More of a Linux based question. I’m trying to use select on stdin to check for waiting input and it works fine for me in a container on my PC but on Torizon inside a debian container I get:
Exception has occurred: PermissionError
[Errno 1] Operation not permitted
Do I need to pass a device to the container that represents stdin? I tried /dev/stdin but that didn’t help. The container is already privileged but we are trying to get away from that.
Ok, I think I figured this out. It works when I create a release version of the container and run the application there. It must be to do with stdin not being available during debug using the Torizon plugin.
On a related note, is there a way I can test to tell if the container is the release or debug versions?
I’m glad you were able to resolve this on your own. As for release/debug versions, usually the Torizon extension will name the container accordingly. Also the debug container will usually be larger since it has to include debug tools and such.
