Hello.
We’re currently producing a custom carrier board and we would like to use the current pins assigned to the Ixora’s LEDs as GPIOs.
My question is: On my custom device tree, if I change the pins used on ixora’s leds to the general gpio node directly can I use them as such?
I.e. by removing:
leds_ixora {
pinctrl_leds_ixora: ledsixoragrp {
fsl,pins = <
MX6QDL_PAD_SD2_DAT1__GPIO1_IO14 PAD_CTRL_HYS_PU
MX6QDL_PAD_SD2_DAT3__GPIO1_IO12 PAD_CTRL_HYS_PU
MX6QDL_PAD_NANDF_D1__GPIO2_IO01 PAD_CTRL_HYS_PU
MX6QDL_PAD_NANDF_D2__GPIO2_IO02 PAD_CTRL_HYS_PU
And adding them to:
&iomuxc {
* Mux the Apalis GPIOs, GPIO7 used for PCIe reset,
* GPIO5, 6 used by optional fusion_F0710A kernel module
pinctrl-names = "default";
pinctrl-0 = <&pinctrl_apalis_gpio1 &pinctrl_apalis_gpio2
&pinctrl_apalis_gpio7 &pinctrl_apalis_gpio8>;
Joao
