I don’t have specific information about using sshlib inside containers with Torizon OS in the provided documentation sources. However, I can provide guidance on container networking and port exposure based on the official Torizon documentation.
Container Port Configuration
When running SSH services inside containers on Torizon OS, you’ll need to properly expose ports. The documentation shows how to expose ports to the network where your device is connected (1). By default, no ports are exposed by containers, so you must enable them at runtime when starting your container (1).
Port Requirements
For container networking with Torizon, be aware that certain ports are commonly used by the system (2):
- 22 (Dev Board SSH Connection)
- 2375 (Docker API)
- 5002 (Local Docker Registry)
- 2222 (Container SSH Connection)
You’ll want to avoid conflicts with these ports when implementing your SSH server.
Alternative: Torizon Remote Access
Before implementing a custom SSH solution, consider that Torizon already provides a secure remote access feature. Torizon Remote Access offers instant SSH access to devices with extensive security benefits (3), including:
- Extensive metadata validation
- Strict authorization process
- HTTPS certificate pinning
- Mutual TLS (mTLS) authentication
- User-controlled session initiation
- Session timeout and server control
This built-in solution provides secure command-line access without the complexity of implementing your own SSH server (4).
Network Configuration
When configuring your container, you can expose ports using the -p option with docker run, or define port mappings in your docker-compose configuration (1). The container networking documentation indicates that ports can be redirected, so a server bound to one port inside the container can be accessible on a different port on the device (1).
For troubleshooting connectivity issues, ensure your container networking is properly configured and that no firewall rules are blocking the connections.
