Hi there,
I’ve facing some errors during the build process to generate a valid toolchain to be used in Qt creator to develop applications targeting toradex Apalis iMX6Q. First of all I’m using Linux Mint 18.1 Serena based on Ubuntu 16.04 as host machine.
I followed this tutorial here as suggested by toradex team.
On the first part (Prerequisites section) I ran the following code related to Ubuntu 16.04 64bit version:
sudo dpkg --add-architecture i386
sudo apt-get update
sudo apt-get install g++-5-multilib
sudo apt-get install curl dosfstools gawk g++-multilib gcc-multilib lib32z1-dev libcrypto++9v5:i386 libcrypto++-dev:i386 liblzo2-dev:i386 lzop libsdl1.2-dev libstdc++-5-dev:i386 libusb-1.0-0:i386 libusb-1.0-0-dev:i386 uuid-dev:i386 texinfo chrpath
cd /usr/lib; sudo ln -s libcrypto++.so.9.0.0 libcryptopp.so.6
On the Installation section:
mkdir ~/bin
export PATH=~/bin:$PATH
curl http://commondatastorage.googleapis.com/git-repo-downloads/repo > ~/bin/repo
chmod a+x ~/bin/repo
and then:
mkdir oe-core
cd oe-core
repo init -u http://git.toradex.com/toradex-bsp-platform.git -b LinuxImageV2.7
repo sync
Exported the system variables as in:
. export
Once in the build directory I had to modify my local.conf file, located at build/conf/local.conf to setup the MACHINE variable to MACHINE ?= "apalis-imx6" and added the ACCEPT_FSL_EULA = "1" to the file.
At the end, in the Building section I tried to generate the toolchain targeting Qt Creator:
bitbake angstrom-qt-x11-image -c populate_sdk
but I just got this error here:
ERROR: Execution of event handler 'config_reparse_eventhandler' failed
File "/home/prjs/apalis/oe-core/layers/openembedded-core/bitbake/lib/bb/build.py", line 261, in exec_func(func='oecore_update_bblayers', d=<bb.data_smart.DataSmart object at 0x7faa9d3cd630>, dirs=None, pythonexception=True):
if ispython:
> exec_func_python(func, d, runfile, cwd=adir, pythonexception=pythonexception)
else:
File "/home/prjs/apalis/oe-core/layers/openembedded-core/bitbake/lib/bb/build.py", line 306, in exec_func_python(func='oecore_update_bblayers', d=<bb.data_smart.DataSmart object at 0x7faa9d3cd630>, runfile='/home/prjs/apalis/oe-core/build/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/defaultpkgname/1.0-r0/temp/run.oecore_update_bblayers.18168', cwd=None, pythonexception=True):
comp = utils.better_compile(code, func, "exec_python_func() autogenerated")
> utils.better_exec(comp, {"d": d}, code, "exec_python_func() autogenerated", pythonexception=pythonexception)
except (bb.parse.SkipRecipe, bb.build.FuncFailed):
File "/home/prjs/apalis/oe-core/layers/openembedded-core/bitbake/lib/bb/utils.py", line 399, in better_exec(code=<code object <module> at 0x7faa9cee4f60, file "exec_python_func() autogenerated", line 2>, context={'d': <bb.data_smart.DataSmart object at 0x7faa9d3cd630>}, text='\noecore_update_bblayers(d)\n', realfile='exec_python_func() autogenerated', pythonexception=True):
try:
> exec(code, get_context(), context)
except (bb.BBHandledException, bb.parse.SkipRecipe, bb.build.FuncFailed, bb.data_smart.ExpansionError):
File "exec_python_func() autogenerated", line 2, in <module>
File "/home/prjs/apalis/oe-core/build/../layers/openembedded-core/meta/classes/sanity.bbclass", line 84, in oecore_update_bblayers(d=<bb.data_smart.DataSmart object at 0x7faa9d3cd630>):
current_lconf = int(d.getVar('LCONF_VERSION', True))
> lconf_version = int(d.getVar('LAYER_CONF_VERSION', True))
TypeError: int() argument must be a string, a bytes-like object or a number, not 'NoneType'
ERROR: Error parsing configuration files
if ispython:
else:
try:
Could someone help me on this issue? I already tried different solutions, but none of them solved this error.
Layon
