I’m trying to use TorizonCore builder to pre-provision containers to a TEZI-installable image. I’ve installed TorizonCore Builder using the shell script, and am now following this guide to try to create a TorizonCore image with a hello-world Docker container preprovisioned.
When I follow the steps in the guide, the tar that is generated is identical to the vanilla TorizonCore image I’m basing it on - it does not contain the preprovisioned container.
Am I misunderstanding how this tool is supposed to work? I’d eventually like to create a TEZI-compatible image that contains all of my applications in containers, running on vanilla Torizon.
For clarity, console output of what I am attempting is shown below:
user@ubuntu:~/tcb-test$ cat docker-compose.yml
version: '2.4'
services:
hello-world:
image: hello-world
user@ubuntu:~/tcb-test$ mkdir image && wget -P image/ https://artifacts.toradex.com/artifactory/torizoncore-oe-prerelease-frankfurt/dunfell-5.x.y/monthly/12/apalis-imx6/torizon-upstream/torizon-core-docker/oedeploy/torizon-core-docker-apalis-imx6-Tezi_5.3.0-devel-202105+build.12.tar
2021-05-21 12:47:51 (9.77 MB/s) - ‘image/torizon-core-docker-apalis-imx6-Tezi_5.3.0-devel-202105+build.12.tar’ saved [173742080/173742080]
user@ubuntu:~/tcb-test$ torizoncore-builder bundle --host-workdir=$(pwd) --platform=linux/arm/v7 --file docker-compose.yml
user@ubuntu:~/tcb-test$ torizoncore-builder combine --image-directory ./image --output-directory ./image_output
Creating copy of TorizonCore source image.
Combining TorizonCore image with Docker Container bundle.
Successfully created a TorizonCore image with Docker Containers preprovisioned in ./image_output
user@ubuntu:~/tcb-test$ # The generated archive is the same as the source archive:
user@ubuntu:~/tcb-test$ sha256sum image/torizon* image_output/torizon*
ac02982caba038e9be93b09cbf4b147a9ea0faf0f170d86e1ff7aea5e3dd23e5 image/torizon-core-docker-apalis-imx6-Tezi_5.3.0-devel-202105+build.12.tar
ac02982caba038e9be93b09cbf4b147a9ea0faf0f170d86e1ff7aea5e3dd23e5 image_output/torizon-core-docker-apalis-imx6-Tezi_5.3.0-devel-202105+build.12.tar
