I have IMX8MP and Mallow carrier B’d.
I want to download it to the board using Easy Installer, but Mallow carrier B’d doesn’t have a recovery SW, how can I download it?
Hello! Thank you for your question.
Since the Mallow carrier board does not provide a recovery button, you can still load the Toradex Easy Installer using external media, such as an SD Card or a USB Stick. Here’s how to do it:
Download the Toradex Easy Installer image for your module from the Toradex Easy Installer download page.
Prepare external media (SD Card or USB Stick):
- Format your SD Card or USB Stick as FAT (FAT-32 recommended).
- Unzip the Easy Installer package and copy its contents to the root directory of your external media.
Boot order for the iMX8MP platform:
- The system checks for bootable images in the following order: SD Card, internal eMMC, then USB Stick.
To boot from the USB Stick (if you want to use USB):
- Connect to the board using the serial debug UART to access the U-Boot console.
- Insert your prepared USB stick.
- Power on the board.
- Stop the U-Boot autoboot process by pressing any key when prompted in the console.
- At the U-Boot prompt, run the command:
run bootcmd_usb0 - The board should now boot the Toradex Easy Installer from your USB stick.
This method works even if your carrier board lacks a dedicated recovery mode button. Detailed instructions are available here:
Loading Toradex Easy Installer from SD Card/USB Stick
If you need further guidance on any specific step, please let me know!
Hi @junho
You can find instructions to enter recovery mode on Mallow here.
