verdin-imx8mp-15502105 login: torizon
Password:
Login incorrect
Password:
Login incorrect
Password:
Login incorrect
Password:
Login incorrect
To help troubleshoot your login issue on the Verdin iMX8M Plus, I need to understand your setup better.
Could you provide the following details about your system:
You can get detailed information about your system by running the tdx-info command. More details about this tool are available at: tdx-info documentation
The default credentials can vary depending on your OS version and configuration. Once you provide your platform details, I can give you specific guidance for your setup.
Greetings @Adityag,
Have you maybe already changed the password on this device? The default password for the torizon user is torizon. But, after logging in with this password for the first time, the OS should force you to change the password to something else.
If the password torizon is no longer working, then it sounds likely that either you, or someone else has already changed the password on this device.
If you can’t recall the password then the only alternative is to re-flash the OS, using Toradex Easy Installer, so that the password gets reset back to torizon.
