Hello Gerald, thank you for your question!
From your description, it appears that the Torizon IDE extension (running in your VS Code on Mac) tries to connect to Docker at the IP 192.168.88.34:2375—an address that’s not accessible or correct for your Ubuntu Docker host (which should be 192.168.88.57). You also identified that the DOCKER_HOST environment variable on your Mac is set to the wrong IP and attempts to change it with export -n don’t fix the problem.
Here are some troubleshooting suggestions to help you resolve this:
1. Check Workspace and User Settings
The Torizon IDE extension (and Docker extensions for VS Code) often reference the DOCKER_HOST variable either from the shell, VS Code settings, or environment files. Make sure none of the following are still pointing to the old host (192.168.88.34):
- Your macOS shell environment (
~/.zshrc or ~/.bashrc)
- VS Code workspace settings (
.vscode/settings.json)
- VS Code user settings
- Any
.env files in your project directory
2. Explicitly Set the Docker Host in VS Code
To ensure VS Code uses the correct Docker host:
- Open the command palette (
Cmd+Shift+P), type Preferences: Open User Settings.
- Search for docker.host.
- If set, update the value to
tcp://192.168.88.57:2375 (replace with the IP of your Ubuntu host).
You can also set this in .vscode/settings.json in your project:
"docker.host": "tcp://192.168.88.57:2375"
3. Relaunch VS Code
Closing and reopening VS Code (or using the “Developer: Reload Window” command) will ensure any updated settings or environment variables are picked up.
4. Confirm Docker Access
From your Mac terminal, try:
export DOCKER_HOST=tcp://192.168.88.57:2375
docker version
If you get a response, you should be able to connect to Docker on the Ubuntu machine.
5. Remove Old Environment Variables
If a stale DOCKER_HOST keeps getting set, check for any login scripts on your Mac or global variables in your profile files:
grep DOCKER_HOST ~/.zshrc ~/.bashrc ~/.profile ~/.bash_profile
Remove or update any occurrences, then reload your shell.
6. Check Compose Task Definitions
If you use VS Code “tasks” for Docker Compose actions, check if any hardcoded DOCKER_HOST values or other scripts are present in .vscode/tasks.json.
For more on customizing workspace and environment settings in Torizon IDE projects, review:
Add Packages, Libraries, Tools and Files
If you adjust these settings to use the correct Docker host, your compose commands from the Mac should work just like on Windows.
Let me know if this helps or if you need further details!
