./src ${APP_ROOT}/src
CMD [ "/usr/sbin/sshd", "-D" ]
I commented out devices 0-3 because of the output of these two commands, not sure if that’s correct:
devices
torizon@colibri-imx8x-07329158:~$ ls -ltrh /dev/video*
crw-rw---- 1 root video 81, 1 Dec 18 17:17 /dev/video1
crw-rw---- 1 root video 81, 0 Dec 18 17:17 /dev/video0
crw-rw---- 1 root video 81, 3 Dec 18 17:17 /dev/video3
crw-rw---- 1 root video 81, 2 Dec 18 17:17 /dev/video2
crw-rw---- 1 root video 81, 5 Jan  8 11:21 /dev/video5
crw-rw---- 1 root video 81, 6 Jan  8 11:21 /dev/video6
crw-rw---- 1 root video 81, 4 Jan  8 11:21 /dev/video4
crw-rw---- 1 root video 81, 7 Jan  8 11:21 /dev/video7
torizon@colibri-imx8x-07329158:~$ for I in /sys/class/video4linux/*; do cat $I/name; done
amphion-vpu-decoder
amphion-vpu-encoder
mxc-jpeg-dec
mxc-jpeg-enc
Logitech BRIO
Logitech BRIO
Logitech BRIO
Logitech BRIO
Plugging in the webcam, dmesg says this:
[ 3889.518830] usb 1-1.2.1.3.2: Found UVC 1.00 device Logitech BRIO (046d:085e)
[ 3889.524534] input: Logitech BRIO as /devices/platform/bus@5b000000/5b110000.usb/5b130000.usb/xhci-hcd.1.auto/usb1/1-1/1-1.2/1-1.2.1/1-1.2.1.3/1-1.2.1.3.2/1-1.2.1.3.2:1.0/input/input9
Running v4l2-ctl --list-devices doesn’t print anything for the webcam though:
amphion vpu decoder (platform: amphion-vpu):
        /dev/video0
I don’t really know where to go from here. I’m not sure if I even need the v4l stuff (rather GStreamer?), but what it currently prints indicates to me that the webcam isn’t correctly recognized.
How to get it to do that I don’t know, some threads on this forum make it sound like it should “just work”.
I’m also confused by the users. The output from v4l2-ctl I got using a “Container console” on Portainer running as root user, whereas when ssh-ing with the torizon user (the other console outputs I posted), v4l2-ctl is an unrecognized command.
tdx-info Output
Software summary
Kernel version:           5.15.129-6.5.0+git.6f8fd49366db #1-TorizonCore SMP PREEMPT Fri Dec 22 11:15:52 UTC 2023
Kernel command line:      root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/7e7d5c182b8db9a981d1f942cee2a808b3535fa86862471d67f718c4959f44df/0
Distro version:           VERSION_ID=6.5.0-build.8
Hostname:                 colibri-imx8x-07329158
Hardware info
HW model:                 Toradex Colibri iMX8QXP on Colibri Evaluation Board V3
Toradex version:          0038 V1.0D
Serial number:            07329158
To successfully use a USB webcam with your Colibri iMX8X module and display the feed in a Python GUI, you’ll need to ensure your Docker containers are properly configured to access the webcam hardware. Here’s a step-by-step guide to help you troubleshoot and set up your system:
1. Verify Webcam Recognition
  • Check Device Detection: Use dmesg to confirm that the webcam is detected when plugged in. Your logs indicate that the Logitech BRIO is recognized.
  • List Video Devices: Run ls /dev/video* to see available video devices. Your output shows multiple /dev/videoX entries, which is typical.
2. Configure Docker Containers
  • Map the Correct Device: In your docker-compose.yml, ensure you map the correct /dev/videoX device to the container. For instance, if /dev/video4 is your webcam, map it as - /dev/video4:/dev/video0 inside the container.
  • Simplify Device Mappings: Remove unnecessary device mappings to avoid confusion.
