Hello Toradex Community
We experience a problem after migrating to Toradex’ debian bookworm base container from the earlier arm64v8-debian-base. Usign the same Dockerfile, our created user dosen’t have permission to delete any file. Please see the minimal example below. This was only reproducible on the SoM running TorizonOS, but not when pulling the container on an arm64 laptop. It was also not reproducible on a more recent version of TorizonOS.
As you can see below, the newly created user myuser is not allowed to delete file in its own user directory. Interestingly tough, using rm -f seems to do the trick. We would however very much like to have the exact same permissions and behaviour as on previous versions.
Any help on this topic is greatly appreciated. Please let me know if any other information is required. Thank you very much.
Minimal example ( TorizonCore 5.7.2)
sh-5.0$ docker run --rm -it torizon/debian:3-bookworm
root@24231a3ec667:/# adduser --disabled-password --gecos "" myuser
Adding user `myuser' ...
Adding new group `myuser' (1001) ...
Adding new user `myuser' (1001) with group `myuser (1001)' ...
Creating home directory `/home/myuser' ...
Copying files from `/etc/skel' ...
Adding new user `myuser' to supplemental / extra groups `users' ...
Adding user `myuser' to group `users' ...
root@24231a3ec667:/# su myuser
myuser@24231a3ec667:/$ cd home/myuser
myuser@24231a3ec667:~$ touch afile
myuser@24231a3ec667:~$ rm afile
rm: cannot remove 'afile': Operation not permitted
myuser@ 24231a3ec667:~$ ls -la
total 20
drwx------ 2 myuser myuser 4096 Sep 2 11:04 .
drwxr-xr-x 1 root root 4096 Sep 2 11:03 ..
-rw-r--r-- 1 myuser myuser 220 Sep 2 11:03 .bash_logout
-rw-r--r-- 1 myuser myuser 3526 Sep 2 11:03 .bashrc
-rw-r--r-- 1 myuser myuser 807 Sep 2 11:03 .profile
-rw-r--r-- 1 myuser myuser 0 Sep 2 11:04 afile
myuser@ 24231a3ec667:~$ echo "hello" >> afile
myuser@ 24231a3ec667:~$ cat afile
hello
myuser@ 24231a3ec667:~$ rm -f afile
Expected behaviour (TorizonCore 5.7.2)
sh-5.0$ docker run --rm -it torizon/arm64v8-debian-base
root@24370b27fe60:/# adduser --disabled-password --gecos "" myuser
Adding new user `myuser' (1001) with group `myuser' ...
root@24370b27fe60:/# su myuser
myuser@24370b27fe60:/$ cd home/myuser
myuser@24370b27fe60:~$ touch afile
myuser@24370b27fe60:~$ rm afile
tdx-info output
Software summary
Bootloader: U-Boot
Kernel version: 5.4.193-5.7.2+git.b60d3160fd04 #1-TorizonCore SMP PREEMPT Fri Dec 23 15:47:24 UTC 2022
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.0/torizon/020545d935d9f72873c9b5be7c5bb59b1c7cc1886ca7979b5e9e3950434b330e/0 kernel.sched_rt_runtime_us=-1
Distro name: NAME="TorizonCore"
Distro version: VERSION_ID=5.7.2-build.20
Distro variant: VARIANT="Docker"
Hostname: rstest
Hardware info
HW model: Toradex Apalis iMX8QM V1.1 on Apalis Evaluation Board
Toradex version: 0037 V1.1B
Serial number: 06738340
Processor arch: aarch64
Running the Toradex base container on an arm64 Mac
root@e21a25d91fc2:/# adduser --disabled-password --gecos "" myuser
root@e21a25d91fc2:/# su myuser
myuser@e21a25d91fc2:/$ cd /home/myuser
myuser@e21a25d91fc2:~$ touch afile
myuser@e21a25d91fc2:~$ rm afile
I also tried the same on the same SoM running TorizonOS 6.6.1 and it worked without any problems.
sh-5.1$ sudo tdx-info
Password:
Software summary
Bootloader: U-Boot
Kernel version: 5.15.148-6.6.1+git.23a8e831749d #1-TorizonCore SMP PREEMPT Thu Feb 29 20:25:21 UTC 2024
Kernel command line: root=LABEL=otaroot rootfstype=ext4 quiet logo.nologo vt.global_cursor_default=0 plymouth.ignore-serial-consoles splash fbcon=map:3 ostree=/ostree/boot.1/torizon/42030519c913f0e3ac912532a62fb43aca3c0735968f33b9a7cae8e6c9bdc1de/0 kernel.sched_rt_runtime_us=-1
Distro version: VERSION_ID=6.6.1-build.14
Hostname: rstest
Hardware info
sh-5.1$ docker run --rm -it torizon/debian:3-bookworm
root@84790f2e20cc:/# adduser --disabled-password --gecos "" myuser
root@84790f2e20cc:/# su myuser
myuser@84790f2e20cc:/$ cd /home/myuser
myuser@84790f2e20cc:~$ touch afile
myuser@84790f2e20cc:~$ rm afile
