SVL
January 30, 2024, 4:14pm
1
Hello.
I want to capture interlaced 720x576 video via BT.656 input on Apalis imx6 + Apalis Evaluation Board. BSP 6.
I’ve already compiled my own kernel and wanted to start with the adv7180-adv7280 driver as an example, but I can’t find the source code for these drivers in the toradex_ti-linux-6.1.y branch.
Can someone give me a quick guide to creating such a driver or share an example of such a driver?
Thanks.
Hi @SVL ,
can you share me the output of tdx-info
on your module?
Getting Device Information with Tdx-Info | Toradex Developer Center
The latest kernel for Apalis iMX6 is based on mainline Linux Kernel 6.1.xx as you can refer here Embedded Linux Release Matrix | Toradex Developer Center .
Please note that the Apalis iMX6 has moved to the upstream kernel (as of today v6.1.55
) as you can see here Build Linux Kernel from Source Code | Toradex Developer Center . You can find the source code of the driver here: adv7180.c « i2c « media « drivers - kernel/git/torvalds/linux.git - Linux kernel source tree . The branch you were pointing out (toradex_ti-linux-6.1.y branch) was meant for TI SoC based SoM.
The driver is also compatible for ADV7280 as you can read from the device tree bindings here . See the code snippet below:
properties:
compatible:
items:
- enum:
- adi,adv7180
- adi,adv7180cp
- adi,adv7180st
- adi,adv7182
- adi,adv7280
- adi,adv7280-m
- adi,adv7281
- adi,adv7281-m
- adi,adv7281-ma
- adi,adv7282
- adi,adv7282-m
Let me know if this helped you further.
SVL
February 2, 2024, 3:40pm
3
Hi.
root@apalis-imx6-11274726:~# tdx-info
Software summary
Bootloader: U-Boot
Kernel version: 6.1.71-6.5.0-testbuild+git.38fb82ecd144 #4 SMP Fri Jan 26 09:55:03 CET 2024
Kernel command line: enable_wait_mode=off vmalloc=400M root=PARTUUID=0e2d22cf-02 ro rootwait fec_mac=00:14:2d:ac:09:e6 consoleblank=0 no_console_suspend=1 console=tty1 console=ttymxc0,115200n8 mxc_hdmi.only_cea=1 fbmem=32M
Distro name: NAME="TDX Wayland with XWayland Upstream"
Distro version: VERSION_ID=6.5.0-devel-20240118094319-build.0
Distro variant: -
Hostname: apalis-imx6-11274726
Hardware info
HW model: Toradex Apalis iMX6Q/D Module on Apalis Evaluation Board
Toradex version: 0028 V1.1D
Serial number: 11274726
Processor arch: armv7l
root@apalis-imx6-11274726:~# tdx-info -dt
Device tree
Device tree enabled: imx6q-apalis-eval.dtb
Compatible string: toradex,apalis_imx6q-evaltoradex,apalis_imx6qfsl,imx6q
Device trees available:
imx6q-apalis-ixora-v1.1.dtb
imx6q-apalis-ixora-v1.2.dtb
imx6q-apalis-ixora.dtb
Device tree overlays
Overlays enabled: fdt_overlays=apalis-imx6_panel-cap-touch-10inch_overlay.dtbo
Overlays available:
apalis-imx6_adv7280_overlay.dtbo
apalis-imx6_hdmi_overlay.dtbo
apalis-imx6_ov5640-v11a_overlay.dtbo
apalis-imx6_ov5640_overlay.dtbo
apalis-imx6_panel-cap-touch-7inch_overlay.dtbo
apalis-imx6_panel-edt-5.7inch_overlay.dtbo
apalis-imx6_panel-edt-7inch_overlay.dtbo
apalis-imx6_panel-res-touch-7inch_overlay.dtbo
apalis-imx6_spi1_spidev_overlay.dtbo
apalis-imx6_spi2_spidev_overlay.dtbo
apalis-imx6_tc358743_overlay.dtbo
apalis-imx6_vga-640x480_overlay.dtbo
Thank you. It seems that my mistake is that I used a downstream kernel. OK, I need time to do some research.
I will let you know if I have any more problems or questions.
Thanks.