3. Set Device Permissions
  • User Permissions: Ensure the user running the container has permissions to access video devices. You might need to add the user to the video group or run the container with elevated privileges.
4. Test with GStreamer
  • GStreamer Pipeline: Use GStreamer to test the video stream:
    gst-launch-1.0 v4l2src device=/dev/video0 ! videoconvert ! autovideosink
    This command should display the webcam feed if everything is configured correctly.
5. Integrate with Python and OpenCV
  • OpenCV Setup: Once the webcam is accessible, use OpenCV in your Python application to capture and display video. Ensure OpenCV is installed in your container and use the cv2.VideoCapture class to access the video stream.
6. Address User and Command Confusion
  • Command Availability: The v4l2-ctl command should be available if v4l-utils is installed in the container. Make sure you are executing commands in the correct environment (container vs. host).
By following these steps, you should be able to configure your setup to access and display the webcam feed in your Python GUI. If issues persist, double-check device mappings and permissions, and ensure all necessary software components are correctly installed in your containers.
Toradex AI Assistant
https://www.toradex.com/computer-on-modules/colibri-arm-family/nxp-imx-8x
Display output from mipi camera.
Okay, I believe I am a step further, after adding - "c 81:* rmw" to the device_cgroup_rules sections in the compose file (got the 81 from ls -l /dev/video* following this article), v4l2 now outputs this:
root@64bc7770d04f:/# v4l2-ctl --list-devices
        /dev/video0
        /dev/video1
mxc-jpeg codec (platform:58400000.jpegdec):
        /dev/video2
mxc-jpeg codec (platform:58450000.jpegenc):
        /dev/video3
Logitech BRIO (usb-xhci-hcd.1.auto-1.2.1.3.2):
        /dev/video4
        /dev/video5
        /dev/video6
        /dev/video7
…but also
v4l2-ctl -D
root@64bc7770d04f:/# v4l2-ctl -D
Driver Info:
        Driver name      : amphion-vpu
        Card type        : amphion vpu decoder
        Bus info         : platform: amphion-vpu
        Driver version   : 5.15.129
        Capabilities     : 0x84204000
                Video Memory-to-Memory Multiplanar
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps      : 0x04204000
                Streaming
                Extended Pix Format
…which I interpret as the “amphion-vpu” device being used instead of my webcam, even when I remove all devices apart from /dev/video4 in the compose file.
Specifying video4 gives this output:
v4l2-ctl --device 4 -D
root@64bc7770d04f:/# v4l2-ctl --device 4 -D
Driver Info:
        Driver name      : uvcvideo
        Card type        : Logitech BRIO
        Bus info         : usb-xhci-hcd.1.auto-1.2.1.3.2
        Capabilities     : 0x84a00001
                Video Capture
                Metadata Capture
                Streaming
                Extended Pix Format
                Device Capabilities
        Device Caps      : 0x04200001
                Video Capture
                Streaming
                Extended Pix Format
…notably missing the “Media Driver Info” parts that are shown on the How to use cameras on Torizon page.
Oof. After adding the gstreamer libs to the Dockerfile (except for gstreamer1.0-doc which produced an error) and successfully getting a webcam stream using
gst-launch-1.0 v4l2src device='/dev/video3' ! "video/x-raw, format=YUY2, framerate=5/1, width=640, height=480" ! fpsdisplaysink video-sink=waylandsink text-overlay=false sync=false
from the documentation page, I now can’t debug my container anymore (I always use VS Code’s Run > Start Debugging because I don’t know what to call manually), always get this error:
connect ECONNREFUSED 192.168.178.89:6512
Help please?
Hi @uwdlg
Thanks for this very detailed explanation of the issue.
That’s a lot of information, so I’m going to go one step at a time.
I actually did a very similar project some time ago, I’m going to attach the files here, maybe it can provide some insights for your development.
