we have I2C devices behind a PCA9548A I2C mux. It works from Linux, but I would also want to access the I2C devices from U-boot. In the u-boot .conf the TI PCA954x driver can be enabled, but this driver uses the driver model for I2C devices (CONFIG_DM_I2S), which seems to be incompatible with CONFIG_SYS_I2C.
make shows:
error: #error "Cannot define CONFIG_SYS_I2C when CONFIG_DM_I2C is used"
# error "Cannot define CONFIG_SYS_I2C when CONFIG_DM_I2C is used"
CONFIG_SYS_I2C is defined in some toradex specific files like /board/toradex/apalis_imx6/apalis_imx6.c. It also seems to be required by pf0100.c (“The following is needed during production”).
What is your suggestion how to proceed? Will CONFIG_DM_I2S be supported?
I enabled:
Device-Tree Control → Run-ime configuration via Devicetree
Device Drivers->I2C Support->Enable Driver Model for I2C drivers
Device Drivers->I2C Support->Enable I2C compatibility layer
Device Drivers->I2C Support-> Support for I2C multiplexers
Device Drivers->I2C Support-> TI PCA954x I2C Mux/switch
I am on aca804c9ddadbf34a8ff82779e5598ec5e319f23 of 2016.11-toradex u-boot
Matthias
