aehki
1
Hello everyone,
I would like to know if it is possible USB 3G key and/or usb gps key in Windows Embedded 2013.
If yes, do you have some reference working actually ?
I need to send data (ethernet way is not possible), and get gps position in our software.
Thanks for your help.
Dear @aehki
There are solutions which provide exactly the combination you want. I know of a customer which uses the following module:
There are Windows CE drivers available.
Please don’t treat the information as a recommendation to use this particular module, but it is the only device that I know it is in use.
Regards, Andy
aehki
3
Ok thank you very much, I will contact them to know if it will fit with our application.
best regards.