Dockerfile
ARG IMAGE_ARCH=arm64
ARG BASE_VERSION=3.2.1
ARG APP_ROOT="mpu-test_cv2"
ARG GPU="-vivante"
     torizon/qt5-wayland${GPU}:${BASE_VERSION} AS deploy
ARG IMAGE_ARCH
ARG GPU
ARG APP_ROOT
        ; else \
            libgl1 \
        ; fi \
# Install python packages
    python3-minimal \
    python3-pip \
    python3-dev \
    python3-venv \
    python3-pyside2.qtmultimedia \
    python3-pyside2.qtmultimediawidgets \
# Install pyqt packages
    qtwayland5 \
    qtmultimedia5-dev \
    qml-module-qtmultimedia \
    libqt5multimedia5-plugins \
# Install gstream packages
RUN apt-get -y update && apt-get install -y --no-install-recommends libgstreamer1.0-0 \
    gstreamer1.0-plugins-base gstreamer1.0-plugins-good gstreamer1.0-plugins-bad \
    gstreamer1.0-plugins-ugly gstreamer1.0-tools gstreamer1.0-OpenCV \
    python3-gst-1.0 gstreamer1.0-rtsp libgstrtspserver-1.0-0 gir1.2-gst-rtsp-server-1.0 && \
    apt-get clean && apt-get autoremove && rm -rf /var/lib/apt/lists/*
# Install others packages
    build-essential \
    libcairo2-dev \
    libgirepository1.0-dev \
    v4l-utils \
    rsync \
    nano \
# Create virtualenv
COPY requirements-release.txt /requirements-release.txt
    pip3 install --upgrade pip && pip3 install --break-system-packages -r requirements-release.txt && \
    rm requirements-release.txt
USER torizon
COPY ./src ${APP_ROOT}/src
WORKDIR ${APP_ROOT}
ENV APP_ROOT=${APP_ROOT}
ENV QT_DEBUG_PLUGINS=0
ENV GST_PLUGIN_SCANNER="usr/lib/aarch64-linux-gnu/gstreamer1.0/gstreamer-1.0/gst-plugin-scanner"
# Activate and run the code
CMD . .venv/bin/activate && python3 src/main.py --no-sandbox
docker-compose.yml
version: '3.8'
services:
  weston:
    image: torizon/weston:${CT_TAG_WESTON}
    container_name: weston
    network_mode: host
    cap_add:
    volumes:
      - /dev:/dev
      - /tmp:/tmp
      - /run/udev:/run/udev
    devices:
      - "/dev/tty7:/dev/tty7"
      - 'c 4:* rmw'
      - 'c 13:* rmw'
      - 'c 199:* rmw'
      - 'c 226:* rmw'
    command: --developer weston-launch --tty=/dev/tty7 --user=torizon
  mpu:
    image: <my_image>
    container_name: mpu
    network_mode: host
    cap_add:
    volumes:
      - /dev:/dev
      - /tmp:/tmp
      - /var/run/dbus:/var/run/dbus
      - /dev/galcore:/dev/galcore
    environment:
      ACCEPT_FSL_EULA: '1'
      MPU_I2C_BUS: '4'
      MPU_DEVICE_ADDRESS: '0x69'
      MPU_dt: 0.001
    privileged: true
    depends_on:
      - weston
video.py
from PySide2.QtWidgets import QApplication, QWidget, QLabel, QVBoxLayout
from PySide2.QtGui import QImage, QPixmap
from PySide2.QtCore import Qt, QThread, Signal, QByteArray, QDataStream, QBuffer
import numpy as np
import gi
gi.require_version('Gst', '1.0')
from gi.repository import Gst, GObject
import sys
# Initialize GStreamer
Gst.init(None)
class VideoThread(QThread):
    frame_data_signal = Signal(bytes)
    width  = 1280
    height = 720
    def __init__(self, parent=None):
        super(VideoThread, self).__init__(parent)
        self.pipeline = None
    def run(self):
        # Set up the GStreamer pipeline
        self.pipeline = Gst.parse_launch(
