Using the QSPI interface to access the FPGA as a memory mapped device
Hi All,
I am planning on reading ADC data periodically from and FPGA over the QSPI interface. I want to be able to have read/write access to the FPGA (via QSPI interface) as if the FPGA was just a memory mapped device.
Is this possible? I know that the Linux driver provides high level access to allow reading and writing files over QSPI. However, what I want to know is whether I can have lower level access to the QSPI to make the FPGA look like an attached memory device. Will I need to write my own QPSI device driver or can I simply tweak the existing driver?
Module : NXP® i.MX 8M Mini Computer on Module
Thanks in advance for your help!
Kind regards,
Lakshman
Hi @w1002644 ,
Welcome to the Toradex Community, feel free to browse around.
Thank you for your question.
Could you give some more in-depth information about your setup?
  • HW Type and Version of the module
  • Version and type of carrier board
  • OS and respective version of it
Have a nice day
Kevin
Hi Kevin,
Thank you for your response. I am planning on using the Verdin iMX8M Mini Quad 2GB IT system on module from Toradex (PN: 0059).
I am designing the carrier board myself and will have a Cyclone 10 FPGA on this board, which will interface with the Verdin SoM (via QSPI as I said earlier).
I am planning on using the latest version of Yocto Linux (I believe the latest is version 3.1) as my operating system.
Kind regards,
Lakshman
Hi @w1002644 !
Sorry for the delay.
Please take a look at this other question, that seems related to yours.
Also, if you make your FPGA work just like an SPI-NOR, maybe you can “simply” set your FPGA as an SPI-NOR in the device tree and it would work.
I just can’t confirm as I have no experience with it.
