I have a Colibri-IMX8X module with a custom carrier board.
I am trying to configure UART2 for debug output instead of UART 3.
I have made the following changes:
diff --git a/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi b/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi
index 84417d0ea6..2abf6b8129 100644
--- a/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi
+++ b/arch/arm/dts/fsl-imx8qxp-colibri-u-boot.dtsi
@@ -92,7 +92,7 @@
u-boot,dm-pre-proper;
-&pd_dma_lpuart3 {
+&pd_dma_lpuart2 {
@@ -175,7 +175,7 @@
-&lpuart3 {
+&lpuart2 {
iff --git a/arch/arm/dts/fsl-imx8qxp-colibri.dts b/arch/arm/dts/fsl-imx8qxp-colibri.dts
index a672347e1a..7ee5208803 100644
--- a/arch/arm/dts/fsl-imx8qxp-colibri.dts
+++ b/arch/arm/dts/fsl-imx8qxp-colibri.dts
@@ -12,8 +12,8 @@
compatible = "toradex,colibri-imx8x", "fsl,imx8qxp";
chosen {
- bootargs = "console=ttyLP3,115200 earlycon=lpuart32,0x5a090000,115200";
- stdout-path = &lpuart3;
+ bootargs = "console=ttyLP2,115200 earlycon=lpuart32,0x5a080000,115200";
+ stdout-path = &lpuart2;
reg_usbh_vbus: regulator-usbh-vbus {
@@ -57,6 +57,13 @@
+ pinctrl_lpuart2: lpuart2grp {
+ fsl,pins = <
+ SC_P_UART2_RX_ADMA_UART2_RX 0X06000020
+ SC_P_UART2_TX_ADMA_UART2_TX 0X06000020
pinctrl_fec1: fec1grp {
fsl,pins = <
SC_P_COMP_CTL_GPIO_1V8_3V3_ENET_ENETB0_PAD 0x000014a0 /* Use pads in 3.3V mode */
@@ -88,10 +95,10 @@
pinctrl_hog1: hog1grp {
fsl,pins = <
- SC_P_QSPI0A_DATA1_LSIO_GPIO3_IO10 0x00000020 /* 45 */
+ SC_P_QSPI0A_DATA1_LSIO_GPIO3_IO10 0x02000020 /* 45 */
SC_P_ENET0_RGMII_TXD3_LSIO_GPIO5_IO02 0x06000020 /* 65 */
SC_P_CSI_D07_CI_PI_D09 0x00000061
- SC_P_QSPI0A_DATA2_LSIO_GPIO3_IO11 0x00000020 /* 69 */
+ SC_P_QSPI0A_DATA2_LSIO_GPIO3_IO11 0x02000020 /* 69 */
SC_P_QSPI0A_DQS_LSIO_GPIO3_IO13 0x00000020 /* 73 */
SC_P_SAI0_TXC_LSIO_GPIO0_IO26 0x00000020 /* 79 */
SC_P_CSI_D02_CI_PI_D04 0x00000061
@@ -112,7 +119,7 @@
SC_P_USB_SS3_TC1_LSIO_GPIO4_IO04 0x00000020 /* 133 */
SC_P_CSI_PCLK_LSIO_GPIO3_IO00 0x00000020 /* 96 */
SC_P_QSPI0B_DATA3_LSIO_GPIO3_IO21 0x00000020 /* 98 */
- SC_P_SAI1_RXFS_LSIO_GPIO0_IO31 0x00000020 /* 100 */
+ SC_P_SAI1_RXFS_LSIO_GPIO0_IO31 0x02000020 /* 100 */
SC_P_QSPI0B_DQS_LSIO_GPIO3_IO22 0x00000020 /* 102 */
SC_P_QSPI0B_SS0_B_LSIO_GPIO3_IO23 0x00000020 /* 104 */
SC_P_QSPI0B_SS1_B_LSIO_GPIO3_IO24 0x00000020 /* 106 */
@@ -267,6 +274,12 @@
&lpuart3 {
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_lpuart3>, <&pinctrl_lpuart3_ctrl>;
+ status = "disabled";
+&lpuart2 {
+ pinctrl-names = "default";
+ pinctrl-0 = <&pinctrl_lpuart2>;
diff --git a/board/toradex/colibri-imx8x/colibri-imx8x.c b/board/toradex/colibri-imx8x/colibri-imx8x.c
index 36bc85fdf0..7cf06771b2 100644
--- a/board/toradex/colibri-imx8x/colibri-imx8x.c
+++ b/board/toradex/colibri-imx8x/colibri-imx8x.c
@@ -32,16 +32,14 @@ static struct gpio_desc gpio_usb_cdet;
(SC_PAD_28FDSOI_DSE_DV_HIGH << PADRING_DSE_SHIFT) | \
(SC_PAD_28FDSOI_PS_PU << PADRING_PULL_SHIFT))
-static iomux_cfg_t uart3_pads[] = {
- SC_P_FLEXCAN2_RX | MUX_MODE_ALT(2) | MUX_PAD_CTRL(UART_PAD_CTRL),
- SC_P_FLEXCAN2_TX | MUX_MODE_ALT(2) | MUX_PAD_CTRL(UART_PAD_CTRL),
- /* Transceiver FORCEOFF# signal, mux to use pull-up */
- SC_P_QSPI0B_DQS | MUX_MODE_ALT(4) | MUX_PAD_CTRL(UART_PAD_CTRL),
+static iomux_cfg_t uart2_pads[] = {
+ SC_P_UART2_RX | MUX_PAD_CTRL(UART_PAD_CTRL),
+ SC_P_UART2_TX | MUX_PAD_CTRL(UART_PAD_CTRL),
static void setup_iomux_uart(void)
- imx8_iomux_setup_multiple_pads(uart3_pads, ARRAY_SIZE(uart3_pads));
+ imx8_iomux_setup_multiple_pads(uart2_pads, ARRAY_SIZE(uart2_pads));
diff --git a/include/configs/colibri-imx8x.h b/include/configs/colibri-imx8x.h
index 0f4e415678..c30547d7dc 100644
--- a/include/configs/colibri-imx8x.h
+++ b/include/configs/colibri-imx8x.h
/* Enable Distro Boot */
#define BOOT_TARGET_DEVICES(func) \
@@ -41,12 +41,13 @@
M4_BOOT_ENV \
MEM_LAYOUT_ENV_SETTINGS \
"boot_script_dhcp=boot.scr\0" \
- "console=ttyLP3\0" \
+ "console=ttyLP2\0" \
"fdt_board=eval-v3\0" \
When I create an image with these patches u-boot seems to crash.
I am using the following BSP to build my image:
<remote name="toradex"
fetch="git://git.toradex.com"/>
<project name="meta-toradex-bsp-common"
remote="toradex"
revision="a1a81391a926d64010447d0e1b7700947b682393"
upstream="kirkstone-6.x.y"
path="layers/meta-toradex-bsp-common"/>
<project name="meta-toradex-nxp"
remote="toradex"
revision="c997bae3e7e21380d2ad11919a6dd1762bd3fbba"
path="layers/meta-toradex-nxp"/>
Are my changes correct and are there additional changes I need to switch the UART ?