            f"v4l2src device=/dev/video0 ! videoconvert ! video/x-raw,format=RGB,width={self.width},height={self.height} ! appsink name=sink emit-signals=True"
        appsink = self.pipeline.get_by_name("sink")
        appsink.connect("new-sample", self.on_new_sample, appsink)
        # Start playing
        self.pipeline.set_state(Gst.State.PLAYING)
        # Run the GStreamer main loop
        loop = GObject.MainLoop()
        loop.run()
    def on_new_sample(self, sink, data):
        sample = sink.emit("pull-sample")
        if sample:
            buffer = sample.get_buffer()
            # Map the buffer to a readable format
            success, map_info = buffer.map(Gst.MapFlags.READ)
            if success:
                frame_data = map_info.data
                print(type(frame_data))
                self.frame_data_signal.emit(bytes(frame_data))
                # Unmap the buffer
                buffer.unmap(map_info)
            return Gst.FlowReturn.OK
    def stop_pipeline(self):
        if self.pipeline:
            self.pipeline.set_state(Gst.State.NULL)
class VideoPlayer(QWidget):
    width  = 1280
    height = 720
    def __init__(self):
        super(VideoPlayer, self).__init__()
        self.video_thread = VideoThread(self)
        self.label = QLabel(self)
        self.label.setAlignment(Qt.AlignCenter)
        layout = QVBoxLayout(self)
        layout.addWidget(self.label)
        self.video_thread.frame_data_signal.connect(self.update_frame)
        self.video_thread.start()
    def update_frame(self, frame_data):
        # Convert frame data to a NumPy array
        # frame_array = np.frombuffer(frame_data.data(), dtype=np.uint8).reshape((self.height, self.width, 3))
        # frame_rgb = (frame_array).copy(order='C')
        qimage = QImage(frame_data, self.width, self.height, QImage.Format_RGB888)
        # Set the image in the QLabel
        pixmap = QPixmap.fromImage(qimage)
        self.label.setPixmap(pixmap)
    def closeEvent(self, event):
        self.video_thread.stop_pipeline()
        self.video_thread.wait()
        event.accept()
In my example, I used the -v /dev:/dev and privileged: true. This basically gives to the container full permissions and full access to all the devices, which is not a best practice but may help you to debug during development stage.
I recommend taking a while to understand the general concept of a container.
But in a few words, the container is an environment isolated from your linux environment. So it don’t have access to your devices, such as a camera, unless you explicit allow it. This also includes libraries, binaries, files and everything.
Thank you for answering!
All my problems now seem to be related to gstreamer. Whenever I add the packages to the Dockerfile (I also tried the subset from yours, moving them to before/after other packages are installed), I get the “connection refused” error I described when I hit Start Debugging. I can’t tell what the underlying problem is, I’m unsure how to get more helpful error messages when debugging fails.
I believe I can rule out any network changes or errors from my python file running into a timeout as debugging always works again as soon as I remove the gstreamer packages from the Dockerfile.
