I followed Building Machine Learning Software with Reference Images for Yocto Project | Toradex Developer Center and that seems to work just fine.
However, when running my custom network (which contains an LSTM layer) it fails with the following message when I run the tensorflow lite benchmark with --use_nnapi=true:
E [vsi_nn_kernel_create_node:656]Load client node from kernel com.vivantecorp.extension.cl.lstmunit_activation_S_F32toF32_F32_SIGMOID fail with -7.
E [vsi_nn_kernel_create_node:656]Load client node from kernel com.vivantecorp.extension.cpu.lstmunit_activation fail with -7.
W [vsi_nn_kernel_selector:977]No valid kernel for lstmunit_activation
E [vsi_nn_internal_compute_node:615]op_compute fail 79
E [vsi_nn_internal_compute_node:615]op_compute fail 80
E [compute_node:354]Create node[1] LSTM_OVXLIB fail
This is unexpected as the LSTM operation is supposed to be supported.
Anyone knows what is going on here?
Hi @sannenj
Could you provide the version of the hardware and software of your module?
I think in your case, you are using a custom image. Could you let us know how you created the custom image?
Please share also information about how we can reproduce the issue?
Thanks and best regards,
Yes I have created a custom image. I have created it using the steps as described in the linked article.
I have an Ixora 1.1A and an Apalis 1.2B imx8qm.
For reproducing the issue you need to run the tensorflow benchmark application with a model that has an lstm unit. Unfortunately I am not allowed to share the model I am using. I will try to reproduce first with a publicly available network and then let you know.
Thanks for the information. We will wait for your example where we can reproduce this issue.
Hi @sannenj
Were you able to create an example with a public network.
Unfortunately not. I could not spend much time on it and was not able to find such a model yet. I did find some but they were not in tflite format. It will probably take a while as this now has very low priority within my company.
Hi @sannenj
Thanks for your feedback. Feel free to write us once you found such a model.
