Is it possible to use boost library on toradex platform?
If yes, how to setup eclipse to work with boost?
Regards
Sure, boost is e.g. available in openembedded-core as can be seen from the layer index. Just add it to IMAGE_INSTALL of your resp. image recipe or append it via local.conf as explained in the following article on our developer website.
Just build your cross tool chain the populate_sdk way and it will include resp. development headers. Then integrate it with Eclipse as usual.