I also tried creating a new project and copied in your files, but when I debug that (after removing the leftover numpy import) it doesn’t get past the gstreamer import:
Exception has occurred: ModuleNotFoundError
No module named 'gi'
Debugging still doesn’t work, but the container is launched and the application src copied over, so I can manually run the application from a container console (works for a trivial QT GUI). However now I’m stuck getting opencv installed. I tried adding python3-opencv to the RUN apt-get -q -y update && apt-get -q -y install… statement after the other python3- packages in Dockerfile.debug, but my python file still complains about the import:
> python3 main.py
  File "/home/torizon/app/src/main.py", line 6, in <module>
    import cv2
  File "/usr/lib/python3/dist-packages/shiboken2/files.dir/shibokensupport/feature.py", line 139, in _import
    return original_import(name, *args, **kwargs)
ModuleNotFoundError: No module named 'cv2'
…and apt list --installed doesn’t list any opencv packages (it does list all the gstreamer packages btw). Next I tried adding it via torizonPackages.json:
  "prodRuntimeDeps": [],
  "devRuntimeDeps": [
    "python3-opencv"
…which produces the following terminal output when I hit Start Debugging:
> RUN apt-get -q -y update && apt-get -q -y install python3-opencv:arm64 && apt-get clean && apt-get autoremove && rm -rf
#10 [pyside-embedded-world-container-debug  6/12] RUN apt-get -q -y update &&     apt-get -q -y install             python3-opencv:arm64     &&     apt-get clean && apt-get autoremove &&     rm -rf /var/lib/apt/lists/*
#10 0.916 Get:1 http://deb.debian.org/debian bookworm InRelease [151 kB]
#10 1.015 Get:2 http://deb.debian.org/debian bookworm-updates InRelease [55.4 kB]
#10 1.074 Get:3 http://deb.debian.org/debian-security bookworm-security InRelease [47.9 kB]
#10 1.117 Get:4 https://feeds.toradex.com/debian/snapshots/20240116T145428Z testing InRelease [15.1 kB]
#10 2.066 Get:5 http://deb.debian.org/debian bookworm/main arm64 Packages [8693 kB]
#10 4.028 Get:6 http://deb.debian.org/debian bookworm-updates/main arm64 Packages [13.3 kB]
#10 4.172 Get:7 http://deb.debian.org/debian-security bookworm-security/main arm64 Packages [237 kB]
#10 4.766 Get:8 https://feeds.toradex.com/debian/snapshots/20240116T145428Z testing/non-free arm64 Packages [5573 B]
#10 4.796 Get:9 https://feeds.toradex.com/debian/snapshots/20240116T145428Z testing/main arm64 Packages [59.9 kB]
#10 7.531 Fetched 9278 kB in 7s (1360 kB/s)
#10 7.531 Reading package lists...
#10 10.73 Reading package lists...
#10 13.80 Building dependency tree...
#10 14.33 Reading state information...
#10 14.80 python3-opencv is already the newest version (4.6.0+dfsg-10+toradex1).
#10 14.80 0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
#10 15.01 Reading package lists...
#10 18.18 Building dependency tree...
#10 18.73 Reading state information...
#10 19.20 0 upgraded, 0 newly installed, 0 to remove and 17 not upgraded.
#10 DONE 19.3s
…making it sound like it should already be installed, but isn’t?
Also trying to manually install it from the container console gives:
> apt install python3-opencv
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
E: Unable to locate package python3-opencv
How do I get it in there?
Hi @uwdlg
Sorry, I forgot to include the pip dependencies. You need to add pygobject the to the requirements-release.txt
pip install pygobject
In my Dockerfile, I install it after installing libcairo2-dev and libgirepository1.0-dev.
Sorry, things are getting a little confusing here. I don’t know at which point you are now.
I’m going to try to explain about the dependencies.
There’s 2 “supported” ways to add your packages:
  1. Using the torizonPackages.json:
    You are going to install the python3-opencv package from the Debian apt
  2. Using the requirements-release.txt:
    You are going to install the opencv-python package from Python pip inside a virtual environment venv
By “manually installing” you mean you attached the container and is running this command inside the container right?
You need to first run, to update the local package index.
apt update
So somehow the opencv problem magically went away when I tried again (without changing anything) the next day and I finally have a webcam image.
The problem with no more debugging as soon as gstreamer is in the mix still remains though.
Hi @uwdlg
Happy to know that you were able to get the opencv with gstreamer pipeline working. :grinning:
We just updated this page with a video instruction that can help you in debugging.
Check the Troubleshoot Execution Errors - Debug section to see how you can access the container logs.
You should be able to see any printing messages or execution error there.
Hi @uwdlg.
Given that you were able to solve your initial issue. I’m going to mark this thread as solved.
Feel free to open a new thread if you have more questions. :grinning:
