We built your “image tdx-reference-minimal-image” using bitbake and also checked your prebuilt reference image i.e. Apalis-iMX8_Reference-Minimal-Image-Tezi_5.6.0
The question is that we want to use the UART in the M4_0 core and make it available to linux applications running on the A cores.
Sorry for simple questions… I guess that:
- we need firmware in the M4_.0 to handle the UART device (not accesible to the Acores)
- further, we will need some rmsg channel to/from the M4core-Acore for sending receiving through this UART device
Can you confirm the above questions?
Looking at the settings in my u-boot, I concluded that no firmware is loaded in the M4 as I could not find any m4_0.bin file in the image and the loadm4image_0 looks imcomplete and not part of the bootcommad, is that assumption correct?
Finally are there any reference images for the M4 and linux that we can use and, ideally, make available the UART to the applications running on linux?
Let me know if everything is clear and feel free to ask any questions you might have.
It’s not possible to share the UART between the M4 Core and the A Core. All the resources are allocated during boot time.
Instead, you will need to choose where you want to use the UART and then communicate the data using the RPMsg.
For example, if you want to use it with the M4 Core, you will need to allocate the UART inside the M4 firmware and disable it inside Linux (A core) device tree. Then, if you need to send data using the A core, you can use the rpmsg channel to send messages to the M4 Core, and M4 will handle it and send the messages through UART. So UART will only be exposed to the M4 Core.
Yes, it is correct, u-boot comes with a default name “m4_0.bin” but this file isn’t called by default. You should set the “bootaux” command to initialize the M4 core.
Thanks for your answer Hiago.
I do not need the M4 up an running by now, just need to use the UART in pins M40_UART0_RX and M40_UART0_TX from the A core.
My device tree is based on imx8-apalis-ixora-v1.2.dtsi, where an imx8-ss-cm41.dtsi is included. I found an
imx8-ss-cm40.dtsi in the freescale directory and included this, then enabled the M40 UART with
&cm40_lpuart {
status = “okay”;
On boot I got some error messages due to this inclusion
[ 0.374543] 000: imx8qxp-lpcg-clk 37620000.clock-controller: failed to get clock parent names
[ 0.374609] 000: imx8qxp-lpcg-clk: probe of 37620000.clock-controller failed with error -22
[ 0.391261] 004: clk: couldn’t get clock 0 for /bus@34000000/serial@37220000
I could not check in detail yet, but should I include anything else?
The cortex M4 features one I2C, one UART, and one GPIO coupled to the M4 cortex, therefore it is not accessible and shared with the Cortex-A. You need to choose a different UART that is available for Cortex-A. Please check the Apalis iMX8 datasheet.
Thanks for your answer. That was indeed my initial understanding.
What I do not understand is what are imx8-ss-cm41.dtsi (included in your reference DT imx8-apalis-ixora-v1.2.dts) and imx8-ss-cm40.dtsi good for… as these resources/devices are not available to the A cores?
Regards
The imx8qm.dtsi comes from NXP, therefore we don’t make any modifications to it. NXP includes the imx8-ss-cm40.dtsi (and cm41), it only allocates the resources for the M4 Core, but not necessarily enables it (you can check the “status” of the nodes).
Therefore I still recommend you customize your device tree (with overlays, for example) to remove these nodes from the Cortex-A to avoid any conflict between M4 and Linux.
